shaonuff@hotmail.com
if you want to buy or have something to trade let me know
90$ sony etak skymap 2000gps. including isa pcmcia adapter. sony still in box all software and hardware included. this one is nmea compliant will work with many different gps programs.
20$ each (2) dauphin mini ps2 keyboards. keyboards measure approx 9 inches by 5 inches. black color .
85$ 5" parts express lcd flip down. paid 199$ a while back
45$ Pioneer DVD-106S 16X/40X Slot Load
65$ Pentium® III 850Mhz, FCPGA 256K, 100Mhz, Flip Chip - OEM
SOLD 20$ each (2) 256 pc100 memory
SOLD 33$ sounblaster audigy
70$ motherboard and celeron 400. The motherboard is designed with VIA Apollo Pro133 chipset supports the Intel PII/PIII, Celeron, and VIA Cyrix III processor. System memory bank supports 3 DIMM socket
memory to 768MB 100MHz & 133MHz SDRAM.
ST-693AVMA, on board include 2X AGP slot, Stereo sound , ATX power,
Super I/O, 2 Ultra DMA 33/66 EIDE interfaces, 2 USB ports, 2 PCI Expansion slots,
1 AMR slot , and 1 ISA slot.
Specifications:
► CPU -Supports Slot-1 and Socket-370 Intel Pentium ® II/III
and Coppermine TM processors
-2 nd level Cache Depend on CPU
-Coppermine Socket 370 FCPGA packaged processor
-VIA Cyrix III Processor
-Supports 66/100/133 MHz CPU Front Side Bus (FSB)
► Chipset -VIA VT82C693A North Bridge -VIA VT82C686A South Bridge
► Clock Generator -Supports 66/100/133/140*/150*MHz
("*" means frequency can be adjusted, and subject to different
configuration)
► Memory -3x168-pin DIMM Sockets
-Supports 100MHz & 133MHz SDRAM from 8MB to
768MB-Supports only 3.3V SDRAM DIMMT-693AVMA/E & ST-6 9 3 A V A /E U S E
► Audio -SoundBlaster Pro Hardware and Direct Sound Ready
AC97 Digital Audio controller-Hardware SoundBlaster Pro for
Windows DOS box and real-mode DOS legacy compatibility
- Supports two channel speaker mode
-MPU-401 game/MIDI port and Sound blaster 16 compatible
► I/O Control -Integrated Super I/O Controller in the VT82C686A/B
► I/O Interface -PCI Bus master IDE interface on board with two
connectors support 4 IDE devices in 2 channel, the PCI IDE
Controller supports PIO Mode 0 to Mode 4, Bus master IDE DMA
Mode 2 and Ultra DMA 33/66
-On-board super Multi-I/O chip that support 2 serial ports with 16550
Fast UART compatible, 1 parallel port with EPPand
ECPcapabilities, and a floppy disk drive interface
-On-board support PS/2 mouse Connector
-On-board support PS/2 Keyboard Connector
-On-board 2 USB ports
-On-board IrDA connector
-Floppy port supports 2 FDD with 720K, 1.44M, and2.88M bytes,
supports LS-120 floppy disk device
► Other Function -Supports Modem Ring Power On
► Power Supply -On-board 3V, 5V and 12V 20-pin ATX power connector
-Use switching regulator to support CPU core voltage
► Hardware Monitor -CPU/Power Supply/Chassis Fan Revolution detecting
-CPU Fan Control
-System Voltage Detect
-Display Actual Current Voltage
► BIOS -Licensed AWARD BIOS, 2M bit FLASH RAM -ACPI ready
for PC98/Windows 98
-System BIOS supports ACPI function and Green feature function,
DMI Plug and Play Flash ROM
Intel Celeron ®400Mhz Slot One CPU
► 400-MHz Processor Core Speed
► 128kbytes L2 Cache
► 66-MHz System Bus
► MMX Media Enhancement Technology
► Single Edge Processor Package
► CPU has heatsink and fan
► The Intel® Celeron™ processor offers great performance at
an exceptional value for today's applications.
I have used this CPU and board in my computer for the last several months and it is working fine, guaranteed not DOA
