Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Coders Corner
Old 04-18-2006, 12:48 AM   #1
VB6: Does anyone have experience with adding moudlarity to their apps?
I am been around VB6 for a while now an have built some pretty extensive applications with it. I have yet to be able to familiarize myself with adding modulatity though. What I'd like to be able to do it have a main application and allow users to download a file and place it in the app directory or run an installer. This will give them that functionality. This way I can upgrade a certain module of my application each time, and allow for many different options.
I guess some sort of .dll or .ocx, but it needs to be able to be loaded and run after the application is built and out. I also want to be able to make new addons and have the VB detect their existance and load them too. Do you know of any tutorials or pages about this type of functionality?
I have been looking around on Google, but what generally comes up is stuff about VB Modules, not what I need.
Thanks!
Mrbmw99 is offline   Reply With Quote
Old 06-10-2006, 02:23 AM   #2
Well, I know that in VB.NET what you are looking for is a Interface. You would have an interface that a class from a DLL would implement. That way your original code can load the .DLL into memory and then create an instance of the class and call the implemented functions on the instanciated class.
Ineffigy is offline   Reply With Quote
Old 10-15-2006, 06:19 PM   #3
Under VB6 the trick is "Late Binding". It all gets a bit messy and is not particularly well documented but you use CreateObject("PackageName.ObjectName") to get an instance of some registered object, then from there you need to have some standard "plugin" interface that you require from third party developers so that you can call the functions etc. E.G. you may require that all valid plugins have a name property so it might go ...
function loadplugin(byval pluginObjectName as string) as object
dim result as object
set result = nothing ' assume failure
on error goto fail
set result = createobject(pluginObjectName)
if result.Name="" then set result = nothing ' We dont allow blank plugin names
set loadplugin = result ' return object if ok.
exit function
fail:
set result = nothing ' either object not registered or didnt implement name
end function
this function would return and instance of an object registered with the supplied classid as long as it implemented a member called name that returns a non-blank string. ActiveX controls are even messier; look into controlextender.
wheesplat is offline   Reply With Quote
Embedding apps in vb6 Laidback Software & Software Development 9 05-09-2004 07:44 PM
Adding apps craigyb MediaCar 4 12-01-2003 06:52 AM
