Specs:
• Lilliput BlaXtream TC-1000 one Din In-Dash Computer system with 1G CPU, 512Mb DDR Ram , 40GB Hard drive onboard Sound card, onboard Lan card and onboard Modem.
• CD/RW burner & DVD player built in
• Main Frame ( For In-dash installation )
• Full function Remote Controller
• 100v-240v Power AC adapter
• Five-Core automobile power connection cable
• Audio output wire (RCA out )
• VGA extension wire
• USB extension wire
• Computer Instruction menu
• DVD player User's menu
• Onboard application driver software CD
• Bluetooth Driver software CD
• Carrier fixing frame
• Panel plastic frame
• Lilliput Fully 1 Din In-Dash Car PC DVD Player System with CD/RW
• Working Voltage from 7v to 24v
• Working current from 2.2A to 4A
• VIA BlaXtream TC-1000 with 1 GHz CPU,266MHz Bus (DDR),VGA card ,Sound card ,LAN card on board .
• DVD Rom build in
• 512 MB DDR Ram
• 40 GB Hard Drive - 5400 RPM and 8 MB cache
• Bluetooth on board
• Dimensions : 195 x 177 x 54 mm
• Weight : 1.55kg
• Computer : This product can be operated as a Car PC or Home PC when adapted with a mini LCD monitor or Home PC monitor .
• DVD Player and CD/RW burner : This product can play various media Discs such as CD, Mp3 , VCD and DVD . This is an instant boot-up Media player, which means the users can play Disc Media without booting up the computer Operating system.
• Extension Functions: This computer is designed with the bluetooth communication function and four USB ports, through which , the user can extend this machine with cordless keyboard and mouse, wireless earphone , GPRS modem, GPS navigation antenna, DVB-T digital TV receiver etc.
• Bluetooth Communication: For the operation instruction of the bluetooth communication mode , please refer to the following two*.pdf files in the bluetooth installation CD.
• English blueSoleil Usermanual 1.4.pdf
• English IVT blueSoleil 1.4-GAQ.pdf
• Compact Design: with the dimensions of 195 x 177 x 54mm , it is easy to be installed and carried. High Performance Specification: CPU 1G , Memory up to 512mb , 40GB Hard Disc , DVD drive & CD/RW burner. Lower Power consumption: maximum power consumption of this machine is 48W. Rated power consumption is lower than 30W . Energy saving and efficient heat emission performances make is applicable to the car environment. Professional make is applicable to the car environment. Professional design: it is specially designed for the application under vehicle environment with good mechanical structure and electrical design, such requirements as anti-vibration, heat emission, anti-disturbance, and power separation ca be satisfied; and the following severe operation conditions under vehicle environment can be improved, including vehicle jounce, high and low temperatures , surge current, and electromagnetic disturbance. Intelligent Power Control-this equipment has special Intelligent Power Control system .
• Wide voltage range input: this car PC can normally work ranged from 7V to 24V,overcoming the disadvantage of non-stability of vehicle battery voltage, especially the insufficient instantaneous vehicle ignition voltage.
• Automatic Delay shutdown: after "ACC" ( automobile electric lock ) switches off the power , the computer can automatically normally shut down and has 20 second delay to switch off the whole computer's power supply to ensure the normal PC shutdown.
