The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Coders Corner
Thread Tools Display Modes
Old 12-12-2007, 08:36 PM   #1
inh
Vehicle: 91 CRX Si
My Photos: (0)
VB6 FileSystemObject woes
Im trying to get VB6 to delete a file, using the FileSystemObject, but I cant get it created..
I am trying to define it using this in the on form load event:
Dim fso As New FileSystemObject
I get a 'user defined type not defined' error.. Any ideas guys? =/
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
inh is offline   Reply With Quote
Sponsored Links
Old 12-12-2007, 08:52 PM   #2
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
1. have you set up a reference in Project->References to the Microsoft Scripting Runtime?
2. Have you got scrrun.dll on your PC?
Enforcer is offline   Reply With Quote
Old 12-12-2007, 09:07 PM   #3
inh
Vehicle: 91 CRX Si
My Photos: (0)
I setup the reference, no more error =] Thank you!
Will i have to distribute scrrun.dll with my program? Or is this a standard windows component?
Old 12-12-2007, 09:43 PM   #4
Confusion Master
Enforcer's Avatar
My Photos: (1)
It should be standard however there are different versions so distributing it will not be a good idea.
Old 12-15-2007, 08:21 AM   #5
ClockWorK's CarPC Specs
ClockWorK's Avatar
Vehicle: 2004 Pontiac Grand Prix GTP CompG
My Photos: (79)
Other options
Personally, I prefer using the win32 API over system objects. Try the DeleteFile API or even the Kill command. If you use KILL, wrap it with an error trap. If you use the API, the return value is non-zero for successful delete. Make sure to add the API declaration to one of your modules though.
'in the declares of a module:
Declare Function DeleteFile Lib "kernel32" Alias "DeleteFileA" (ByVal lpFileName As String) As Long
'Then call it like:
dim retVal as long
retVal = DeleteFile(fullFileName)
'then check retVal.
or use the Kill command:
on error resume next
Kill fullFileName
on error goto 0
'then check error state or check if file still exists
My 2 cents. Hope it helps.
ClockWorK is offline   Reply With Quote
Old 12-15-2007, 08:28 AM   #6
inh
Vehicle: 91 CRX Si
My Photos: (0)
Much appreciated =] I'll probably just leave the system object in though, since ive already tested it and it works fine. There is really no reason it should be passed invalid info, since it is only deleting files that the program has created =]
Old 02-05-2008, 05:08 AM   #7
st1mpy's CarPC Specs
My Photos: (0)
Try Dim fso
set fso = createobject("scripting.filesystemobject")
st1mpy is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Questions about Destinator 3 SDK and VB6 gsova Coders Corner 4 01-17-2007 06:36 AM
VB6 vs VB 2005 Express alimh Road Runner 4 11-14-2006 05:36 AM
VB6: Does anyone have experience with adding moudlarity to their apps? Mrbmw99 Coders Corner 2 10-15-2006 06:19 PM
SDK - VB6 App Gobby RR Bug Tracker 2 05-08-2005 04:58 AM
Screwy docked toolbox in VB6!! deadweasel Software & Software Development 5 02-12-2004 02:06 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
