Quote: Originally Posted by NiteMax Mark
JP2 Option/Feature Connector (Ground pin to enable)
JP2-1 AES/ALC AES: Automatic Exposure Control. ALC: Automatic LEvel Control.
JP2-2 BLC Black Level Control
JP2-3 AGC Automatic Gain Control
JP2-4 ATW/AWC ATW: Auto tracking white balance. AWC: One push lock white balance.
JP2-5 MIRROR
JP2-6 2X ZOOM
JP2-7 GND
Did some playing with the pins. Here's my results in a somewhat well lit room.
Enable this and the glare of the lights become a supernova.
The only effect this seems to have, is that if it's dark and you ground this, blacks become blacker.
I forget
, I'll have to go back to the drawing board.
JP2-4 ATW/AWC ATW
Basically, you when you hold it to ground, it will keep the current white balance until you open the circuit. I noticed that if you put the camera in the dark and held it to ground, the color will look much more natural in normal light (once you took it out of the dark of course ), still greenish, but much closer to normal. Release it and it goes back to being St. Patrick's Day.
JP2-5 MIRROR - predictable
JP2-6 2X ZOOM - predictable
Though I did note something interesting relating to my glare problem.
I put a different lense on it. A Cosmicar (came off the medical IR equipment) 8.5mm lens. Must be half decent as the only place I saw them wanted ~$100 for them. Anyway, it has an adjustable aperture and goes from 16 to 1.5.
Anyway, through the range, with this lens, the CCD handles the glare fine. For instance, the light in my living room is just a ball of glare no matter what I do with the F1.4 wide angle lens. With the 8.5mm, no matter what it's set to, it adjusts so I can actually see the fixture.
I wonder why that is
