The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF SDK
Thread Tools Display Modes
Old 09-04-2006, 11:12 AM   #1
My Photos: (5)
Password Handling
Hey David ... I have two quick questions about passwords:
1. Is there a pre-built control for password handling? Or will I have to mask input manually?
I am looking for the same functionality that is used when setting up a password for an internet connection.
2. Is there exposed functionality through the SDK to store passwords securely? Or must we encrypt and store the password ourselves?
JWise1203 is offline   Reply With Quote
Sponsored Links
Old 09-04-2006, 05:39 PM   #2
MySQL Error
veetid's Avatar
My Photos: (0)
The only two places I use passwords are with the dialup connections and the lock screen/settings password...
You are correct that I store these as clear text in XML... I will encyrpt them...
I will try to get that into the next release, but if not the next one... I just overlooked it... they should be encrypted
david
veetid is offline   Reply With Quote
Old 09-04-2006, 05:43 PM   #3
My Photos: (5)
Thanks for the info David. What about masking the password input (****) in the GUI?
Old 09-04-2006, 05:46 PM   #4
MySQL Error
veetid's Avatar
My Photos: (0)
Is it not masked? I thought I already did that... When you set the password under settings that is masked for you right? I might have missed masking it on the Internet setup screen...
What version are you running?
note: I just checked and it should be masked in RC2... not sure if I had that in RC1 yet...
david
Old 09-04-2006, 05:50 PM   #5
My Photos: (5)
The password masking is enabled for the two fields that you mentioned.
The question I have is if you made the masking available through the SDK. I will need to do this for a plug-in that I am developing. Basically have the masking work exactly as you have it setup now.
Old 09-04-2006, 05:58 PM   #6
MySQL Error
veetid's Avatar
My Photos: (0)
I see what you are saying... This should all just been done by you in your plugin, very basic stuff...
For example in setup when you are populating in readConfig just use something like this:
Code:
string hiddenpassword = ""; for(int i=0;i<readConfig("/APPCONFIG/DIALUPPASSWORD").Length;i++) hiddenpassword += "*"; this.CF_updateButtonText("BUTTON4", hiddenpassword);
Then when you go to save use something like:
Code:
osk myosk = new osk(LanguageReader.getText("APPLANG/SETUP/PASSWORDTEXT"), ((CFControls.skinButton)buttonArray[CF_getButtonID("BUTTON4")]).Text, true); myosk.MainForm = this.MainForm; if(myosk.ShowDialog() == DialogResult.OK) { string hiddenpassword = ""; for(int i=0;i<myosk.resultData.Length;i++) hiddenpassword += "*"; this.CF_updateButtonText("BUTTON4", hiddenpassword); updateConfig("/APPCONFIG/DIALUPPASSWORD", myosk.resultData); } myosk.Close();
Notice updateConfig writes the real password to to the XML file, this is just a function that updates the XML node and then if you hit save, it saves the file, you hit cancel no changes are made...
This is where I could encrypt the password, at updateConfig... Then when you load up your plugin and read the config unencrypt there...
NOTE: The biggest thing to note is the true parameter on the end of the OSK dialog creation... This tells the OSK to auto mask for you... This might have been all you were asking for the whole time, this is handled for you in the dialog... With intellisense you can seet he parameters on the OSK and the numberpad...
david
david
Old 09-04-2006, 06:09 PM   #7
My Photos: (5)
Code:
Code:
david
david
Perfect! Thanks David.
Old 09-30-2006, 08:47 PM   #8
My Photos: (5)
Code:
Code:
david
david
David,
I am getting around to implementing this code and am having a prolem creating the OSK; at this line:
I can't find an osk class anywhere in the documentation. Am I missing something?
Currently I am displaying the OSK this way:
this.CF_systemDisplayDialog(CF_Dialogs.OSK, this.pluginLang.readPluginField("/APPLANG/SETUP/BUTTON3TEXT"), this.CF_getButtonText("BUTTON3"), out resultvalue, out resulttext)
Old 10-01-2006, 06:08 PM   #9
MySQL Error
veetid's Avatar
My Photos: (0)
David,
Those are the internal functions, I pasted my code straight from the internal project, not a plugin run from the SDK, for an example...
I actually don't have a way to call the OSK in password mode currently from the SDK, I will add this as a parameter...
david
Old 06-02-2007, 09:27 AM   #10
smeesseman's CarPC Specs
smeesseman's Avatar
Vehicle: http://www.fluxmedia.net/
My Photos: (0)
david
Any chance this has been done by now David? I too am looking for the password mode for the OSK...
EDIT:
For anyone still looking for this info in the future...
Can be done with sending string "PASSWORD" as the second parameter to the
CF_systemDisplayDialog() function...
i.e.
.OSK, "text", "text", "PASSWORD", out resultvalue, out resulttext)
smeesseman is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Coding a touchscreen password program can ctrl-alt-del be disabled? alti Software & Software Development 21 06-27-2005 07:49 AM
Password for Centrafuse? justintime Centrafuse 8 06-15-2005 04:11 AM
Kenwood password problem five_to_one Car Audio 3 05-18-2005 10:34 PM
Excel 2000 password recovery wizardPC Off Topic 2 03-07-2005 02:48 PM
Cleared Password and now it pops a dialog box every time i go into setup antimatter FrodoPlayer 3 08-02-2004 09:18 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
