04-08-2007, 08:31 AM
#136
Quote: Originally Posted by evilkokonut
I upgraded to the newest centrafuse version and now iguidance says gps not found when I launch it through centrafuse. When i launch iguidiance outside of centrafuse it works normally. Any ideas?
probibly another device set up with cf that is using the same com port or otherwise conflicting with your gps. (bt, obd2 ect)
04-09-2007, 03:03 AM
#137
yah you're right. destinator said "no port" for gps but I guess it was using the one for iguidance. I just set it to com 4 and it worked.
05-01-2007, 08:47 PM
#138
Quote: Originally Posted by sivart321
Is there anyway to have another button that makes cfig cover the bottom bar as well? One thing I still don't like is the mailbox effect that we are getting with the top menu bars, and the bottom track selection bars. I like how JIT did it in the nexus skin better, but prefer the default skin over his. I would like to see the cfig buttons up top, and iguidance filling the whole rest of the screen below it. That is, till I click the other button. I would really love to have a button on the top cfig bar that brought you straight back to the media section...
Is there anyway to do this in the cfig plugin without changing the skin?
Any word on this idea?
Also, with CF 1.12 with default settings on 800x600, the top and bottom get cut off just a hair on my system. I tried adjusting the y offset and the height adjustments, but no combination seemed to solve the problem. If I get the bottom bar to fit, the top was cut off where the guidance directions would go. Was this covered in earlier posts? I may have missed it.
Thanks!
05-01-2007, 10:46 PM
#139
not without changing the skin
try:
<X>0</X>
<Y>84</Y>
<WIDTH>848</WIDTH>
<HEIGHT>318</HEIGHT>
<FULLX>0</FULLX>
<FULLY>0</FULLY>
<FULLWIDTH>848</FULLWIDTH>
<FULLHEIGHT>480</FULLHEIGHT>
<APPX>0</APPX>
<APPY>51</APPY>
<APPWIDTH>848</APPWIDTH>
<APPHEIGHT>268</APPHEIGHT>
<FULLAPPX>0</FULLAPPX>
<FULLAPPY>51</FULLAPPY>
<FULLAPPWIDTH>848</FULLAPPWIDTH>
<FULLAPPHEIGHT>429</FULLAPPHEIGHT>
Thanks!
i just loaded mine up @ 800 x 600 before making the changes to the skin file above and i did not notice anything
05-10-2007, 04:01 PM
#140
The download link http://www.gormanly.com/CFIG/CFiGv1_1.zip isnt working for me and I didnt see it on the fluxmedia site is there anywhere i can get the plug in from thanks.
05-10-2007, 04:49 PM
#141
VENDOR - Centrafuse
Check http://www.fluxmedia.net/downloads, you will see it listed as a plugin on the main downloads page...
david
05-10-2007, 04:58 PM
#142
I swear it wasn't there an hour ago when I looked. Thanks
05-20-2007, 10:33 PM
#143
its giving me and error saying a newer version is already installed, but there is nothing in my plugins directory.
05-20-2007, 11:31 PM
#144
VENDOR - Centrafuse
I have the same problem (thinks there is a newer version already installed and installer exits). I think David is looking into it...
05-23-2007, 01:03 AM
#145
When it asks - Install for "Just Me" or "Everyone" - Choose Everyone.
This was doing the same thing to me when I chose Just Me.. When I chose Everyone it installed.
05-24-2007, 05:29 PM
#146
Thanks!
Adjust the height setting to 45 under 800x600. After I did that, the bottom output was not cut off.
Dwaine
2003 Black Impala
05-24-2007, 05:31 PM
#147
Quote: Originally Posted by cwwny
This plugin looks awesome.
But when I am at home and the gps is not connected to the UMPC I get a gps not found error from iGuidance. The error is a popup box and it launches iguidance outside of centrafuse. Is that expected behavior?
change the default COM port for the gps under the built-in navigator.
It conflicts with CFIG plug-in.
So if you gps is on COM1. Make sure in the setup for the internal navigator, is set to something other than COM1.
2003 Black Impala
05-24-2007, 05:35 PM
#148
Download is availible on CF's site on the downloads page
I finally have everything cleaned up and ready for a official release. Please let me know if you have any issues at all (even the small details), I want to make sure everything works properly.
Just wanted to say that your plug-in works great. I really appreciate the work that you put into making this plug-in.
Dwaine
2003 Black Impala
05-24-2007, 05:47 PM
#149
VENDOR - Centrafuse
you should also be able to go to the last page of navigation settings and select None for navigation engine
david
06-20-2007, 08:47 PM
#150
I'm using Xport3 and I set the com4 (GPS) to be available on 5 and 6. Destinator is set up for 5 and I started iGuidance outside of CF in windows and set the port to 6. However, any time I start iGuidance inside CF it only wants to use port 1 and well doesn't work because of that. Why won't the plug in version use the saved port that the program has without the plug in?
| Thread Tools |
| Display Modes |
Linear Mode
