Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Centrafuse > CF Skins
Old 07-01-2008, 09:40 PM   #1
Aura For 1.20?
Trying to get the Aura skin to work with 1.20...when using the Aura skin file everything lines up but any button with text doesnt work also the text does not show and the icons do not refresh when pressed...when using the skin file for onyx everything works but alot of things do not line up correctly...anyone got this working...trying to avoid going threw the xml to edit..
m2x0p9x is offline   Reply With Quote
Old 07-03-2008, 12:24 PM   #2
Well went ahead and edited the 1.2 XML to work with the Aura skin...works just fine...if anyone else is using 1.2 and would like the XML...post or pm..
Old 07-18-2008, 09:01 AM   #3
If you don't mind, I'd like to get that xml.
Do you know of any other skins that work nicely with 1.2? I haven't had much luck with skins in 1.2 presumingly because of xml differences between the different versions and custom skins.
lukec is offline   Reply With Quote
Old 07-18-2008, 06:47 PM   #4
check your pm
Old 07-23-2008, 01:54 PM   #5
Quote: Originally Posted by m2x0p9x View Post
check your pm
I'd like it too! could you tell us if there was anything else that you did which was special? I mean, anything else to edit?
mshale is offline   Reply With Quote
Old 07-23-2008, 05:27 PM   #6
should have just done this in the first place..haha...nothing special for the old aura skin...rename skin.txt to skin.xml...mp3car doesnt see xml files...and replace the xml with the one attatched...
Old 07-28-2008, 08:53 PM   #7
rEegLer's Avatar
awesome! Thanks!
Love
www.rEegLer.com
rEegLer is offline   Reply With Quote
Aura skin to be modified... Hammerhand CF Skins 6 12-20-2007 09:11 AM
simple orange aura twist... turbocad6 CF Skins 4 11-04-2007 01:24 PM
FS: D3, microATX mobo, mobile Athlon, 5" LCD, hauppauge nexus, aura interactors. kai445 Classified Archive 2 04-16-2004 04:04 PM
