Go Back   MP3Car.com > General > Classifieds > Classified Archive
Old 04-02-2006, 10:35 PM   #271
NiteMax Mark's Avatar
NiteMax Mark is on a distinguished road
Thank you!
NiteMax Mark is offline
Old 04-02-2006, 10:48 PM   #272
PCModifiers's Avatar
PCModifiers is on a distinguished road
PMed you
No one ever said this stuff was easy...The Mobile Desktop
Progress[**********]
Dolby Digital Real-time Encoding*Desktop Computer*Athlon XP Mobile*ASUS A7N8X Deluxe*Kingston Hyper X*5.25" CDRW and DVD drives*Lilliput 8" LCD*Mag 14" LCD
PCModifiers is offline
Old 04-03-2006, 12:34 PM   #273
spaceskater's Avatar
spaceskater is on a distinguished road
So what lens are u guys using? I have been trying to decide what ls to use for the front side of the car but I still don't know... I got a bunch of them for cheep to test them but did not pay any attention that they all were F2.0 . When I decide on the lens I'll get a better one.
I am leaning toward a 6 or 8mm lens. Less than that and I can't see far enough (killing the point of night vision camera). More than that and looking through it feels very weird since everything is zoomed and u miss all nearby details and looking through the camera wile turning is VERY uncomfortable.
Will never be DONE! There is always something to add
VIA EPIA SP13000,1GB DDR,80Gb 2.5” SATA HDD,8" Xenarc LCD with t/s,Linksys Bluetooth,Logitech wireless trackball,OBDII,RearView wide angle cam,XM radio,2 Wifi external antennas, Frodo,Navivoice
spaceskater is offline
Old 04-03-2006, 01:25 PM   #274
ROMbler is on a distinguished road
Quote: Originally Posted by NiteMax Mark
That sucks!
Did you try the suggestion where you back out the stop screws on the lens and let it travel farther? This works until the lens bottoms itself out internally.
Yes, that's what I did. The lens bottoms out - I'll try your other suggestions when I can get a chance to crack it open. Thanks for all your help!
Quote: Originally Posted by 0-0-7
what is your other lens ? (I mean spec ?)
I'm sorry, I can't remember right now. I'll look at it tonight when I'm home.
ROMbler is offline
Old 04-04-2006, 11:12 AM   #275
trdny is on a distinguished road
I'm in for lenses.
I'll take the battery pack if it's the real one not the car adapter pack.
trdny is offline
Old 04-04-2006, 12:35 PM   #276
alti's Avatar
alti has a spectacular aura aboutalti has a spectacular aura aboutalti has a spectacular aura about
I started my nightvision project in my car here
Mark, I would like to get one of the nitemax ultras (the ones with out the power board, but the screen controller and color CCD) that you have, I also would like to get 6 of the IR LEDs that you have.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
alti is offline
Old 04-05-2006, 01:42 PM   #277
0-0-7 is on a distinguished road
while modifying the lcd, I removed all the wires but pin 5,9,11 from jp1.
now my picture is upside down and not clear.
Can someone post a picture of jp1 with all the wires attached as it comes from Mark so that I can put back the necessary wires back ?
thx
0-0-7 is offline
Old 04-05-2006, 02:08 PM   #278
thx
See Page 9
Quote: Originally Posted by Page 9
- Apply 12v DC on JP1 Pin 11
- Attach Ground to JP1 Pin 9
- On the pads near JP1, connect a 5k Ohm potentiometer between the "5v" pad and the "Gnd" Pad. Connect the center (wiper) pin of the potentiometer to the "Brt" pad.
- Feed the video signal in on JP1 Pin 5
Here's the LCD Controller Board...
Pin Name... I/O Pin Description...................... Remark
1.. /Hsync. .O. Horizontal Sync...................... Output for specific Application.
2.. /Vsync. .O. Vertical Sync........................ Output for specific Application.
3.. NPC.... I/O NTSC/PAL mode selection.............. Note 1
4.. SW..... .I. Composite/Analog RGB Signal Selection Note 2
5.. CVS.... .I. Composite Video Signal Input.........
6.. Bin.... .I. Separated Blue Video Signal Input....
7.. Rin.... .I. Separated Red Video Signal Input.....
8.. Gin.... .I. Separated Green Video Signal Input...
9.. GND.... .-. Ground...............................
10. GNDS... .-. Ground...............................
11. Vin.... .I. 12 Voltage DC Input..................
12. GNDS... .-. Ground...............................
13. COL.... .I. Color terminal adjustment............
14. LR..... .I. Left/Right scan selection............ Note 3
15. UD..... .I. Up/Down scan selection............... Note 4
Note 1: Default is auto detect for NTSC or PAL system.(Controlled by internal UPS015) High for NTSC mode and Low for PAL mode.
Note 2: Default is Composite Signal (Low); High is for seperate Analog RGB signals.
Note 3: Default is reversed scanning (High) and Low is for normal scanning (L —›R).
Note 4: Default is reversed scanning (High) and Low is for normal scanning (U —›D).
Old 04-05-2006, 03:48 PM   #279
hey mark,
so I need to make pin 14 & 15 high ? how do I do that ?
also, what is the diff betn gnd (pin 9) and gnds (pin 10,12) ? are they tied toghether on the pcb ?
0-0-7 is offline
Old 04-05-2006, 04:43 PM   #280
hey mark,
The original NiteMax configuration had 12, 14 and 15 tied together which would pull these pins LOW for normal operation. It looks like these pins have a pull-up resistor that makes them go high when no wire is attached.
The documentation shows the GND and GNDS names. I believe these are the same but I can't see the traces on the PCB well enough to say for sure. I think it's a safe bet to assume that these are all ground.
Old 04-06-2006, 05:18 PM   #281
OK everything works great now. tied pin 14 & 15 to ground.
thx Mark.
0-0-7 is offline
Old 04-07-2006, 12:11 AM   #282
dtran01 is on a distinguished road
How about the list... anyone else ? I think we may have enough for a bulk buy for the lenses right? (greater than 5..)
dtran01 is offline
Old 04-07-2006, 03:01 PM   #283
Banned
Motorcity's Avatar
Motorcity is on a distinguished road
I ended up having 1 dead beat bidder on my NiteMax auction. So, if anybody wants it, 28.00 to your door. (Insurance optional, @ 1.50)
SOLD. Thank you.
Motorcity is offline
Old 04-08-2006, 12:49 PM   #284
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
Just got my color CCDs (thanks Mark!)
It is quite a bit bigger than the b&w ccds.
So I start looking at my pile of project boxes and found a radioshack one that fits almost perfect
#2701801
I say almost as the standoffs for holding the pcb just miss and one of them is in the way of the can labeled NTSC. Though you could just mount it reversed. The board to the cover. I think with the right standoffs and a template, you could actually mount the CCD board to the cover of the project and the lens to the box itself, thereby solving the lens mounting issue. And if you were careful, could even fit a TO-2 voltage regulator in there.
shotgunefx is offline
Old 04-08-2006, 01:29 PM   #285
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
awesome, if you create a pdf template, that'd be sweet
.... sucks the color CCD is so large. Thats project enclosure is slightly smaller then my camera http://www.dpreview.com/reviews/canonsd450/page2.asp
no wonder that one guy was able to fit his in a paper clip holder. I was thinking "no way would this fit"
PC Components:
My work log
Peoples is offline
BMW E30 install with night vision tekta Show off your project 24 07-01-2006 03:41 PM
Digital Still Camera as video feed (i.e. for reverse camera, etc) meatwad General Hardware Discussion 2 01-26-2005 06:50 PM
low light night vision camera USB Tred General Hardware Discussion 8 01-05-2005 04:27 PM
Is non-IR rearview camera visible at night with reverse lights on? hd54321 General Hardware Discussion 6 07-23-2004 04:21 PM
Cheap camera with night vision mxxxxxm General Hardware Discussion 6 06-04-2003 12:55 AM
