Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 03-22-2008, 10:30 PM   #211
nobb will become famous soon enoughnobb will become famous soon enough
Ok in regards to the problem of iGuidance 4 not embedding properly...I think there is something wrong with my .exe file. I've tried renaming another .exe program to iguidanceumpc.exe, stuck that in the main iguidance directory, and when I launch the program, it is embedded properly into Centrafuse.
So could I request someone who has gotten their iG4 working with CF to go into c:/program files/inav/iguidance and send me their iguidanceumpc.exe file for me to test out? Maybe upload it on yousendit.com. Thanks in advance.
nobb is offline   Reply With Quote
Old 04-25-2008, 02:31 PM   #212
Phatsacks's Avatar
Phatsacks is an unknown quantity at this point
Has anyone gotten this plugin from post #199 working with 2.0?
Phatsacks is offline   Reply With Quote
Old 04-25-2008, 02:48 PM   #213
Nola111's Avatar
Nola111 is an unknown quantity at this point
No. And I haven't seen the author around in quite some time. David says the plugs will have to be recompiled for 2.0 Unless someone has the source for this one, or tracks down the guy who wrote it, we may be SOL for awhile.
Nola111 is offline   Reply With Quote
Old 04-25-2008, 03:11 PM   #214
Phatsacks's Avatar
That's...upsetting
Thanks for the confirmation.
Navigation is one of my more commonly used apps. I might have to downgrade now, so I can use IG4 =/
Old 04-27-2008, 09:59 PM   #215
mikess2k is an unknown quantity at this point
also interested in getting IG working with CF2
mikess2k is offline   Reply With Quote
Old 04-27-2008, 11:58 PM   #216
rgarjr's Avatar
rgarjr is an unknown quantity at this point
Could you guys not run iG4.0 using the add application?
My carpc worklog
rgarjr is offline   Reply With Quote
Old 05-20-2008, 02:38 AM   #217
Ogold007 is on a distinguished road
Has anyone been able to track the author down? I am currently using RoadRunner but am planning to switch to CF RC2, however that will change if I can't use iGuidance. Does anyone have the 2.0 compiled version? Better yet, does anyone have the source code so I could compile it myself and also update it for iG v4?
My Install - 2003 Lexus IS300
Ogold007 is offline   Reply With Quote
Old 05-20-2008, 07:48 AM   #218
f1anatic is an unknown quantity at this point
While I am still using the old 1.20 myself, the issue at stake here - as i understand it - is NOT that the plugin does not work with IG4 or with CF2 but rather the DEST button does not work. Something which I can confirm. However the TOP MENU button as well as the left lower panel MENU button from IG4 itself provide the shortcut to the destination. It really is about convenience.
If you had to use IG4 by itself, one would have to go that route tio input a destination. Not the end of the world but I agree someone should make it work.
f1anatic is offline   Reply With Quote
Old 05-20-2008, 10:27 AM   #219
I understand that. I can run iG4 in CF1.2 just fine but like you said, the dest button won't work. The problem is that CF RC2 is written in the .NET 2.0 runtime and there have been many changes to the plugin dll. Therefore, as I understand it, cfig needs to be recompiled in 2.0 with the new dll in order for it to work. Does anyone know if this is not correct? Can you still use iG4 in CF RC2 with cfig?
Old 05-20-2008, 10:28 AM   #220
WuNgUn's Avatar
WuNgUn is on a distinguished road
I'm using it...
Haven't tried the Dest button though...hang on...
WuNgUn is offline   Reply With Quote
Old 05-20-2008, 10:31 AM   #221
WuNgUn's Avatar
Nope...Dest button not working.
I tried + - zooming and it crashed CF...
Definetly needs work or a new plugin
Old 05-20-2008, 10:37 AM   #222
But you were able to installed cfig on RC2? When I even tried it, it said that no installation of CF could be found. How were you able to do that?
Old 05-20-2008, 05:29 PM   #223
well no apparently you guys are right. The plugin needs work done. I guess no upgrades for me anytime soon.
Old 07-26-2008, 04:03 PM   #224
Sprintereei is an unknown quantity at this point
new 2008 Dodge Sprinter help Starscan scantool
I know a lot about cars. I am learning about my new 2008 Dodge Sprinter with a Gas engine.
I need to interface audio and video and HD cameras into this van.
My main concern is, I also need to remove the speed limiter/governor. I am limited to 80mph.
I have looked at the Very expensive Starscan tools. http://millerspecialtools.spx.com/Featured.aspx?id=1408
I think it uses CAN or CAN2 protocols Which, I am not sure.
Does anyone have an affordable scanning tool or sofrwareI can buy to defeat the speed limiter/governor ?
This vehicle has a dedicated desktop Vista computer installed.
Also,
I need interfaces, To install a aftermarket HD/XM radio and GPS system, what interfaces do I need ?
Sprintereei@Gmail.com
Sprintereei is offline   Reply With Quote
Old 09-05-2008, 11:31 AM   #225
For anyone still monitoring this thread, I built my own version of an iGuidance plugin that is made specifically for CF 2.0.
Check it out:
http://forums.fluxmedia.net/plugin-d...ce-plugin.html
Traffic Plugin for Centrafuse? justintime CF Plugins 26 09-09-2006 10:09 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Sample C# Code For Centrafuse Plugin buurin CF Plugins 0 01-27-2006 06:10 PM
Embedding FM PLugin into CENTRAFUSE 1.1 camsgs3 DragonBTV's CarPC Plugins 1 01-16-2005 11:55 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
