Here are the Specs
7" transflective screen (Xenarc widescreen with remote)
------------THE PC--------
Via C3 1Ghz CPU
512 MB Ram
80GB HDD 2.5"
VIA EPIA PD 10000 mainboard
6 USB, 4 serial ports
SB Live 64 sound card
Caseoutlet Travla c137 case, black
M1-atx 90W pwr supply
The following hardware will be included
-80mm external exhaust fan on top of the chassis cover (keeps the entire system cool, blows hot air from the pc out through the top of the case)
-XM Direct unit, inside the comp chassis, with cabling for serial port and power, with the antenna
-RoadRunner temp monitoring hardware with 2 temp probes
-All wires with molex connectors
-External USB cd\dvd drive with wiring
-external Holux GM-210 USB GPS reciever
The following software is preinstalled
WIndows XP pro
Registered copy of StreetDeck, with mappoint 2006(No cds)
about 5 GB of mp3's, all sorts of music
1 2 channel AMP
Power Acoustik 500 Watt
All power connections run off the m1-atx so you will get clean power to all the components of the pc, including the monitor and the dvd drive.
You will get all the cabling, usb, power cables, and anything else that i used to install.
All this for $1100.00. I am not parting this system out. I can take detailed pics of the system. Check out my sig for the install pics as well as the transflective screen. There are links there.
This is a rock bottom price guys. Its the real deal.
SO CAL BUYERS PREFERRED! The price does not include shipping which would be pretty darn expensive for all this stuff. Esitmated shipping cost is about 200.00 for UPS ground.
