Go Back   MP3Car.com > General > Classifieds > Classified Archive
Old 04-25-2006, 04:49 PM   #331
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
Quote: Originally Posted by Genesisfactor
JP2-5 is mirror imge? that coud be highly useful...
Yup (On the ultra CCDs). That's why I got 4. Two are for the car. One is going to replace my SAVV reverse cam. The night pics on that are way too noisy.
shotgunefx is offline
Old 04-25-2006, 07:24 PM   #332
Raw Wave
shotgunefx's Avatar
Quote: Originally Posted by Fusion-One
I gave that connection a try, but it doesn't solve the problem, unfortunately.. IT is definitely in the right area, though. When I intitally connect it, it causes a vertical shift in the image to a random position on the screen, and then continutes to roll.
An error I made earlier, when I thought I was outputing 60hz vertical to the screen, powerstrip was still controling the refresh rates (windows rates were disabled) so while I thought it was eating up 60hz, it was actually taking in a touch under 30.
Still scrolling. :P
(Notice how readable that text is?? 640x480 on a 2.5" screen, and its actually readable! (The insanity!)
Any luck with this since? Did you try the sync circuit?
Old 04-25-2006, 08:37 PM   #333
Genesisfactor is on a distinguished road
fun time...does the LCD itself have this feautre available to play with? How about that PSone screen, does it have tha ability?
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline
Old 04-25-2006, 08:59 PM   #334
Raw Wave
shotgunefx's Avatar
The mirror image? The nitemax lcd board does it (it's somewhere buried in one of the threads), the standard nitemax CCD cannot.
The PSOne screens? No idea.
Old 04-25-2006, 11:53 PM   #335
NiteMax Mark's Avatar
NiteMax Mark is on a distinguished road
- Any of the CCDs with 2x Zoom can mirror the video output.
- Any of the NiteMax LCDs can mirror the video input.
- The original NiteMax B&W CCD is the only part that can't mirror anything.
So as long as you've got a 2x Zoom CCD or the NiteMax LCD somewhere in your system, you've got mirror capability.
NiteMax Mark is offline
Old 04-26-2006, 12:06 AM   #336
PCModifiers's Avatar
PCModifiers is on a distinguished road
Lenses?
No one ever said this stuff was easy...The Mobile Desktop
Progress[**********]
Dolby Digital Real-time Encoding*Desktop Computer*Athlon XP Mobile*ASUS A7N8X Deluxe*Kingston Hyper X*5.25" CDRW and DVD drives*Lilliput 8" LCD*Mag 14" LCD
PCModifiers is offline
Old 04-26-2006, 05:33 AM   #337
dtran01 is on a distinguished road
We now have 10 lenses total ...
I am assuming Mark is still working on the negotiations. (?)
dtran01 is offline
Old 04-26-2006, 10:26 AM   #338
dmurray14 is on a distinguished road
Mark,
Do you have any LCDs left?
Thanks,
Dan
dmurray14 is offline
Old 04-26-2006, 02:11 PM   #339
Quote: Originally Posted by dmurray14
Mark,
Thanks,
Dan
Yes, too many to count.
Basically the status is still this: I have dozens of some items and hundreds of other items necessary to build complete NiteMax cameras. I don't have ANY of the internal Power Supply Boards.
Proposed Lens
It looks like the best price I can get will be $15 delivered to individual members. (Which is less than the $20.49 by going direct through this seller.) I am assuming I can re-ship them individually by first-class mail. International destinations will not be so lucky. Hopefully I can add them to a larger order so that the ADDITIONAL cost of shipping is nearly zero for the lens itself.
Old 04-26-2006, 02:15 PM   #340
I sure wish I had a VGA cable to cut apart!
Does anyone have a dead VGA monitor that they are interested in trashing? An amputated VGA Cable would sure be handy right about now.
Old 04-26-2006, 04:32 PM   #341
ROMbler is on a distinguished road
I have a 4' VGA cable I don't need - it's yours if you want it.
ROMbler is offline
Old 04-28-2006, 12:28 PM   #342
Raw Wave
shotgunefx's Avatar
I'm going to Radioshack today and pick up a vga connecter (they're like 3 bucks)
Quick question on experimenting with VGA, going by this post...
Is this what I have to do?
- Apply 12v DC on JP1 Pin 11
- Attach Ground to JP1 Pin 9
- On the pads near JP1, connect a 5k Ohm potentiometer between the "5v" pad and the "Gnd" Pad. Connect the center (wiper) pin of the potentiometer to the "Brt" pad.
- Put 5v? to JP1 Pin 3
- Connect RGB inputs to JP1 Pins 6,7,8 respectively
Then try and figure out sync.
Old 04-28-2006, 12:54 PM   #343
JP1-3 Selects between NTSC and PAL Composite Video format. This is not the correct pin to select RGB mode.
JP1-4 Should be pulled high to +5v to select RGB Mode.
You'll need to apply HSYNC and VSYNC in addition to what you've listed. Right now, the only thing that works for sure is to apply a Composite Sync signal to the Composite Video Input on JP1-5. (Your VGA output almost certainly DOESN'T have Composite Sync available.)
Pending the outcome of my experimentation, there's a good chance that a minor mod to the LCD Controller Board will allow the individual sync signals that the VGA connector outputs. It hasn't been done yet, but my feeling is that I'm close to having a working solution.
Old 04-28-2006, 01:12 PM   #344
Raw Wave
shotgunefx's Avatar
Thanks Mark. I meant JP-4, was tabbing too fast between the chart and the post.
I was reading through the Sharp chip datasheet the other day and tracing circuits on the board. I see how you came up with the first guess at sync.
One thing that has me wondering is how it stops rolling when he hit's the gain button. Got me thinking about the RGB amplification adj pin on the sharp.
Old 04-28-2006, 01:42 PM   #345
I'm guessing that cranking the gain up high causes enough noise internally to make the sync input THINK it has found sync. You can synchronize to one of the color signals at times, but it's completely dependent on the pattern of the image being displayed. It's a curiousity, but I'm not putting too much importance on it because I've seen this kind of thing before.
All we need (I think) is to feed the Sharp chip a satisfactory Vertical sync pulse and it should work. The question is how to do exactly that with the least amount of modifications to the board -- so mere mortals can make the mod without specalized equipment or skills! (I'm convinced that the clever little XOR circuit proposed somewhere will work, but It's more than I care to do because it's not convenient for most people.)
BMW E30 install with night vision tekta Show off your project 24 07-01-2006 03:41 PM
Digital Still Camera as video feed (i.e. for reverse camera, etc) meatwad General Hardware Discussion 2 01-26-2005 06:50 PM
low light night vision camera USB Tred General Hardware Discussion 8 01-05-2005 04:27 PM
Is non-IR rearview camera visible at night with reverse lights on? hd54321 General Hardware Discussion 6 07-23-2004 04:21 PM
Cheap camera with night vision mxxxxxm General Hardware Discussion 6 06-04-2003 12:55 AM
