The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Coders Corner
Thread Tools Display Modes
Old 04-15-2008, 04:54 PM   #1
portreathbeach's CarPC Specs
Vehicle: 2003 VW Transporter T5
My Photos: (46)
How can I read ID3 tags in MP3 files?
Here is my problem...
I have coded my own front-end and am using the ultraID3lib.dll to pull the id3 tag info from the mp3 files. Everything works fine for v2.3 files (apart from a few that iTunes screwed up), but it doesn't work for v2.2 or v2.4. I was thinking of writing my own code to read the tags, but can only find samples of how to read v1 tags, which is pretty simple. Is there any VB.net code samples available to get the basic stuff, artist, song name etc. as well as the more advanced stuff, like album art from an MP3 file.
Thanks for any help
ViVE - Volkswagen In Van Entertainment:
VoomPC 2, VIA C7 2GHz
7" Lilliput
120Gb Sata drive
1GB RAM
[||||||||||] 100% - Planning
[||||||||||] 100% - Software coding
[||||||||||] 100% - Built
(Always tweaking!)
portreathbeach is offline   Reply With Quote
Sponsored Links
Old 04-15-2008, 05:28 PM   #2
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
This is VB6 but it might help
http://www.vbaccelerator.com/home/vb...gs/article.asp
Enforcer is offline   Reply With Quote
Old 04-16-2008, 10:41 AM   #3
My Photos: (46)
Thanks for the link. Good write-up about MP3 files, haven't had time to play around with the code, but I don't see anywhere about album art in there.
7" Lilliput
120Gb Sata drive
1GB RAM
(Always tweaking!)
Old 04-16-2008, 11:08 AM   #4
Confusion Master
Enforcer's Avatar
My Photos: (1)
Warning Information overload
http://www.id3.org/id3v2.4.0-frames
Old 04-16-2008, 01:25 PM   #5
My Photos: (46)
That is a lot of reading and some pretty involved coding to read into the frames of an mp3 file. Amyway, I have found a few C# samples, and will try and translate these to VB.net.
Thanks for the help
7" Lilliput
120Gb Sata drive
1GB RAM
(Always tweaking!)
Old 04-19-2008, 03:56 AM   #6
My Photos: (46)
I am now using .GetDetailsOf to retrieve the Artist, Album, Title etc. but I still can't get the album art from the mp3 file. Is there any VB code that has an example of this. I havn't seen any actual code to do this, there are a few .dll files people have written, but I would like to code it myself if possible.
7" Lilliput
120Gb Sata drive
1GB RAM
(Always tweaking!)
Old 04-19-2008, 05:47 AM   #7
Confusion Master
Enforcer's Avatar
My Photos: (1)
Have look a roadrunners source, I think there maybe something in there.
Old 04-19-2008, 04:20 PM   #8
My Photos: (46)
I have had a scan through the RoadRunner source, but can't find any code that extracts the AlbumArt, the only code I can find loads the AlbumArt from files in an albumart folder. For some reason, I can't get RoadRunner to work on my machine, so can't really tell if it can extract the albumart from the mp3.
7" Lilliput
120Gb Sata drive
1GB RAM
(Always tweaking!)
Old 04-19-2008, 07:56 PM   #9
slvrsol's Avatar
My Photos: (0)
try looking at the plugin source
http://www.mp3car.com/vbulletin/rr-p...rt-plugin.html
slvrsol is offline   Reply With Quote
Old 05-21-2008, 11:23 PM   #10
bigbrother82's Avatar
Vehicle: 2007 GMC Sierra
My Photos: (0)
While I am not certain, and I am mainly a Java programmer, I believe the album is not embedded in the MP3 file. The MP3 file I believe has a spot for the location of the album art on the drive, but not the actual image.
I'll try to double check that and let you know. I remember reading that somewhere.
Jacob
"I have not lost my mind - it's backed up on disk somewhere." -Unknown Author
bigbrother82 is offline   Reply With Quote
Sponsored Links
Old 05-21-2008, 11:52 PM   #11
My Photos: (0)
Well I was wrong. The album art can be embedded in ID3v2 or higher. It can not be embedded in ID3v1 though. Which I think is what you were trying to retrieve from, of I read your post right.
Check out http://www.id3.org/ID3v1.
Version 1 was very basic from my understanding.
Old 06-02-2008, 01:22 PM   #12
My Photos: (46)
Thanks for the reply. I am now using '.GetDetailsOf' which is part of XPs 'shell32.dll' to retrieve the mp3 information which is pretty quick. I am still using 'UltraID3.dll' to retrieve the album art.
7" Lilliput
120Gb Sata drive
1GB RAM
(Always tweaking!)
Old 06-02-2008, 02:34 PM   #13
galvitron's CarPC Specs
galvitron's Avatar
Vehicle: 2006 Evo MR
My Photos: (0)
Here is some more info that you might find useful:
http://www.codeproject.com/KB/recipes/vbmp3header.aspx
http://www.codeproject.com/KB/files/tagreader.aspx
http://www.codeproject.com/KB/cs/Do_..._With_ID3.aspx
And a nice tool to convert C# to VB.net and vice versa:
http://labs.developerfusion.co.uk/co...arp-to-vb.aspx
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 100%
Installation/Fab/Assembly (Revised):
[----------] 80%
galvitron is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
mp3 id3 gibrish toofresh Software & Software Development 0 04-07-2008 05:01 AM
Splash screen and id3 tags Flappy Centrafuse 3 09-22-2006 04:57 AM
Help with MP3 radios, files, & directories mp3designer General Hardware Discussion 5 10-03-2001 08:27 AM
Playlists and ID3 tags in VB? Bj Software & Software Development 32 06-25-2001 08:17 PM
Do you guyz know this cool machine? Ginger General Hardware Discussion 3 04-19-2000 11:38 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
