02-18-2007, 01:19 AM
#106
VENDOR - Centrafuse
This is a great project and I'm glad to see making progress...
As soon as it's ready for a version 1, let me know and I will put it for download on the Flux website, I can't wait!
Great Plugin!!!
david
02-19-2007, 08:55 PM
#107
toberdorf. I have the same problem with the X, but for me MENU is still the to. Maybe you can't see it because of your color. It's not as noticeable as the X
I also have the menu bar problem, but I just do a maximize and everything evens out. I think it's because I'm running 640x480 for resolution and my screen is scaling it to what should be 800x480 I think
02-19-2007, 10:49 PM
#108
for some reason today i was using UMPC in the car with the plugin and it kept freezing up, especially when I opened any menu. and the weird thing is whenever i would click something on the menu, CF would bounce back to the main menu and exit out of the plugin. anyone else having these issues?
03-04-2007, 12:19 AM
#109
could someone tell me how to install this plugin? i think im doing it wrong.
CF 1.10
I hit settings, + , plugin, i browse to where the extracted plugin is...
I highlight the folder, and press ok. ....
that takes me back to CF settings window...
I look for the item CFIG...
nothing there....
*puzzled*
~0okami.Digital
03-04-2007, 12:22 AM
#110
VENDOR - Centrafuse
CF 1.10
nothing there....
*puzzled*
just make sure the plugin is getting copied to the plugins folder.. Exit out of Centrafuse and see if the plugin is getting copied to the Centrafuse\Plugins folder...
If it is not, please post in the bugs thread and looks for an error.log file...
If it does, just reload Centrafuse... Otherwise just close Centrafuse and copy the folder manually to the Centrafuse\Plugins folder and then open Centrafuse...
If it shows under settings, then it's loading... so this all might be you just not assigning a button action to a button, such as replaceming the NAV button with this plugin... It is done under settings, "button layout"...
david
03-04-2007, 12:29 AM
#111
david
yup. it shows. Now what was that again about assigning a button action?
sounds like the missing link im in search for!
n/m... i found it. i should read your post completely before jumping into action.
Thanks!
~0okami.Digital
03-04-2007, 01:31 AM
#112
in cf go to settings -> button layout -> choose the button that you want -> choose CFiG
that should be all....
03-04-2007, 06:42 AM
#113
Brilliant! I am loving Centrafuse and the iGuidance skin... man I can't wait for it to be in my car haha... I've come to a conclusion that Front-Ends that are actually commercialized or soon-to-be commercialized are a much better eye candy
03-04-2007, 07:31 PM
#114
I've been messing around with the skin for CFIG, and took a look at the Nexus skin for it as well. I really like the nexus skin, but I was wondering if it would be possible to modify it so that I can change the track forward/back from the CFIG bar.
Does anyone know if I can change the actions of the buttons to do with via the xml file in the CFIG skin folder?
#115
Am I doing something wrong.
Cause mine wont embedded..
I can still see the "Main menu" in the back...
03-04-2007, 08:12 PM
#116
you can modify the CFiG skin button actions, but only to interface commands with ig that I have allowed for. (the ones currently availible on my skin)
so no, you cannot change the tracks from the cfig bar.
are you using the newest verison?
and if so can you give a bit more detail about your hardware and software...
Reason: Automerged Doublepost
03-05-2007, 10:15 AM
#117
Hi,
I was not using the latest version but the one from the first post.
I am now :-)
BUT
Now I do not se the "Main menu" but IGuidance puts it self. in the background , I can bring it up by multitasking, but it still do no embedded.
My system info:
MB: VIA EPIA MII 12000
RAM: 512 MB PC3200 Kingston
HDD: 120 GB 3,5" WD
PSU: Standard ATX
Monitor: my 19" wide LG - It will be a 7" motorised in dash in the car
Software: Windows XP SP2 Danish (not stripped or anything)
iGUIDANCE 2,12 Europe
Centrafuse (the latest fra www.fluxmedia.com)
03-05-2007, 10:23 AM
#118
I was not using the latest, but I am now. (used the one from post nr. 1)
It still do not embedded, but now the size of the Iguidance window is right, but it loads in the background and do not embedded I can bring it up by multitasking
My info:
Windows XP PRO SP2 Danish (full, not stripped or anything)
iGUIDANCE 2.12 Europe
Hardware:
Via MII 12000
120 GB 3.5" WD
Standard ATX PSU (for configuring only) M2 ATX when it's going in the car
SORRY Found the reason myself, it was because iGUIDANCE failed to find my GPS reciever and that caused it not to embedded
Reason: solved problem
03-09-2007, 07:37 PM
#119
I am also having the incorrect window size on cfig until I press the maximize button to maximize then minimize. On my desktop pc with basically the same settings the program opens perfectly....
Also for anyone that would like to not see the speed / distance to destination bar when in minimized mode but would like them visible in full screen I have attached the config and skin.xml settings.
In the Skin.xml make change the values to match below.
<CFIG>
<X>0</X>
<Y>84</Y>
<WIDTH>848</WIDTH>
<HEIGHT>325</HEIGHT>
<FULLX>0</FULLX>
<FULLY>0</FULLY>
<FULLWIDTH>848</FULLWIDTH>
<FULLHEIGHT>404</FULLHEIGHT>
<APPX>0</APPX>
<APPY>51</APPY>
<APPWIDTH>848</APPWIDTH>
<APPHEIGHT>308</APPHEIGHT>
<FULLAPPX>0</FULLAPPX>
<FULLAPPY>51</FULLAPPY>
<FULLAPPWIDTH>848</FULLAPPWIDTH>
<FULLAPPHEIGHT>355</FULLAPPHEIGHT>
Change the config.xml to these values
<APPCONFIG>
<SKIN>Onyx WS Night</SKIN>
<APPLANG>English</APPLANG>
<FULLSCREEN>false</FULLSCREEN>
<PATH>c:\Program Files\iNav\iGuidance\</PATH>
<ARGUMENTS>nowarning</ARGUMENTS>
<FILENAME>iGuidanceUMPC.EXE</FILENAME>
<XOFFSET>-2</XOFFSET>
<YOFFSET>-47</YOFFSET>
<WIDTHOFFSET>4</WIDTHOFFSET>
<HEIGHTOFFSET>66</HEIGHTOFFSET>
03-13-2007, 10:47 PM
#120
I have iGuidance installed and the plugin installed correctly yet when i bring it up in Centrafuse i see an empty white screen where the map should be.. The buttons also dont do anything other than maker a noise..
| Thread Tools |
| Display Modes |
Linear Mode
