The motherboard is the Aopen i855GMEm-LFS Pentium M Micro Atx, im also including a Pentium M 1.4ghz chip with it. Everything is in perfect working condition, im selling cause i dont have any use for it and need some money. I lost the I/O shield and the cpu fan shipped with the mobo cause i never used it, but i will be including a low profile cpu cooler which im currently using with the mobo. The fan works just as good as the original fan except for being a little louder, but its a lot smaller in height. The mobo also works perfect with an opus 150, i was able to leave my system in standby for days without any effects on the battery.
Product Specs
I'm asking for $185 shipped for the mobo and cpu. No trades please
System screenshot
Features:
Supports Intel Pentium M CPU (Dothan / Banias)
400MHz FSB
Supports up to 2GB of DDR RAM
Onboard Audio
MATX Form Factor
On board 10/100/1000Mb LAN
Specifications
Motherboard Specifications
Motherboard Model AOpen I855GMEm-LFS
CPU Socket Type Socket 479
CPU's Supported Supports Intel Pentium M CPU (Dothan / Banias)
Front Side Bus 400MHz FSB
Chipset Intel 855GME
Intel ICH4-M
Form Factor Micro-ATX
SATA Supports 2 ports SATA 150
On Board Sound Realtek AC'97 CODEC on-board
5.1 Channel
Memory Features
Dimm Banks 2
Ram Type Supported DDR333 [PC2700]
Maximum Ram 2 GB
External Connectors
PS/2 Keyboard x 1
PS/2 Mouse x 1
USB Port x 4
LAN Port x 2
VGA Port x 1
COM Port x 1
Printer Port x 1
Speaker_Out x 1
Line_In x 1
MIC_In x 1
Internal Connectors
Floppy Drive Connector x 1
IDE Channel : ATA100 x 2
Serial ATA Channel x 2
Front Panel x 1
CPU FAN x 1
System FAN x 1
Chassis FAN x 1
Power Temperature Connector x 1
AUX_IN x 1
CD_IN x 1
S/PDIF x 1
COM2 x 1
IEEE 1394 x 2
USB Port x 2
Expansion Slots
AGP Integrated VGA Engine in chipset
4X AGP slot
Plug & Play PCI PCI x 3
Dimm Banks 2 x
Other Features
Features Easy Installation Guide x 1
Enhanced Full Pictured Manual x 1
Bonus Pack CD disc x 1
Promise Serial ATA Driver Diskette x 1
Floppy Disk cable x 1
80-wire IDE cable x 1
Serial ATA cable x 1
Serial ATA Power cable x 1
Back Panel I/O Shield x 1
CPU Retention Module x 1
