Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 06-20-2007, 10:14 PM   #151
Nola111's Avatar
Nola111 is an unknown quantity at this point
Quote: Originally Posted by Ewout_vB View Post
I'm using Xport3 and I set the com4 (GPS) to be available on 5 and 6. Destinator is set up for 5 and I started iGuidance outside of CF in windows and set the port to 6. However, any time I start iGuidance inside CF it only wants to use port 1 and well doesn't work because of that. Why won't the plug in version use the saved port that the program has without the plug in?
I don't know why it doesn't work like that, but if you set it from within the plugin, it will work and retain the setting. I had the same issue.
Nola111 is offline   Reply With Quote
Old 06-20-2007, 11:08 PM   #152
Ewout_vB is an unknown quantity at this point
how do i get to the setting inside the plug in?
Ewout_vB is offline   Reply With Quote
Old 06-21-2007, 12:15 AM   #153
Fixed
Old 06-21-2007, 12:51 PM   #154
Just so people know if you use CFiG. Set the port to something less than 10, it can't handle anything above for some odd reason. It will load it externally but not inside CF.
Old 06-22-2007, 08:09 PM   #155
sivart321 is on a distinguished road
Any chance you can add left and right arrows for us using the UMPC version to switch through the various modes? It is a nice feature, and I hate having to bust out my keyboard to see them.
Possible?
sivart321 is offline   Reply With Quote
Old 06-22-2007, 10:57 PM   #156
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
ya, I have been working on something that should fix that right now it is back burned for a short time, I am going on vacation for a month to Italy and Poland but as soon as I get back i will look into it.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Old 06-27-2007, 11:36 PM   #157
Is there any way to make iGuidance mute the music (pause) the way destinator and mappoint do when integrated in CF?
Old 06-28-2007, 09:53 AM   #158
alti's Avatar
Not the same way unfortunately as there is no sdk for iguidance that would allow this to be done from my software.
Other forum members had been working on this issue, i remember someone had increased the volume of the iguidance sound files so that they were much louder, there might have been other solutions as well, i am not sure.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 07-13-2007, 09:59 AM   #159
mezz64's Avatar
mezz64 is on a distinguished road
Quote: Originally Posted by Yellow-Snow View Post
Does the app that auto switches on turn work with this plugin? Is it built in?
Any Updates on this previously posed question? Thanks
98' Honda CR-V
http://www.superbluecrv.com
*OBDMPG, the RR OBD Plugin*
mezz64 is offline   Reply With Quote
Old 07-19-2007, 08:08 PM   #160
blackrsx is on a distinguished road
I haven't tried this plugin yet because I still can't decide between destinator and iGuidance. I was leaning towards iGuidance but now I just read you can't mute it when iGuidance voice speaks.
Does this plugin at least lower the volume when it's giving you turn directions?
If not, is there any way at all to mute the voice when giving instructions?
Can't David help with it?
blackrsx is offline   Reply With Quote
Old 07-23-2007, 12:03 PM   #161
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
nothing I can do... iGuidance gives you no SDK, so you get no event or anything to tell you that the program is about to speak or give a direction...
there was a workaround at some point I believe, but not sure...
david
veetid is offline   Reply With Quote
Old 07-26-2007, 03:40 AM   #162
does this work for the new iGuidance v4?
Old 07-29-2007, 04:51 AM   #163
PhatMo is on a distinguished road
I have all the maps to Iguidance 3, but I cant get the engine to work for some reason. It doesnt work externally either. When I double click the execution file it does absolutely nothing. Any ideas?
PhatMo is offline   Reply With Quote
Old 08-12-2007, 10:33 PM   #164
macbrando's Avatar
macbrando is an unknown quantity at this point
Hey everyone. I need a little help. I installed the CFiG plugin and am using iGuidance 4. When I run iGuidance, my GPS works. When i then close iGuidance and open CF, then go to CFiG, it shows me the map but doesn't seem to work with my GPS. This only happens when I use iGuidance thru CF. Any ideas? I checked all the settings and they are all the way they should be (COM3, 4800 baud). Thanks!!
| 06 Mitsubishi Raider Durocross |
| CarPC Project:________________ |
| Planning: [*******-------] 50% |
| Carputer: [********------] 60% |
| Fabrication: [*----------] 10% |
macbrando is offline   Reply With Quote
Old 08-13-2007, 10:13 PM   #165
alti's Avatar
I do not have ig4 to test with... does anybody else using cfig have ig4 working with it?
My Install
Software:
CFiG v1
CarShell
StopWatch
Traffic Plugin for Centrafuse? justintime CF Plugins 26 09-09-2006 10:09 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Sample C# Code For Centrafuse Plugin buurin CF Plugins 0 01-27-2006 06:10 PM
Embedding FM PLugin into CENTRAFUSE 1.1 camsgs3 DragonBTV's CarPC Plugins 1 01-16-2005 11:55 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
