Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Coders Corner
Old 03-09-2006, 09:37 PM   #1
XM Direct Protocol ?
First, I have searched, but I cannot find a source that describes how the commands are sent and data is received from the XM Direct device. I have one and it works with Road Runner, but I would like to find an uptodate listing of how the communications work so that I could do some programming. I looked at the Road runner source, but there is a tremendous amount of code in that app. My hat is off to anyone who can manage all of that.
Anyone have a writeup, or some VB code that only covers this area?
walttoinfiniti is offline   Reply With Quote
Old 03-10-2006, 12:39 AM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
It's a series of bits that you send to the serial port.
For example, "5A, A5, 00, 05, 00, 10, 10, 01, ED, ED " will power the unit up.
I did a Google on "XM Direct Protocol" and got the following link: http://weblogs.asp.net/bstahlhood/ar...06/347438.aspx
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is online now   Reply With Quote
Old 03-10-2006, 07:15 PM   #3
Thanks for the info Bugbyte, but I'm pretty sure that I have been there before and the link to the document is still dead.
BTW I have spent a lot of time searching thru a lot of subjects since I signed up a couple of weeks ago, but because there is so much, it get very fustrating at times.
Walt
Old 03-10-2006, 10:54 PM   #4
kamikaze2112's Avatar
I have that PDF somewhere. I'll start some full scale searches on my HDD's an post it up if I find it
Edit: Geez....didn't think i'd find it that quick LOL
1999 Pontiac Sunfire
New CarPC on it's way! Check out my worklog for details ;)
kamikaze2112 is offline   Reply With Quote
Old 03-12-2006, 08:54 PM   #5
kamikaze2112,
Thanks, that was exactly what I was looking for! This and the other info you provided should get me going. I've got a lot of learning to do still, but think I should be able to put my system together, since it will not be as full feartured as many of the ones I've seen.
Walt
Old 05-02-2006, 08:23 PM   #6
XM Protocol
Could someone post some sample VB code using the xm protocol info? I'm new to working with serial data. It's not entirely clear from looking at the pdf how to send the info.
Pendragon445 is offline   Reply With Quote
Old 05-03-2006, 03:57 PM   #7
pyros's Avatar
Your best bet is to check the open source projects on sourceforge.net or the roadrunner source code..
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
pyros is offline   Reply With Quote
XM Direct + Serial = Mouse? jpsndtek Hardware Development 4 12-23-2007 12:56 PM
XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer Will Albers General MP3Car Discussion 2 03-27-2006 08:49 PM
Possible to split XM Direct cable to computer and XM commander? Jemmi General Hardware Discussion 3 12-14-2005 02:07 PM
XM Direct digital adapter or XM PC cable with SkyFi2??? LATEOTT Hardware Development 0 01-19-2005 02:18 PM
Using an XM direct as an XMPCR dacndar General Hardware Discussion 20 10-17-2004 01:21 AM
