Anyone want a Mastero Mk3.5 PSU kit?
I purchased it to power an ATX Car PC but then went the Epia route instead and so this is surplus to requirements.
It comes with the complete kit of parts and an old ATX PSU so you can install the finished PSU into it's case.
You might need additional heat sinks/insulators etc but all the components should be there. You will also need to be neat and tidy with a soldering iron. All the specs can be found at
http://www.mastero.tk/
I can take PayPal so PM me your best offer incluidng shipping (weighs about 5lb with the ATX PSU - less if you don't need it).
Steve
SPECIFICATION
Mk- 3.5 ATX DC-DC Power Supply.
INPUT: 7vdc ~ 30vdc
OUTPUT:
VOLT AMP (MAX)
+ 3.3vdc 6A
+ 5vdc 12A (Shared)
+ 12vdc 4.5A
- 5vdc 500MA
- 12vdc 500MA
+ 5v stby 5A
This power supply is specifically designed for use in automobiles.
Having a low input range this PSU can survive the engine crank without restarting your PC.
Fits Perfectly in an A/C ATX psu case. Assembly required.
