Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 01-10-2007, 10:57 PM   #61
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
Quote: Originally Posted by marshes View Post
Alright, I was wondering if anyone had any insight on my new CFIG problem. With or without a GPS device connected Centrafuse opens iGuidance but does not reposition the screen to fit within centrafuse. Maximizing and shrinking it also does not work. Anyone else have/fix this problem?
Maybe a Fresh xp install will fix it...
dont re-install xp because of that..... could be CFiG
are any windows popping up while ig is loading?
anyone else having the same issue?
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Old 01-11-2007, 03:30 PM   #62
Cross_ is an unknown quantity at this point
Here's the language file for German. I saved it as unicode- hopefully that will preserve the non-English characters. I am sure there's a way to do that properly in XML but I don't know how.
Cross_ is offline   Reply With Quote
Old 01-11-2007, 06:15 PM   #63
marshes is an unknown quantity at this point
The only other thing to come up is the window of iG that says ok and that is only up for a flash, because it automatically goes away and iG opens with working gps connection. So I dont know what is wrong
marshes is offline   Reply With Quote
Old 01-12-2007, 09:59 AM   #64
alti's Avatar
are you talking about the warning window? try adding nowarning to the command line arguments in the setup and see if that helps (instead of letting cfig close the warning window)
also what hardware are you running (cpu and ram)
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-12-2007, 10:00 AM   #65
alti's Avatar
thanks you very much, I will add it to the install
I have a msi installer i will be putting up shortly and it will be available on the flux site as well.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-13-2007, 01:25 AM   #66
I have the same problems with nowarning, only the warning window does not flash up at all.
I am running it on an m10000 with 512 ram and bu-353 gps.
Old 01-13-2007, 12:02 PM   #67
alti's Avatar
anyone have it running successfully on a m1000? I dont have any epia hardware to test on.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-13-2007, 01:24 PM   #68
AngryMan's Avatar
AngryMan is on a distinguished road
I want to say, this Cfig thing is pretty sweet, thanks for all your hard work.
I have a problem not mentioned here so far,
first, while the nowarning command line works great, I get another little popup flyout thingy that has 5 buttons on it,
the speaker icon (for volume), the gps info button, the north/heading up button, gps disconnect/reconnect, and the full screen button.
this has its own little title bar, (blank) an X to close it, and it is floating over the menu buttons. is there a way to start iguidance without this stupid thing?
I hate having to close it every time I open ig.
second, I dont know what the score is, but the "MENU" button within CFIG does nothing. I click it. nothing. same for the dest button.
am I doing something wrong?
.______
/ '__|__\____ VW CarPC project
\(o)_____(o)/ Full Spead Ahead!
Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
www.summitadventuresystems.com
AngryMan is offline   Reply With Quote
Old 01-13-2007, 01:36 PM   #69
AngryMan's Avatar
one more thing,
my ignav window dowsnt look anything like yours.
what modification or iguidance are you using to get that?? I really like that bar accross the bottom of your ignav window with the speed, eta, etc on it.
.______
Old 01-13-2007, 03:37 PM   #70
m2x0p9x
Could someone write an autoit script that launches iguidance with the nowarning param and see if the plugin still crashes iguidance...could be a work around...
m2x0p9x is offline   Reply With Quote
Old 01-13-2007, 03:56 PM   #71
AngryMan's Avatar
ooh.... why am I the last to find out that Iguidance 3 is out... here I am trying to get CFiG working with 2.1.... no wonder it wont work.
.______
Old 01-14-2007, 10:06 AM   #72
alti's Avatar
what are you tring to work around? is it still not embedding with the new version? So far only one person (marshes) has reported having an issue with it with the new version. Are you having trouble as well?
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-14-2007, 10:12 AM   #73
alti's Avatar
I am not sure what window you are talking about here, my only guess is that it is one of the ig menus, did you do that modification to ig to try to remove the warning box that makes ig not remember any of the settings when you close it? if that is the case and you had that window open the last time it saved settings it might reopen it every time. It does not sound like it has anything to do with cfig though.
As you noted in your last post, I have version 3 running, the menu button does not work with version 2 (yet) I have been meaning to add this, but i have to find my old ig 2.0 and re-install it to test. The dest button does not work in version 2.0 either.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-14-2007, 12:41 PM   #74
AngryMan's Avatar
Alti, thanks for the response. I was using 2.1. now I have 3.0 and it looks much better. I love the new look and feel.
I still have tthe extra buttons in iguidance tho, and I hadnt made any mods to it other than the "nowarning" command line. regardless, my work around to hide those buttons was to change the Y offset and height of the app within cfig to:
Y Offset = -70
Height Offset = 89
looks great on my screen now
.______
Old 01-14-2007, 12:42 PM   #75
AngryMan's Avatar
actually, not sure if this makes any difference, but I am runnign my screen at 800x600. I never did get my screen to run 800x480 with the onboard video.
*shrug*
.______
Traffic Plugin for Centrafuse? justintime CF Plugins 26 09-09-2006 10:09 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Sample C# Code For Centrafuse Plugin buurin CF Plugins 0 01-27-2006 06:10 PM
Embedding FM PLugin into CENTRAFUSE 1.1 camsgs3 DragonBTV's CarPC Plugins 1 01-16-2005 11:55 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
