Go Back   MP3Car.com > General > Classifieds > Classified Archive
Old 02-05-2007, 09:58 AM   #1
CoupeE46 is an unknown quantity at this point
FS:: [[ Auzentech HDA X-Plosion 7.1 DTS Connect Sound Card ]]
Auzentech HDA X-Plosion 7.1 DTS Connect Sound Card $85.00 SHIPPED
Selling my DTS soundcard, I have no use for it now since i do not have a DTS decoder, and i am going with the M-Audio Firewire as well.. I would like to get rid of this item at $85.00 SHIPPED!! Item comes with Original Box, and DRIVERS, Optical CABLES, and the PCI Soundcard itself.. Any Questions please ask..
ITEM Features ::
  • # C-Media CMI8770 PCI chipset (8CH audio single chip with DTS® Connect and Dolby® Digital Live Real-Time Content Encoder)
  • # 8CH codec embedded PCI audio single chip
  • # Full-duplex 8CH 24bit/96kHz DAC / 2CH 16bit/48kHz ADC
  • # Integrated S/PDIF input/output supports 44.1kHz/48kHz/96kHz sample rate and 16/24bits resolution
  • # The world's first DTS¨ Connect logo program certificated PCI audio board
  • # DTS® Interactive : A real-time 5.1 encoder that takes any 2 or more channel and encodes it into DTS® bit stream. DTS® Interactive provides a single cable connection via S/PDIF digital audio output to a DTS® enabled surround sound system by encoding all audio into a DTS® compatible bit stream at 1.5Mbps
  • # DTS® Neo:PC : An up mixing matrix technology that turns any 2 channel audio into 7.1 surround sound. DTS® Neo:PC, based upon DTS® Neo:6 matrix surround technology, transforms any stereo content such as MP3, WMA or CD audio, into a 7.1-channel surround sound experience
  • # Dolby® Digital Live(DDL) Real-Time Content Encoder converts PC audio into a 5.1 channel Dolby® Digital bit stream
  • # Swappable dual DIP type OPAMP controlled preamp circuit (4pcs output control OPAMP IC with DIY socket, 2pcs MIC input control OPAMP IC with DIY socket)
  • # Max 2.8Vrms full swing analog output gain by unique preamp circuit / incredible powerful analog output, improve dynamic range / SNR
  • # Proper OPAMP control circuit (+8V, -8V dual power supply circuit) for high quality audio quality, prevent audio distortion at high volume level
thanks for looking..
-Steph'
CoupeE46 is offline
Old 02-05-2007, 10:44 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
bump for a darn good sound card.
I have the X-Meredian.
Jan Bennett
RedGTiVR6 is offline
Old 02-05-2007, 08:00 PM   #3
evening bump..
CoupeE46 is offline
Old 02-05-2007, 09:07 PM   #4
pepsibobby's Avatar
pepsibobby is on a distinguished road
your not suppposed to bump your own threads. its in the rules
I wish i could use this with my G5
Cant code cause I dont know how, but give me the paint bucket and my eraser and have at you!
pepsibobby is offline
Old 02-05-2007, 10:37 PM   #5
oops.. sorry about that then, still a noob on the site.. i must have skipped that part in the rules.. thanks for the heads up
and ya, i wish i can use this in my vehicle as well.. but i cant
CoupeE46 is offline
How do I connect the sound card to my head unit? emre LCD/Display 3 05-30-2005 12:25 AM
Sound Blaster Live 24-bit 7.1 Audigy Sound Card djXternal General Hardware Discussion 1 04-25-2005 04:49 PM
What cable do you use to connect from sound card to Amp?....need answer fast... phatrabbitzz Car Audio 1 07-28-2004 11:26 AM
5.6" LCD, PCI TV/Radio, 7.1 sound card, Sony amp & more eatyummypuppies Classified Archive 22 06-29-2004 08:19 PM
FS M-audio Sonica Theater 7.1 surround USB sound card jusatry Classified Archive 4 04-19-2004 09:41 PM
