Go Back   MP3Car.com > General > Classifieds > Classified Archive
Old 03-28-2006, 12:25 AM   #211
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
Mark, just wanted to thank you for making this hardware availible to the mp3car community, I missed this thread at the start but I have ordered 2 od the b/w units from motorcity. These cameras should make for awesome night vision projects.
Do you still have the 2.5" lcds and ir lights availible? Also are you selling any of the color ccds?
I would be interested in a few of the lcds w/ controller boards and a bunch or the ir leds.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline
Old 03-28-2006, 12:46 AM   #212
NiteMax Mark's Avatar
NiteMax Mark is on a distinguished road
Thanks! It's been more work than eBay serving all of you folks -- but it has been more fun too!
Here's the scoop...
I've got dozens of some NiteMax parts and hundreds of others! The only thing I really don't have is the internal Power Supply Board. The function of this board is well understood and it can be easily replaced if you have a source of 12v DC power. Seriously: Anyone who's half technical can build themselves a Night Vision system -- I can provide the technical details and forum members can provide experience!
If I were smart, I'd make a menu with all of the parts and all of the prices. For now, we'll need to figure out what your needs are and I'll do everything I can to meet those needs with the parts I have.
Color LCDs with the Controller Board are pictured somewhere here. They're $25 for the first pair and $10 each after that. IR LED Arrays are 3 for $1. I also have Color CCDs that you can mount in your NiteMax for $15 each. HOWEVER, I have incomplete NiteMax cameras that are missing the Power Supply Board inside. I've been selling these incomplete ones for $20 each which gets you the CCD and the LCD together for not much more than the price of just one of the items inside.
NiteMax Mark is offline
Old 03-28-2006, 09:37 AM   #213
alti's Avatar
I am going to wait till the cameras i ordered get to me and i play with them alittle more, I am still planning out how the system is going to work, and what, exactly, i am going to need.
I will PM you when i know. Thanks again.
My Install
Software:
CFiG v1
CarShell
StopWatch
alti is offline
Old 03-29-2006, 03:10 PM   #214
Fusion-One's Avatar
Fusion-One is on a distinguished road
Quote: Originally Posted by NiteMax Mark
The lens looks perfect.
Should we start a new NiteMax LCD Thread?
- Apply 12v DC on JP1 Pin 11
- Attach Ground to JP1 Pin 9
- On the pads near JP1, connect a 5k Ohm potentiometer between the "5v" pad and the "Gnd" Pad. Connect the center (wiper) pin of the potentiometer to the "Brt" pad.
- Feed the video signal in on JP1 Pin 5
Here's the LCD Controller Board...
Pin Name... I/O Pin Description...................... Remark
1.. /Hsync. .O. Horizontal Sync...................... Output for specific Application.
2.. /Vsync. .O. Vertical Sync........................ Output for specific Application.
3.. NPC.... I/O NTSC/PAL mode selection.............. Note 1
4.. SW..... .I. Composite/Analog RGB Signal Selection Note 2
5.. CVS.... .I. Composite Video Signal Input.........
6.. Bin.... .I. Separated Blue Video Signal Input....
7.. Rin.... .I. Separated Red Video Signal Input.....
8.. Gin.... .I. Separated Green Video Signal Input...
9.. GND.... .-. Ground...............................
10. GNDS... .-. Ground...............................
11. Vin.... .I. 12 Voltage DC Input..................
12. GNDS... .-. Ground...............................
13. COL.... .I. Color terminal adjustment............
14. LR..... .I. Left/Right scan selection............ Note 3
15. UD..... .I. Up/Down scan selection............... Note 4
Note 1: Default is auto detect for NTSC or PAL system.(Controlled by internal UPS015) High for NTSC mode and Low for PAL mode.
Note 2: Default is Composite Signal (Low); High is for seperate Analog RGB signals.
Note 3: Default is reversed scanning (High) and Low is for normal scanning (L —›R).
Note 4: Default is reversed scanning (High) and Low is for normal scanning (U —›D).
When it says (High) and (Low) does it mean open or connected to ground?
High = No connection or Connected to 12v???
Low = Connected to ground?
Thanks for the clarification!
-Jared
Fusion-One is offline
Old 03-29-2006, 03:30 PM   #215
Fusion-One's Avatar
Eeee.. Someone answer. I have the screen all wired up for VGA input, I just need to know if tying pin 4 to 12v like I'm thinking is the right thing to do. Let me know, someone!
Old 03-29-2006, 03:47 PM   #216
My gut feeling is that tying any of those to +12v would be bad! I think they are digital inputs and expect +5v for "high".
I'll need to confirm this, but I think the board has pull-up resistors so that leaving it disconnected will cause it to go "high" automatically.
Connecting the pin to Ground to pull it low for sure -- this part I can say for sure.
If you get this thing working with VGA using the timings I talked about, you'll be my hero. I've got you covered if you kill your LCD in the process!
Old 03-29-2006, 04:01 PM   #217
Fusion-One's Avatar
Hmm.. Pin 4 is actually not connected by default... so that must default to low. I think you're right on 12v making it unhappy. I'll try 5v.
Something that might interest you.. I tried lowering my supply voltage from 12.. 11.. 10.. 9. 8.7.6.5! The lcd runs all the way down to 5v without any apparent change in function. I haven't checked the specs on this, so please kids.. Don't try this at home. (I'm still using 12v as just to be safe) but its interesting that the screen seems happy with whatever you give it.. (probably by design since its intended for a battery powered device)
Also, Mark. I'm so happy with the package you sent me. . These LCDs are PERFECT.
Old 03-29-2006, 04:06 PM   #218
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
Normally a pin is connected to VSS or ground either externally or internally. Otherwise the value can "float".
shotgunefx is offline
Old 03-29-2006, 04:10 PM   #219
Fusion-One's Avatar
From noise on the line? I think its tied to ground by default, how would vss affect that...? Eek, even though I've got Mark behind me on this, I'm still worried about hurting it.
Old 03-29-2006, 04:21 PM   #220
Raw Wave
shotgunefx's Avatar
I don't know if it's noise so much or just how the transistors work. And when I said VSS, I meant to say VCC.
VSS = ground
VCC = + input voltage (usually)
Old 03-29-2006, 04:35 PM   #221
Fusion-One's Avatar
I saw VSS and thought V+ :P
Well, What I have seems promising.. I left the pin unconnected, and started playing with timings.. the screen is responding to my changes, so I'm assuming that it auto detected the VGA signal.
Right now I have fast scrolling lines. Playing with refresh rates as we speak.
Old 03-29-2006, 04:39 PM   #222
dmurray14 is on a distinguished road
Mark,
I may be interested in the incomplete NiteMaxx at some point...this thing is just too cool to rip apart, even though it had been my intention. Speaking of which - do you have any batteries/chargers?
Thanks,
Dan
dmurray14 is offline
Old 03-29-2006, 05:19 PM   #223
Genesisfactor is on a distinguished road
hehe, you see, that was my problem! I was like,"..but...but i want it...like it is...and i want it in my car...mark...i need another camera!" Thank god for parts and what not. If not, then i'd sit there and be like, "but I don't want to hurt them...they're so cooooollll...."
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline
Old 03-29-2006, 05:33 PM   #224
Fusion-One's Avatar
VGA SIGNAL ON THE NITEMAX: (Well, getting close. )
Old 03-29-2006, 05:49 PM   #225
Did you know that I have datasheets available here...
NiteMax Datasheet Collection
(Please don't let my ISP kill me for excessive bandwidth usage when everyone downloads them...)
There's a datasheet for the LCD Controller. It really wants 12v DC.
If you're powering the NiteMax through its own Power Supply Board, it'll boost your input voltage up to 12v DC. Based on your comments and the LCD Controller requirements, I'm guessing that this is what you're doing.
BMW E30 install with night vision tekta Show off your project 24 07-01-2006 03:41 PM
Digital Still Camera as video feed (i.e. for reverse camera, etc) meatwad General Hardware Discussion 2 01-26-2005 06:50 PM
low light night vision camera USB Tred General Hardware Discussion 8 01-05-2005 04:27 PM
Is non-IR rearview camera visible at night with reverse lights on? hd54321 General Hardware Discussion 6 07-23-2004 04:21 PM
Cheap camera with night vision mxxxxxm General Hardware Discussion 6 06-04-2003 12:55 AM
