Go Back   MP3Car.com > General > Classifieds > Classified Archive
Old 03-29-2006, 05:52 PM   #226
turner brown is on a distinguished road
This is a better 2x magnification lens that works very good. However, an adjustment with a small screw driver is necessary to make it fit the NiteMax...
Better Lens: http://cgi.ebay.com/16MM-CCTV-Camera...QQcmdZViewItem
any details on the adjustment needed to this lens
would like to know before i buy one
turner brown is offline
Old 03-29-2006, 06:00 PM   #227
Fusion-One's Avatar
Fusion-One is on a distinguished road
Actually, I'm talking just strictly LCD panels.. I saw in the datasheet that it requires 12v, and that is what I'm using.. just thought I'd mention that it seems happy with other voltages. (Very common for portable electronics)
Also, I thought it was responding to my input without pin4 being tied, but it wasn't.. I have it tied to 12v now, and its displaying image (like you see above) however I'm having trouble getting it to display properly.. an odd thing is that pressing the GAIN button on the LCD actually causes the image to stabilize on the vertical axis
Fusion-One is offline
Old 03-29-2006, 06:07 PM   #228
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
what is the refresh rate set to?
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline
Old 03-29-2006, 06:49 PM   #229
Fusion-One's Avatar
I was using the ole' PSONE timings.. but I just realized the two pins I Was trying to cram H/V sync into are actually outputs.
So, I connected the H sync pin from the VGA connection to the composite sync input...
The result is an image which is PERFECTLY stabilized horizontally.. it looks terrific... the only problem is, it slowly scrolls vertically =\
This is the screen running at 640x480@60hz (no special timings).. now if I can just figure out how to get it to stop slowly rolling. :P
Old 03-29-2006, 07:57 PM   #230
NiteMax Mark's Avatar
NiteMax Mark is on a distinguished road
You're AMAZING!
Try feeding the Green signal in the Composite Sync Input. (Sometimes there's sync info on Green or another color.)
If that fails, you could put a Current-Limiting Resistor in series with both the HSYNC and VSYNC from your VGA output and tie them together at the Composite Sync Input. (Maybe 1k Ohm or 10k Ohm would work.) The two signals will be protected from each other and the Composite Sync might "see" enough of both to make it work.
NiteMax Mark is offline
Old 03-29-2006, 08:30 PM   #231
Fusion-One's Avatar
I've tried all sorts of custom timings, but it doesn't seem to make any difference. Something very strange is that my geforce 6600 doesnt have the csync or sync on green options in powerstrip.. Very odd.
I think the csync circuit by MatrixPC is the best bet:
Old 03-29-2006, 09:16 PM   #232
What polarity is the HSYNC and VSYNC you've got?
Old 03-29-2006, 09:30 PM   #233
spaceskater's Avatar
spaceskater is on a distinguished road
This is getting VERY interesting! I wish I could help but I have very little knowledge on VGA signaling...
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline
Old 03-29-2006, 10:17 PM   #234
Genesisfactor is on a distinguished road
fusion...you never fail to impress me
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline
Old 03-29-2006, 10:35 PM   #235
In the picture there's a silver post for locking the focus in one place. Adjacent to this post are two black phillips-head screws that are flush with the lens body. (One is barely visible.)
The outer portion of the lens is screwed in and out to focus. Internally, there's a stop that keeps you from unscrewing the lens completely!
The problem I saw was some of the lenses would reach this internal stop before perfect focus could be achieved with some of the cameras.
It turns out that the two black screws could be backed out almost all the way and this would remove the stop. All I had to do was lift up the screws far enough to let the stop mechanism pass by and then re-tighten them once I had turned it past. The effect was that I re-calibrated the lens by adding one turn worth of adjustment at one end of the focus range at the expense of one turn at the other end of the range.
After discovering this feature of these lenses, I really liked them.
Old 03-29-2006, 11:09 PM   #236
dmurray14 is on a distinguished road
Quote: Originally Posted by dmurray14
Mark,
I may be interested in the incomplete NiteMaxx at some point...this thing is just too cool to rip apart, even though it had been my intention. Speaking of which - do you have any batteries/chargers?
Thanks,
Dan
Mark - any chance you have any batteries/chargers?
dmurray14 is offline
Old 03-29-2006, 11:23 PM   #237
Chargers -- a ton of 'em. Batteries... NO.
Recommended Batteries
If someone wants to collect together a list of people wanting a battery and a charger...
I'll do a bulk purchase, add the charger for nothing and ship them to you for cost.
I'll do the same for lenses if they are all included in the same package.
If someone wants to organize a list, I'll make the group buy as long as there is a minimum of 10 batteries and 10 lenses. (The hard part will be getting everyone to agree on lenses!)
With luck, we'll be able to get these three items to you from three sources for the cost of shipping from only one source. Plan on $12 or so for the battery, $10 or so for the lens and the charger. Shipping is probably less than $6 but I'll try to get it lower if I can.
Anyone want to organize the list?
Old 03-29-2006, 11:30 PM   #238
Fusion Brain Creator
greenman100 is on a distinguished road
I'll keep the list running, though I dunno if I need one yet.
greenman100 is offline
Old 03-30-2006, 12:37 AM   #239
dtran01 is on a distinguished road
Okay i'm in for a lens! how about lowest F you can get (1.2?) and your typical 4mm?
dtran01 is offline
Old 03-30-2006, 12:42 AM   #240
NiteMaxx Accessories Master List
Lens
dtran01
Battery
Charger
BMW E30 install with night vision tekta Show off your project 24 07-01-2006 03:41 PM
Digital Still Camera as video feed (i.e. for reverse camera, etc) meatwad General Hardware Discussion 2 01-26-2005 06:50 PM
low light night vision camera USB Tred General Hardware Discussion 8 01-05-2005 04:27 PM
Is non-IR rearview camera visible at night with reverse lights on? hd54321 General Hardware Discussion 6 07-23-2004 04:21 PM
Cheap camera with night vision mxxxxxm General Hardware Discussion 6 06-04-2003 12:55 AM
