Quote: Originally Posted by 0-0-7
Hi Mark,
I got a 4mm f/1.6 lens and the picture is very very blury. You can hardly recognize any object. Any suggestions ? there is no display on lcd for night vision mode. Of course the lcd is working and I tried increading the gain for IR as well as contrast for LCD.
Here is the lens.
Thx
http://cgi.ebay.com/4MM-4-MM-CCTV-Ca...QQcmdZViewItem
I agree with what korn kow said! I've used the 16mm version of this lens and they do work -- some needed the adjustment.
It does worry me that you say the focus is so terrible bad because that wasn't the case for me. At the risk of asking stupid questions, let me list the things that might be going wrong...
- The silver stud sticking out is for locking down the focus. You'll need to unscrew it and rotate the outer body of the lens to focus.
- Sometimes the lens gets jammed when you screw it into the camera body because you're actually applying force to the focus adjustment. If you can't rotate the endmost part of the lens while the part next to the NiteMax stays stationery, then it is jammed. You'll need to remove the lens from the NiteMax and twist the two parts in the "unscrew" direction to get them loose again.
- Even if you can't adjust the focus, you should be able to have objects in focus that are extremely close or extremely far. Can you see an object that's a few inches from the lens?
- For testing, you can extend the focus adjustment range by unscrewing the whole lens from the NiteMax. In fact, you can hold the lens a few millimeters in front of the CCD and get it to focus if it is way off. What you can't do is get the lens CLOSER to the CCD once it is screwed all the way in.
Remember: The lens WILL focus when the CCD is at exactly the correct distance from the lens. A standard lens is expected to be a standard distance away from the CCD and this is what the CS designation is for. Not all things are equal and this is why lenses have a range of adjustment for focus. By playing with the distance between the CCD and the lens, we're trying to see which direction things are off by and by how much. Once we understand where the lens needs to be, we can make adjustements accordingly.
- There's no Night Vision Mode -- it's always in the same mode. If you can see, the camera can see! If you can't see anything with your eyes (it's dark) the camera can't either. The camera can see IR. If you can't see and the camera can't see, turn on the IR -- you still won't see but the camera will.
