Quote: Originally Posted by
Sicarius
It's likely that your time estimate is too optimistic. From what I've been able to dig up, the worse your estimate, the worse the A* algorithm's performance gets.
Yes, it is definitely very optimistic, because we wanted to be on the safe side and to make sure we never overestimate the time cost.
Quote:
How feasible would it be to search all vertices within a circle with a radius of the remaining distance to the destination centered on the destination to find speed limits? You'll never be able to get to the destination faster than the highest limit found and it's a much better estimate than an assumed 300km/h.
That should not be too hard I guess. Thanks for the idea, I will definitely give it a try! We might actually retrieve the highest speed in the whole graph as we build it in memory and then simply use it throughout the search
