The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Coders Corner
Thread Tools Display Modes
Old 05-09-2006, 09:58 AM   #1
ado_civon's CarPC Specs
ado_civon's Avatar
Vehicle: 2005 Holden Commodore VZ SV6
My Photos: (0)
Destinator SDK 5 & Pocket PC in .NET
I hope someone can help out.
The PC version includes a DLL DestSDKLib.dll which can be nicely imported into C# or VB.NET in Visual Studio 2003. All works well.
Unfortunately such DestSDKLib.dll does not exist for the PPC version.
How do i get Destinator loading in Pocket PC using DestSDK.dll?
Has anyone tried this or got it working?
It would be great if someone could help me out, thank you in advance.
ado_civon is offline   Reply With Quote
Sponsored Links
Old 06-10-2006, 02:29 AM   #2
Ineffigy's CarPC Specs
Vehicle: 2005 Toyota Celica GTS 6
My Photos: (0)
You could try a process invoke. I never tried it though on a Compact Framework application though, I'm not sure if it will behave any differently.
Ineffigy is offline   Reply With Quote
Old 08-13-2006, 06:20 PM   #3
My Photos: (0)
Question Destinator SDK 5 & Pocket PC in .NET
Hi,
I've been working with the D3 SDK using interop in Visual Studio 2005 and VB.Net. I've now got the D5 SDK and would like to continue. The initialization is some what different - would you mind showing me the initialization code please. My target is also a PDA - so shortly I'll be going through the same issues - and will help out where I can.
TG
TommyGun is offline   Reply With Quote
Old 09-05-2006, 03:15 AM   #4
My Photos: (0)
Hello ado_civon,
I'm also trying to intergrate Destinator ND (v5) into a PC application. I'm using C# with dotnet 2.0. How did you get it working?
This is my test application:
Code:
using System; using System.Collections.Generic; using System.Drawing; using System.Windows.Forms; using DESTSDKLib; namespace test2 { public partial class MainForm { Dest test = new DestClass(); [STAThread] public static void Main(string[] args) { Application.EnableVisualStyles(); Application.SetCompatibleTextRenderingDefault(false); Application.Run(new MainForm()); } public MainForm() { InitializeComponent(); test.ShowDestinatorWindow(); } } }
This is the exception I get @ "test.ShowDestinatorWindow();":
Code:
Exception System.InvalidCastException was thrown in debuggee: Unable to cast COM object of type 'DESTSDKLib.DestClass' to interface type 'DESTSDKLib.IDest'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{F092A542-5F97-4AFD-886A-1B23A7F04BC8}' failed due to the following error: Bad variable type. (Exception from HRESULT: 0x80020008 (DISP_E_BADVARTYPE)).
I've tested this in SharpDevelop, Visual Basic 6 and Visual C# 2005 Express on my development PC and on a fresh installed Windows XP PC. All have the same issue.
Maybe the DestClass object need some more intialization? I've tested with the SDK version include in the latest CentraFuse. CF is written in dotnet 1 and Destinator ND is integrated into it. So it must be possible with the SDK they use.
maartenclaes is offline   Reply With Quote
Old 09-05-2006, 04:04 AM   #5
FreeDrive Creator
CdRsKuLL's CarPC Specs
CdRsKuLL's Avatar
Vehicle: Ferrari 360 (nearly)
My Photos: (5)
I believe the SDK that centrafuse uses has an extra hash key which is used here
res = g_Dest.CreateDestinatorWindow(F_DEFAULT,"KEY")
I think this is whats needed
CDR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 09-06-2006, 01:29 AM   #6
My Photos: (0)
Ok, now I'm getting a messagebox "Wrong access key".
Old 09-06-2006, 04:55 AM   #7
My Photos: (0)
Arrow
The problem I had above (cannot cast ... to interface) can be passed by InvokeMember-calls to the COM object.
Code:
Type t = Type.GetTypeFromProgID("DestSDK.Dest"); obj = Activator.CreateInstance(t); obj.GetType().InvokeMember("CreateDestinatorWindow", System.Reflection.BindingFlags.InvokeMethod, null, obj, new object[]{CREATE_DESTINATOR_FLAG.F_DEFAULT, "KEY"}); ------------ obj.GetType().InvokeMember("ShowDestinatorWindow", System.Reflection.BindingFlags.InvokeMethod, null, obj, null); ------------ obj.GetType().InvokeMember("HideDestinatorWindow", System.Reflection.BindingFlags.InvokeMethod, null, obj, null); ------------ obj.GetType().InvokeMember("DestroyDestinatorWindow", System.Reflection.BindingFlags.InvokeMethod, null, obj, null);
When I create the Dest object, a small unpainted window is created in the lefttop of the screen. When I call ShowDestinatorWindow, nothing happens. HideDestinatorWindow and DestroyDestinatorWindow removes the unpainted window. When I remove all maps from the destinator directory, I get a painted window which ask for a map. What am I doing wrong?
Old 09-07-2006, 05:57 PM   #8
FreeDrive Creator
CdRsKuLL's Avatar
My Photos: (5)
your doing nothing wrong, the software is designed not to work unless you hold a valid key, this is only available from powerloc themselves.
CdR
Old 10-25-2006, 05:43 PM   #9
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
Anyone still working on this?
We can get past the 'key' message and I can get the map to show(and show my position etc.) but I haven't got all the extras yet.
For PC, I mean
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 01-17-2007, 05:42 AM   #10
gsova's Avatar
Vehicle: 1997/BMW/E36 316i Coupe
My Photos: (0)
Unhappy
For PC, I mean
Laidback,
How did you get past the 'key' message? Have you patched the DestSDK.DLL?
I'm stuck with Dest 3 SDK...
gsova is offline   Reply With Quote
Sponsored Links
Old 01-17-2007, 12:27 PM   #11
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
Now would I do such a dishonest thing like that?
And then tell you in plain view of the mods.....
Laidback
Laidback Carputer
Old 01-18-2007, 08:11 AM   #12
gsova's Avatar
My Photos: (0)
I converted maartenclaes's code in VB.NET.
I have similar results. I can see that Destinator PN is starting through obj.GetType().InvokeMember and a box appears in the upper-left corner of the screen. I can also Show and Hide the box but no map appears inside the box. If I delete the maps from the ./DestinatorApps/Destinator folder I get the standard Dest PN map selection screen.
maartenclaes, I'm a beginner to .NET. Can you tell me how I could get/set a property for the COM object that is created with obj = Activator.CreateInstance(t) ?
Assuming that I wanted to modify or display the IDest.GPSProtocol Property, how would I have to call it?
Old 01-19-2007, 02:06 AM   #13
gsova's Avatar
My Photos: (0)
One more thing to mention: If I remove Destinator.exe from the folder, when I initialize the Destinator Object, I get a message saying "my software is not correctly installed".
Isn't it strange that the DLL requires the EXE to work?
I'll try maartenclaes's code in C#
Old 01-19-2007, 04:57 AM   #14
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
'Strange' is the other name for the destinator sdk! :-)
Laidback
Laidback Carputer
Old 01-21-2007, 05:53 AM   #15
Raw Wave
Laidback's Avatar
Vehicle: Jeep GC
My Photos: (0)
That message comes from destcore.dll
Laidback
Laidback Carputer
Sponsored Links
Trackbacks are Off
Pocket PC Dock farmboy30 Fabrication 3 05-02-2006 02:05 PM
pocket pc gps on pc vidason GPS 8 04-12-2006 05:41 PM
Pocket Pc gboy General Hardware Discussion 3 06-27-2005 05:01 AM
WTT/FS - Pocket PC Imat & Tmobile Sidekick 1 xdjxklusivex Classified Archive 0 06-25-2005 04:00 AM
FS: HP iPAQ Pocket PC h1910 w/ Stereo Earpiece astral Classified Archive 0 08-03-2003 01:18 PM
Sponsored Links
Ad Management by RedTyger
