It is a GPS receiver module with an attached patch antenna. It can be powered via USB 5v and sends the standard NMEA protocol.
Size :
Small PCB form factor – 45 mm x 45 mm x 9.7 mm
Weight:
18 Grams
Operating Tempeture:
-40c..+85c
Built in Antenna:
25mm patch antenna element
Center frequency 1578
Protocol:
Propriety Italk binary protocol
NMEA-0183 V3.0
Power Supply (can be supplied via USB):
+2.7V..+7V (Recomended +3V)
Current Drain:
50 Ma typical
These units are not available through retail but I have a chance to order extras through the company I work at for my own uses. The units I receive will not come with any serial connection so I will need to attach a USB connection to make them PC compatible. They will be compatible with any software using the NMEA protocol. The assembled unit will be the GPS module with an attached USB dongle but no protective case.
The price should be $140.00 USD or under. I don't know how much interest this will generate. I would like to find a minimum of 10 people willing to put down a deposit of $25 USD before I put in another order. I will try to answer any questions you have. I will be checking for replies and can be reached at my email:
Minus@shaw.ca (I am located on Vancouver Island, BC, Canada)
