Okay, first here is the hardware I have (or have ordered and is being shipped to me):
1) ipaq desktop pc from this thread (not atx):
http://www.mp3car.com/vbulletin/classified-archive/59760-fs-compaq-ipaq-desktop-sff-pc.html
2) 7" lilliput mounted on IH002 motorized housing:
http://www.digitalww.com/IH002.htm
3) power inverter (300w continuous, 500w peak) - might need a new one (donno if this one is a sine one, or if it'll be sufficient?)
4) 10" usb male to female extension cable
5) 10" vga extension cable
basically here's the things that need to be done:
1) there's 2 din slots available in my car, currently with radio on top and cd player on bottom.. gotta open dash, pull out cd player, move radio to bottom, and install motorized lcd in-dash in top din
2) install computer in the trunk.. bolt it down somehow for security
3) install USB hub in glove box, allow wires to run to it unobtrusively somehow (up to gps on dash, over to touchscreen monitor in din, up to USB IR receiver on dash, etc)
4) run extension cables from dash to trunk (vga extension cable for monitor to pc and usb extension cable for pc to hub)
5) run wires from battery to inverter (which will be in the trunk with the pc to avoid noise in the front), which the comp will be plugged in to. put a fuse on the + lead within a few inches of the battery.
6) Run regular extension cord from inverter to power strip in glovebox (to power usb hub, monitor, etc)
7) according to someone who had the same computer, the power button of the computer is soldered directly to the motherboard, so the connections on the motherboard will need to be resoldered for a remote start
8) a dashwerks dssc controller will need to be installed that will control the inverter and pc at the same time so when i turn on my car the inverter and pc turn on (and vice versa when I turn the car off)
9) the whole things gotta withstand engine crank..
10) hooking up carputer's audio (integrated on the motherboard) with the stock stereo system.. the problem: no aux in = will take a bit more work (luckily there's tons of these tutorials available for ipod owners)
Any steps or thing I'm forgetting?
..so I still need parts for:
1) bolting down the PC (step 2).. not sure what this will require yet?
2) dashworks dssc controller
3) wires for step 5? .. not sure what is needed?
4) extension cord for step 6
5) long audio cable(s) for step 10 . not sure what is needed? (likely depends on how the install of step 10 is done)
Anything else that I need to complete the above steps? Thoughts?
Only reason I haven't ordered all of the above is because I'm not sure what exactly is needed, aside from the dssc controller, and I'm waiting on that to see if there's a better way (looking like not, as it's not an atx mobo = no opius, carpc ez, etc) - (and #4 the extension cord cause I haven’t bothered to go to a home depot or wal mart and grab a regular extension cord yet).. thoughts would be appreciated.
I'll post this in he newbie forum if I actuallly convince myself I can do this (what I originally though when I ordered a regular CD, then I realized I couldn't even do the fabriction so I got the motorized.. then I realized I prolly couldn't even do that and would need serious help with this, so I made this post). :P
-arebelspy
