Hey guys,
i have a 603x xtant amp and empty shroud for sale. This setup will give you an ultra clean looking install where you'll have a matching car pc case and amp. this is the cleanest amp i've owned but i'm totally redoing my install and the amp has to go.
looking for $400 b/o for the set
Channels: 3
Watts Per Channel: 4 Ohm 2 x 75 + 1 x 150, 2 Ohm 2 x 150 + 1 x 300, Bridged 4 Ohm 1 x 300 Watts
Freq. Response: 5Hz to 50kHz +/- 1dB
Distortion: <.04%
Signal to Noise Ratio: >100dB
Damping Factor: >200 @ 100Hz with 4 Ohm Load
Input Sensitivity: 40dB
Stereo Ch. Crossover: 12dB Octave
Mono Ch. Crossover: 12dB Octave
Line Outputs: Yes
Noise Gate: Yes
Passive Outputs: Yes
Module Ports: 4 Accessory
Power Supply: Regulated, PWM
Operational Voltage: 11 to 15 Volts
Fusing Requirements: 100 Amps
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
