Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Coders Corner
Old 03-21-2009, 06:29 PM   #1
lambosprit's Avatar
lambosprit is on a distinguished road
Standalone BlueSoleil wrapper
Due to lots of people asking and the fact I had to do it to get some bits working I have split my mobilephone plugin in two. There is now a RR specific plugin thats still called mobilephone and a new dll that is a wrapper around the BlueSoleil sdk.
I've included a sample VB.net express 2008 project to show how to use it.
It currently has two known problems.
1) For some reason it loses the connection to the phone after about 5 minutes. Dont know why but working on it. If you reconnect its all fine. If you implement an autoconnect function it works fine.
2) The signal and battery strength indicates haven't been implemented yet. Again working on it.
You need to put the BSWrapper dll in the same directory as the program calling it. I didn't need to register it but I had to have the vc redistribution installed if I didn't have vc express installed.
Lastly BlueSoleil version 6.4.236.0 or greater is required
Have fun and any questions just ask.
lambosprit is offline   Reply With Quote
Old 03-21-2009, 07:24 PM   #2
tempgp's Avatar
tempgp is an unknown quantity at this point
yay sweet
THANKS A LOT!!!!
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Bluetooth Cell Phone CallerID [Pre-Alpha]
Custom Button Bash Board - Add physical touchable buttons to your CarPC Project
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
tempgp is offline   Reply With Quote
Old 03-22-2009, 06:29 AM   #3
swift_gti is an unknown quantity at this point
Thanks for your hard work.
Will be checking this out today!
swift_gti is offline   Reply With Quote
Old 03-22-2009, 07:05 AM   #4
P3D4T0R's Avatar
P3D4T0R is an unknown quantity at this point
Thanks for your efforts but I cant seem to get the sample to work on my laptop, i get an error: 0x8007000B which it seems from looking around on google that you might need to recompile it for x64, any clue?
"Mess with the best, die like the rest."
Work Log --> Old Car (Totaled)
Work Log v2 --> New Car (Totaled)
Work Log v3 --> GMC Suburban K2500 (Work in progress)
P3D4T0R is offline   Reply With Quote
Old 03-22-2009, 07:56 AM   #5
vtcom is an unknown quantity at this point
it all seems to work ok for me
vtcom is offline   Reply With Quote
Old 03-22-2009, 01:51 PM   #6
P3D4T0R's Avatar
What are you running?
Old 03-23-2009, 07:23 AM   #7
xp sp3 on a ibm t60 laptop
Old 03-23-2009, 10:37 AM   #8
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
i get the following error :
Unable to load DLL 'BSWrapper.dll': The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
i have the wrapper file in the release folder as well as the project folder. I attempted to add it as a reference but it didnt do anything. Is there a version of bluesoliel required?
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 03-23-2009, 06:54 PM   #9
Just had a chance to play with this latest version, it's working well.. good job!
Only current issues I've noticed are the voice gateway doesn't connect if BT already has a connection to the phone (if you click connect, then connected label changes to 'true' but 'net avail' stays false.. if you disconnect then reconnect it works fine.)
Also for some reason 'hangup' doesn't appear to be working for me, I can dial, answer, get callerid and see incoming calls, but hangup doesn't actually seem to do anything - even though in a call it returns 0 whereas out of call it returns 770..
Great job so far.
Old 03-23-2009, 07:01 PM   #10
If you are running the project from within Visual Studio you need to put the dll inside the debug folder not the release one.
Even if you didn't have BS installed I wouldn't have expected you to get that error so I shouldn't think that will be your problem.
Having said that you may get wierd issues if you are running a very old version as I'm fairly sure the HFP service was only implemented fairly recently.
You can get a 15 day trial of the latest version here; http://www.bluesoleil.com/download/d...asp?resoure=43
It may be a good idea if people post which version of the stack they are using when reporting if this is working or not, then we can get an idea of what works.
I've tested it myself with 6.4.245 and 6.4.249 and both work fine.
Old 03-24-2009, 05:35 PM   #11
lambosprit's Avatar
The net_avail is a problem I know of. Its down to the bluesoleil software itsself. It only reports on network availability when the phone is first connected. If you restart the app without disconnecting then bluesoleil doesn't rereport the network status. Its whats causing me the most head aches in converting my mobilephone plugin.
Sonicxtacy02. you can check where its looking for the dll by adding a message box to output the path setting.
add this line
msgbox Environment.GetEnvironmentVariable("path") after the path is set.
the reason to do this is that you cannot set a variable path to a dll but if the dll is in the local path then its found. so I set the path to include where the application is runnin from which is why the dll need to be in the same directory. If you know a better or different way I would be interested.
Old 03-25-2009, 09:47 AM   #12
lambosprit's Avatar
Had a think about the netavail problem.
What does everyone think of automatically disconnectig and reconnecting if the phone is already connected when the app first starts up? The downside for me is you have to accept the audio connection on the phone (but that might just be my phone).
Old 03-25-2009, 11:31 AM   #13
tempgp's Avatar
In your phone settings go to paired phone and select that pair as autorized, paired, permament, automatic - different makes call that diferently but as result of that option phone will auto connect w/ your comp w/o confirmation message
Old 03-25-2009, 06:16 PM   #14
lambosprit's Avatar
thanks for that tempgp.works a treat
Old 03-25-2009, 06:18 PM   #15
tempgp's Avatar
you got it buddy ;-)
Embedding BlueSoleil - I give up rodweb Road Runner 2 09-20-2008 06:13 PM
BlueSoleil 6.2.227.11 Full for Centrafuse Zo6om Centrafuse 1 09-08-2008 08:54 AM
Bluesoleil not licensed halller Centrafuse 3 05-06-2008 08:54 PM
Shuttle to ship standalone XPC motherboards? Defiler General Hardware Discussion 0 06-05-2007 07:42 AM
BlueSoleil - Bluetooth Wireless Software for Windows!+ BlueSoleil Mobile Partner kyrenia Wireless Communications 0 04-06-2005 12:39 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
