Go Back   MP3Car.com > General > Classifieds > Classified Archive
Old 09-07-2005, 12:28 AM   #1
PitchBlack98's Avatar
PitchBlack98 is on a distinguished road
WTB: lilliput ribbon cable. (opposite facing pins)
I broke my cable and digitalww doesnt have the opposite facing pins in stock right now. If anyone has one let me know and Ill take it off your hands.
The end of the Internet offically begins here...
www.broke-off.com
PitchBlack98 is offline
Old 09-07-2005, 12:31 AM   #2
Raw Wave
EsKALad's Avatar
EsKALad is on a distinguished road
which cable? the cable from the vga board to screen or the one that goes from the vga boardto the controller board for the buttons?
EsKALad is offline
Old 09-07-2005, 12:43 AM   #3
I guess I should of mentioned that... lol I need the one from the LCD to controller.
www.broke-off.com
Old 09-07-2005, 11:05 PM   #4
anyone?
www.broke-off.com
Old 09-08-2005, 07:38 AM   #5
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
You know you can order them from digitalww?
肚子笑痛了
S60 Install
jcdillin is offline
Old 09-08-2005, 09:20 AM   #6
yes I know I can order them from there. Only problem is they dont have the opposite side pins in stock. I went ahead and ordered the 300mm one last night and Ill just twist it for the time being. Thanks though.
www.broke-off.com
Old 09-08-2005, 10:54 AM   #7
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
I've attempted that and its not gonna work. And Digitalww never has those in stock anymore. I waited months before i was lucky enough to find a member with one.
Sonicxtacy02 is offline
Old 09-08-2005, 11:03 AM   #8
Rundell's Avatar
Rundell is on a distinguished road
Yeah when you twist it the pins are going to be backwards so it won't work. Basicly pin 1 will be connected to like pin 20 and so forth
Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
GET PAID TO SURF THE INTERNET
Rundell is offline
Old 09-08-2005, 11:05 AM   #9
Rundell's Avatar
Just realized I was the one that sent that one to you! Glad it worked!
Rundell is offline
Old 09-08-2005, 02:19 PM   #10
I thought about that. I think I may be able to get around it. Ill have to mess with it when it gets here. I did some soldering on the board and want to rule out the ribbon cable before I check the controller board. Right now I get a white screen and the buttons still work. I can turn it on and off and volume up and down.
www.broke-off.com
Old 09-08-2005, 02:26 PM   #11
studmonk3y's Avatar
studmonk3y is on a distinguished road
yea man if you have a white screen it most definately is your ribbon cable.
studmonk3y is offline
Old 09-08-2005, 11:16 PM   #12
well it looks like Im screwed... I cant find a cable anywhere that has the pins on the opposite side. My only option is to try to solder 2 cables together to make them opposite pins or buy a new screen...
www.broke-off.com
Old 09-09-2005, 01:24 PM   #13
parvo99 is on a distinguished road
PitchBlack,
you can carefully peel back the insulation and make the same side pin into an opposite side cable. Just peel it back until there's plenty of pin showing, then cut it straight across so that there's about 1/4 inch of exposed pins showing. Then just peel off the blue pastic end piece, and reglue it to the new end. If that's all confusing, I'll take pictures tonight to show you how I did it.
parvo99 is offline
Old 09-09-2005, 03:09 PM   #14
I tried stripping my old cable by cutting off the bad part and stripping from there, but I still can't get it to work. Im waiting for the longer cable I ordered from Digitalww to get here. Im going to try and fold the contacts on one side over backwards and remove the plastic piece on the end to make it opposite side contacts. That way the pins are still in the same place and folding it over will make it thick enough to stay in. Hopefully it wont break the contacts.
In the mean time Im talking to someone at digikey. Hes trying to locate a cable for me. He also said they can have them custom made. So I may order a bunch of them to have a few on hand and also to sell to others that are looking for them.
www.broke-off.com
Old 09-12-2005, 09:24 AM   #15
Im still looking for one of these if someone has an extra or a busted screen...
www.broke-off.com
WTB; Lilliput Breakout Cable 629 Model lax4321 Classified Archive 4 08-22-2006 01:45 AM
Lilliput 9pin mini-din USB VGA cable Pale Rider LCD/Display 20 10-28-2005 01:54 PM
Lilly Ribbon Cable Extension Willow LCD/Display 3 07-07-2005 04:51 PM
WTB: Lilliput A/V Cable NEW style! djtrickee Classified Archive 6 06-22-2005 10:19 PM
lilliput ribbon Mush LCD/Display 4 02-28-2005 02:10 AM
