09-20-2006, 11:29 AM
#106
MySQL Error
Quote: Originally Posted by Gearhead61
How do you 'reference' the new dll? I thought you just had to drop the plugin into the plugins folder and go with it?
Good luck this weekend alti! Congratulations on tying the knot!
This was a comment for the programmer of the application... It's nothing a user would do...
david
09-20-2006, 12:41 PM
#107
Vehicle: 2003 Ford Ranger FX4 Level II
Oh ok thanks David! I'm going to try and see if I can't find something in the error log regarding the missing plugins and see if I can't get it to you before tonight. Damn classes are interfering with my college experience!
09-20-2006, 01:12 PM
#108
MySQL Error
you have to have the CAM plugin in the plugins folder, it's under known issues now...
when you remove CAM from the plugins folder it is causing issues...
david
09-20-2006, 02:24 PM
#109
Quote: Originally Posted by alti
I am getting married this weekend, so i might not be able to address any issues that pop up with any real efficency... but if there are any issues post them up and i will try to help out as soon as i can...
lol man, you've done more than enough already. screw the internet, go get married
congrats.
09-20-2006, 10:14 PM
#110
Vehicle: 2002 Nissan Altima
thanks for all of the well wishes everyone, everything is going well so far...
@ TC no go on stopping by the meet  the old ball and chain said no lol
Really nice job on that altima... they have such a nice large space in the dash just begging to be redone...
I really like your portrait solution that is really sweet... nice
09-20-2006, 10:25 PM
#111
I have started noticing an issue with CFiG and phone control, I have not had alot of time to play and test but i believe it is a problem with cfig.
When i get a phone call and CFiG is the displayed plugin the dialog box that would show the person calling and have the answer and hang up options is not visible... and if i press back I get an area in the middle of the screen where the phone dialog would have been that does not get redrawn and shows part of the ig map that was there.
hope that made sense...
If anyone else is using CFiG and bluetooth phone control let me know if you notice the same issues.
09-20-2006, 11:53 PM
#112
I'll let you know once I get it all working
09-21-2006, 10:50 AM
#113
I was able to play with it a bit driving around and best i can tell this is not an issue with CFiG I am having the problem even if I remove both my plugin folders from plugins and reboot. Seems that the phone control plugin never renders the dialog box and the area it occupies refuses to re-paint regardless of what plugin or menu was displayed at the time...
I will read throught the main cf bugs thread and post something there.
09-21-2006, 02:40 PM
#114
Man maybe I should just stick to RC1...
09-27-2006, 11:53 AM
#115
<snip>
10-12-2006, 05:52 PM
#116
sweet plugin and congrats on the ball and chain.
i'm new to the cf world but is there a way you can link the drop down menu "NAV' button to open this plugin instead of destinator?
10-12-2006, 06:43 PM
#117
Vehicle: '95 Cadillac Eldorado 4.6L 300HP Northstar Maroon
i'm new to the cf world but is there a way you can link the drop down me "NAV' button to open this plugin instead of destinator?
Yes, go into "Tools" scroll down to "Button Layout" and change one of your unused Global and Main Buttons to CFIG (CFIG appears near the bottom when you edit your Global and Main button).
Does the following HIEGHT typo change anything within the app (code appears at the end)
<MAINBOX>
<X>0</X>
<Y>100</Y>
<WIDTH>848</WIDTH>
<HIEGHT>270</HIEGHT>
</MAINBOX>
DOH, I may have solved my prob - didn't see the FILENAME tag within config.xml - will change it to iGuidanceUMPC and see if that works.
**Yep, I solved the issue BELOW by changing the FILENAME.**
However, I have a question. I am using RC2 and I tried to get the plugin to work with no avail. The CFIG folder was dropped into the CF plugin folder, and I mapped buttons within CF, so I select iNav within CF and the Skin with 2D/3D and all the other info appears, but the area where the map should be is blank. I have iG ver3 UMPC installed in C:\Program Files\iNav\iGuidance\ - do I need to add iguidanceUMPC.exe to the path within the config.xml file? Also, the CAM plugin was not moved out of the plugin folder - only weather, and TV. TIA
900MHz Duron--ECS K7SEM--256 MB--30GB HD(Windows XP)--160 GB External HD (Music)--ON board Audio/Video--8" TM-868 Touchscreen--300W p/s--TrippLite 300W Inverter--Custom Plexi-glass case
10-13-2006, 01:14 AM
#118
thanks nate - boy do i feel dumb when i figure something out before i get to come back here and delete my post...
10-15-2006, 08:31 AM
#119
<MAINBOX>
<X>0</X>
<Y>100</Y>
<WIDTH>848</WIDTH>
</MAINBOX>
your config.xml (in the plugins\CFiG folder) should have these two lines...
<PATH>c:\Program Files\iNav\iGuidance\</PATH>
<FILENAME>iGuidance</FILENAME> -or- <FILENAME>iGuidanceUMPC</FILENAME>
I think the problem might be that you have the .exe on the end of the filename... I think i have the code adding the .exe for you, so to the code it is actually comming up iGuidanceUMPC.exe.exe, I should have made a check for this in the code, but because i rushed it out before the wedding i did not spend time cleaning it up... I hope this works for you, let me know.
10-16-2006, 06:16 PM
#120
Yeah, I solved my problem that day. I caught the line saying FILENAME, not sure how I missed it the first time. However, ALTI, can you comment on my question about :
Does the following HIEGHT typo within config.xml change anything within the app (code appears at the end)
<MAINBOX>
<X>0</X>
<Y>100</Y>
<WIDTH>848</WIDTH>
< HIEGHT>270</ HIEGHT>
</MAINBOX>
BTW, I love this plugin! Great Job!
| Thread Tools |
| Display Modes |
Linear Mode
