Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Plugins
Old 01-14-2007, 03:23 PM   #76
VENDOR - Centrafuse
veetid's Avatar
veetid is on a distinguished road
This is great work alti!! I can't wait to get this up on the site once you get all the bugs worked out...
again great work and email me if you have any questions, need any help, or need anything added to the SDK to help you finish the development of this plugin!
david
veetid is offline   Reply With Quote
Old 01-15-2007, 12:46 AM   #77
m2x0p9x
it embeds fine...i was just wondering if using an autoit script would fix the error with the nowarning param...
m2x0p9x is offline   Reply With Quote
Old 01-15-2007, 10:10 AM   #78
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
I am not aware of an error with the nowarning param.. are you getting one?
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline   Reply With Quote
Old 01-15-2007, 10:51 AM   #79
dudeness is an unknown quantity at this point
Is it possible to make iguidance 2.1.2 compatible? There are no europe maps for version 3 (
btw: From which year are the 2.1.2 maps?
dudeness is offline   Reply With Quote
Old 01-15-2007, 10:59 AM   #80
alti's Avatar
ya, should not be a problem. Going to start working on that now if the app is running stable.
I am not sure if there was different release dates for the versions for different locations. I think 2.1.3 was released in late 2005, please don't quote me on that.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-15-2007, 11:47 AM   #81
Ok, thanx
Old 01-15-2007, 02:08 PM   #82
hari-bhari can only hope to improve
i also have the issue with the menu showing up on the first launch....
hari-bhari is offline   Reply With Quote
Old 01-15-2007, 05:54 PM   #83
alti's Avatar
is it the main ig menu? (the one you get when pressing the cfig menu button?)
if someone could get a screen shot, that would be great...
are you also using 2.x like angryman?
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-15-2007, 11:06 PM   #84
nope its v3, and yes its the main menu.
Old 01-15-2007, 11:07 PM   #85
the parameter is working fine with me. make sure u don't put a hyphen or anything in front of it, simply 'nowarning'
Old 01-16-2007, 10:35 AM   #86
alti's Avatar
And if you open ig normally from windows does the main menu pop up then as well?
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-16-2007, 10:57 PM   #87
m2x0p9x
Im not using the version where is shows the screen flash when it opens...im using the version that took care of that but crashes every other time...anybody have an autoit script just to load iguidance with the no warning param..and then leave the nowarning out of the plugins xml...just wanted to try and see if it still crashes every other time...
Old 01-17-2007, 05:02 PM   #88
Paisan is on a distinguished road
Any way to get rid of the buttons generated for the iguidance menus? I rather use the pop-ups and have more screen space for the maps.
-mike
Paisan is offline   Reply With Quote
Old 01-17-2007, 07:24 PM   #89
alti's Avatar
-mike
sure just make your own skin, you could remove all the buttons altogether if you want. You can adjust where ig embeds using the second setup screen to fit your skin.
My Install
Software:
CFiG v1
CarShell
StopWatch
Old 01-17-2007, 07:31 PM   #90
alti's Avatar
the nowarning param should not be what is causing it crash. It has to do with ig being in a hidden state when CFiG is embedding it and ig trys to find the gps. I cant say for sure what is causing it because i cannot see the ig code, but my best guess is that it has something to do with ig redrawing the map to your current location once the gps returns coords... because the window is hidden it crashes at this point, this is why it worked if the gps was not attached or did not have a signal, the ig window was not redrawn while in a minimized / hiden state. (again my theory)
the only way to fix it was to run the program visible, hence the jumping around the screen. It should have nothing to do with the nowarning param, running the executiable from a script should not going to have any differnt affect.
however by all means go ahead and try and let me know if you are successfull. Then i know i can re-explore starting ig in a hidden state.
My Install
Software:
CFiG v1
CarShell
StopWatch
Traffic Plugin for Centrafuse? justintime CF Plugins 26 09-09-2006 10:09 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
Sample C# Code For Centrafuse Plugin buurin CF Plugins 0 01-27-2006 06:10 PM
Embedding FM PLugin into CENTRAFUSE 1.1 camsgs3 DragonBTV's CarPC Plugins 1 01-16-2005 11:55 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
