The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Thread Tools Display Modes
Old 08-27-2006, 11:40 AM   #16
Raw Wave
lostreception's CarPC Specs
lostreception's Avatar
Vehicle: Chevy Van G20 and '06 Scion Xb
My Photos: (1)
my guess is reshacker
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Sponsored Links
Old 08-27-2006, 12:13 PM   #17
mbkowns's Avatar
Vehicle: 2005 Ford Mustang GT
My Photos: (0)
Did you make it so it pauses the music?
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
mbkowns is offline   Reply With Quote
Old 08-27-2006, 12:40 PM   #18
Raw Wave
justintime's Avatar
Vehicle: 2002 Honda CR-V
My Photos: (0)
He said the following... so no idea HOW he removed the images!
Quote: Originally Posted by alti View Post
I did not hack IG at all, although i know that you can get the best results doing so, I wanted it to be a plug and play solution. to install this you will litterly just drop the folder in the plugins folder and if ig is in the default directory (if not you can change it in settings) set a button like any other plugin and you good to go.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 08-29-2006, 07:57 PM   #19
My Photos: (0)
so... almost means ... ____? ETA?!
Yellow-Snow is offline   Reply With Quote
Old 08-29-2006, 09:49 PM   #20
alti's Avatar
Vehicle: 2002 Nissan Altima
My Photos: (0)
sorry, its comming, i had a hell of a weekend and my wedding is now less then a month away. I am really sorry for being so slow, I have not even been able to login here in days.
Will update soon.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Sponsored Links
Old 08-30-2006, 10:23 PM   #21
alti's Avatar
My Photos: (0)
here is a VERY alpha version that I am making availible mostly because i dont have much time right now to finish it.
there is no setup (does not matter for skin and language changes) I did however add the path and filename it will load into the config.xml file the only thing that you can not change is the drive letter. You can edit the config xml directly.
This really only works with version 3. version 2.0 and i assume 2.1.x will work but the menu might not come up making it impossible to choose a destination ect.
I would love to hear of your experiences (screen shots are helpful) with differnt versions as well as suggestions...
thanks,
Download
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 08-30-2006, 10:33 PM   #22
Vehicle: 2005/Ford/Mustang GT
My Photos: (0)
I'm also curious to know how did he remove the + - mute without reshack.
enitalp is offline   Reply With Quote
Old 08-30-2006, 11:33 PM   #23
alti's Avatar
My Photos: (0)
quite simple, actually, I just moved them off the screen.
crude, I know, but it works.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 08-31-2006, 06:08 AM   #24
My Photos: (0)
You found the window of the control ? i tried with spy++ but can't find their ID.
Did you also kept the menu and clip the window ? everytime i tried to get ride of the menu IG crash (but only when a gps device is attached to the computer).
Old 08-31-2006, 09:35 AM   #25
Raw Wave
justintime's Avatar
My Photos: (0)
how can you move individual controls out of the window, Alti? You mean you just stretched the overall iG3 window, or...?
2002 Honda CR-V
Old 08-31-2006, 12:01 PM   #26
alti's Avatar
My Photos: (0)
yep
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 08-31-2006, 12:02 PM   #27
alti's Avatar
My Photos: (0)
yes i kept the menu and sized it off the top, I tried removing it first but ran into problems with crashes when sending commands as you describe.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 08-31-2006, 12:05 PM   #28
Raw Wave
justintime's Avatar
My Photos: (0)
I dont understand how you could have strectehd it horizontally like you describe, while keeping the bottom menu untouched. The bottom menu with ETA etc does not appear to be clipped!
2002 Honda CR-V
Old 08-31-2006, 12:32 PM   #29
alti's Avatar
My Photos: (0)
it is, notice that ther is no label visiable in the left most field on the bottom
you can see it if you use UMPC or an older version better since i have not yet made the amount it clips configurable to adjust for differnt versions.
I will also make it a feature that you can turn on and off
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 08-31-2006, 12:47 PM   #30
Raw Wave
justintime's Avatar
My Photos: (0)
OK, I see it now.
So, if someone scrolls/pans the map, will they see the RED 'X' on the far lower right, to exit the panning mode??!?!
2002 Honda CR-V
Sponsored Links
vB code is On
Trackbacks are Off
iGuidance SDK Quattro GPS 57 06-23-2006 07:37 AM
Killer egg ?!?! or no? - everyones input please paperisdeliciou LCD/Display 12 10-28-2004 04:04 AM
Ready to purchase, input please! brandon Newbie 20 07-03-2004 03:05 AM
How do you input your destination? (particularly iGuidance users) shakes GPS 5 01-19-2004 12:57 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 05:39 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
