09-01-2006, 12:59 PM
#46
Vehicle: 2002 Nissan Altima
I just made the position of ig adjustable via editing the config, I should have it up later this afternoon.
Untill I figgure out why it would render diffenrntly on some machines then others it will be manually adjustable.
I will post again when the fix is up.
09-01-2006, 01:03 PM
#47
Quote: Originally Posted by Yellow-Snow
everything is normal and working for me.
RC2?
Quote: Originally Posted by JWise1203
Same here ... Ruinning RC2
im running RC2. i changed it to true and it works on mine. just still to the left
project in the works....no worklog but i will post a completed thread.
09-01-2006, 04:43 PM
#48
Here's some more info that you might need. I am running in 800X600 resolution because my video card ( http://store.mp3car.com/ProductDetai...Code=MTB%2D003) refuses to display 800x480 (grrr!)
09-01-2006, 04:54 PM
#49
ah ha! you could have something, the computer i had the issue on was native 800x600 to
I did not think that was it because i changed the resolution size alot in testing
09-01-2006, 04:58 PM
#50
thanks Jwise, got it
It only happens when you open CF in 800x600 when windows is set to 800x600
that is why i did not catch it on my development machine (happly running 1920x1200  ) 800x600 seems to work in any other resolution.
09-01-2006, 05:04 PM
#51
no matter the resolution in cf or my screen in general, i get the cutting off issue. it is equal on both sides though.
still, great job.
09-01-2006, 05:12 PM
#52
I think i nailed down the pattern now, if CF and windows screen size are the same, you will encounter the cut off issue. If they are differnt (ie windows is set to 1024x768 and CF is set to 800x600) then it works.
I did not catch this because i was testing on my home computer.
I dont yet know exactly why it is happening yet though, but i will figgure out the agustments necassary.
Can everyone who reported it working confirm that there windows and cf resolutions were differnt when it worked?
09-01-2006, 05:35 PM
#53
ok, I know why, its because i want to push the ig screen farther to the right then the screen size itself.
I just put up a new version that allows you to move the ig screen around by editing the xoffset, yoffset, widthoffset and heightoffset in the config
I made the xoffset 0 and widthoffset 0 it should resolve the issue but the menu and + - will be back on the screen. the old settings to remove the side areas are xoffset = -42 and widthoffset = 84
I will have to find a work around or a better way to do it
09-01-2006, 06:00 PM
#54
my cf and windows resolutions are completely different and im still getting the cutoff. ill dowload the new version and play around with it.
09-05-2006, 02:17 AM
#55
Vehicle: 2005 Ford Mustang GT
Alti
When I load CFIG from the menu it loads but the toolbar for ig3.0 still shows up until I hit the fullscreen skin button on the top right and then again for small mode. Did I do something wrong?
let me know
09-05-2006, 06:16 AM
#56
are you using the standard skin?
09-05-2006, 06:17 AM
#57
anyone else having the same issue?? and did you download the version i put up late last week with the ajustments in the xml to adjust for ig not embedding correctly?
and just to be clear, your saying that it shows the menu when it first loads, but after you press the max/min button twice it does not show the menu?
if so after you hit the min/max button the first time does it show the menu in full screen mode?
09-05-2006, 11:32 AM
#58
Alti I downloaded latest version of CF RC2 + latest version of CFIG. I press the menubutton to load it and it starts out wiht the top menu bar showing. If I hit max it goes away but I usually hit it twice to get back to min mode. It never shows up after that even if I use the other buttons...
Kinda wierd what do you think?
09-05-2006, 12:53 PM
#59
09-05-2006, 01:45 PM
#60
I have been doing most of my testing on my devolopment machine which does not have a gps connected.
I dont get the warning message though, maybe it came up the first time i ran it, I dont remember.
thanks for the info, I will try to re-create tonight.
| Thread Tools |
| Display Modes |
Linear Mode
