The keybd_event api is also good for this, if you have strings of key commands you need to pass.
Code:
Private Declare Sub keybd_event Lib "user32" (ByVal bVk As Byte, ByVal bScan As Byte, ByVal dwFlags As Long, ByVal dwExtraInfo As Long)
Private Const KEYEVENTF_EXTENDEDKEY As Long = &H1
Private Const KEYEVENTF_KEYUP As Long = &H2
Private Const VK_SHIFT As Long = &H10
Private Const VK_CONTROL As Long = &H11
Private Const VK_MENU As Long = &H12
Private Const VK_SPACE As Long = &H20
Private Const VK_PRIOR As Long = &H21
Private Const VK_NEXT As Long = &H22
Private Const VK_UP As Long = &H26
Private Const VK_DOWN As Long = &H28
Private Declare Function VkKeyScan Lib "user32" Alias "VkKeyScanA" (ByVal cChar As Byte) As Integer
Public Sub Keyboard_PressKey(ByVal key$, Optional ByVal HoldShift As Boolean = False, Optional ByVal HoldCtrl As Boolean = False, Optional ByVal HoldAlt As Boolean = False)
'this procedure uses the byte values for key presses to simulate actual keypresses.
'for now, it's only set up to handle one character at a time.
Dim k As Byte
On Error Resume Next
Dim holdByte As Byte
holdByte = CByte(Asc(key$))
k = VkKeyScan(holdByte) And &HFF
If HoldShift <> False Then keybd_event VK_SHIFT, 0, KEYEVENTF_EXTENDEDKEY, 0
If HoldCtrl <> False Then keybd_event VK_CONTROL, 0, KEYEVENTF_EXTENDEDKEY, 0
If HoldAlt <> False Then keybd_event VK_MENU, 0, KEYEVENTF_EXTENDEDKEY, 0
keybd_event k, 0, KEYEVENTF_EXTENDEDKEY, 0
keybd_event k, 0, KEYEVENTF_EXTENDEDKEY Or KEYEVENTF_KEYUP, 0
If HoldShift <> False Then keybd_event VK_SHIFT, 0, KEYEVENTF_EXTENDEDKEY Or KEYEVENTF_KEYUP, 0
If HoldCtrl <> False Then keybd_event VK_CONTROL, 0, KEYEVENTF_EXTENDEDKEY Or KEYEVENTF_KEYUP, 0
If HoldAlt <> False Then keybd_event VK_MENU, 0, KEYEVENTF_EXTENDEDKEY Or KEYEVENTF_KEYUP, 0
End Sub
