01-13-2007, 12:05 PM
#1
Vehicle: 06' Audi A3 2.0 TDI Exclusive Line 170HP
New Media disposition purpose
Here is what i would suggest in order to increase visual size.
What do you think about?
Reason: Last UPDATE : 23 march 2007
01-14-2007, 11:09 AM
#2
Files
Joined files only for test this dispostion of button and Viz size.
1) Make a copy of Night Skin
2) Rename the folder like you want. (like "Onyx WS Night BigViz")
3) Replace the old .png and .xml files by the ones given.
FixedSkin2.zip for old versions
skins_CF_1.2.zip for 1.2 version
[Thanks to Duranike for Skin edition and skin fix]
02-12-2007, 04:55 PM
#3
I like the look of it. I've always thought the album art display window was too small and I'm not keen on switching between full screen mode "on the fly"
02-19-2007, 03:37 PM
#4
I have got it now in my car and i find it really better look.
03-03-2007, 07:03 PM
#5
I have corrected some mistake i made in .xml file.
03-21-2007, 06:14 PM
#6
do you have any updated graphics? do you want me to make some?
also can you explain further why the two picture files are the same?
Great work man
03-22-2007, 01:56 AM
#7
hi duranike,
as you can see my work is MS PAINT maid
it would be kind of you if you could improve it. perhaps you have a better skin solution to increase the Viz screen size.
Sorry but could you explain the probleme?
03-23-2007, 12:39 AM
#8
actually i think i might. If i make the graphics can you help/explain/point me in the right direction on how to code it? Im a desinger and a coder, but im new to centrafuse, so i dont know the details of editing the skin.
03-23-2007, 10:47 AM
#9
nevermind i figured it out. ill have two new versions of this soon.
03-23-2007, 11:30 AM
#10
Got it
ok attached is a zip with two variations of the mod stated above.
I didnt do much but retouch the graphics so they look better.
Two folders in the zip; Left and Right
Left, is the one im going to use so the skin.xml buttons are perfect!
Basically i took the ideas above and just put the buttons in the order of up, down, favs, and then the normal order of library and so on.
Right, the xml in the file is the same xml file in the zip above.
If your a perfectionist, then you should tweak the button hit areas a little since my graphics are slighty different then the one the xml was intended for. Basically the buttons are the same as the image above.
Hope that makes sense.
*****Now i mentioned in another post, but i guess this page/section of centrfuse (the music player) shares setting with the media art picture viewer. So im not sure if that can be different setting. If no, ill make another graphic for picture/slideshow. If yes, i wouldnt mine keeping the slideshow image the same.
J
03-23-2007, 06:20 PM
#11
Wow,
Thank you Duranike,
Have you got the .PSD files???
Your skin looks very better.
The left one fits me well!
Thank you.
03-23-2007, 07:37 PM
#12
FixedSkin2=FixedSkin from Duranike + "skin.xml" file fix.
Post #1 updated screenshot with FixedSkin2
Post #2 updated download with FixedSkin2 ("skin.xml" fixed for both "Left" and "Right" edition).
04-06-2007, 11:00 AM
#13
Vehicle: 2002 VW Jetta 1.8T
I played around a little with the media screen and came up with this. I've finished the day skin and I'm now working on the night.
06-23-2007, 07:29 AM
#14
Post 2 updated with "skins_CF_1.2.zip" for 1.2 version
06-28-2007, 11:56 AM
#15
Great mod, thanks
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
