Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 02-03-2008, 11:13 AM   #196
SLAYER6669
I'm using the same thing. That is kinda strange that it works for some and not for others.
1991 Camaro Z28
2004 Acura TL
Thirdgenfbodies.com
SLAYER6669 is offline   Reply With Quote
Old 02-04-2008, 03:24 PM   #197
ali7up's Avatar
ali7up is an unknown quantity at this point
sweet plugin. i installed it and when i click cfig there is only a white box on the top left side, no iguidance. i set the correct path and disabled the nav in the settings. any ideas thanks
ali7up is offline   Reply With Quote
Old 02-12-2008, 11:54 AM   #198
jhanson999 is on a distinguished road
Is the version on flux's site 1.00 or 1.1? Because I'd like to use the newest version if possible, and the link for 1.1 is dead.
jhanson999 is offline   Reply With Quote
Old 02-17-2008, 02:51 PM   #199
Ewout_vB is an unknown quantity at this point
Same problem, also are there any plans to add the new skin to this? Looks a bit weird with 2 skins in CF at the same time.
Ewout_vB is offline   Reply With Quote
Old 02-26-2008, 03:15 PM   #200
I contacted the author regarding a skin matching the new Aura CF skin i quickly photoshopped (whether I can release it) and whether I could get the source code to fix the dest button; I have not gotten a reply yet.
Old 02-26-2008, 09:11 PM   #201
Got a reply from the author (nice guy), he gave me the source and permission to modify it.
I'll go ahead and attach the skin in case anyone wants it.
Simply replace your CFiG folder with the one attached, the new default skin is the modified Aura skin I made. (please note this RESETS!!! any settings you set up for CFiG as it replaces the config.xml in the CFiG folder along with the rest of the folder).
I'm currently looking into fixing the "dest" button.
Old 02-26-2008, 10:44 PM   #202
I've figured out why the "dest" button doesn't work with iG v4.
The "2" button the keyboard used to be a link to destination (kind of like "3" for 2d/3d view), however this is no longer true. I don't know the shortcut for the destination in iGuidance v4 though...
Old 02-26-2008, 10:55 PM   #203
I found it!
"alt+F+E"
Old 02-26-2008, 11:07 PM   #204
nobb will become famous soon enoughnobb will become famous soon enough
Why are your screenshots blank in the middle (where the map should be)? Are you also having problems with iguidance v4 embedding? Your work so far looks awesome, I wish I could get my iguidance issues fixed so I can use it =(
nobb is offline   Reply With Quote
Old 02-27-2008, 12:35 AM   #205
CFiG was not installed on that machine -- it embeds just fine for me :-).
Old 02-27-2008, 01:15 AM   #206
Well I ran into a problem -- there is no dedicated shortcut for the destination menu with iG v4, this means that yes we can open it using alt->f->e; however, we wont be able to close it with any shortcut. So I propose to change it to a POI toggle instead.
Old 02-27-2008, 02:36 AM   #207
accordvsick is on a distinguished road
has anyone had a problem with guidance not seeing gps mouse in centrafuse?
I am using centrafuse 1.47 and IGuidance 3.0. Iguidance works fine stand alone, but when I open it using CFIG it launches Iguidance but it doesn't see my gps mouse (BU-353). I exit centrafuse and open up Iguidance it works fine again.
am I missing a setting?
accordvsick is offline   Reply With Quote
Old 02-27-2008, 09:24 AM   #208
Is destinator set up to use the same port? You can only have one application use 1 port at a time -- you might have to use a port splitter like "Xport"
Old 02-27-2008, 09:57 AM   #209
Nola111's Avatar
Nola111 is an unknown quantity at this point
So the attached in post #199 is v. 1.1 then?
Thanks for the skin update Ewout!
Nola111 is offline   Reply With Quote
Old 02-28-2008, 12:58 PM   #210
Yup, I think that was it...seems to be working now.
Thanks!
Traffic Plugin for Centrafuse? justintime CF Plugins 26 09-09-2006 10:09 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Sample C# Code For Centrafuse Plugin buurin CF Plugins 0 01-27-2006 06:10 PM
Embedding FM PLugin into CENTRAFUSE 1.1 camsgs3 DragonBTV's CarPC Plugins 1 01-16-2005 11:55 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
