Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Coders Corner
Old 08-06-2006, 06:33 PM   #1
kamikaze2112's Avatar
VB6 serial port help
I'm trying to figure out how to get the proper data off the serial port from my GPS adapter. I'm using xPort to split my GPS into 3 virtual coms, 1 for iGuidance, one for netstumbler, and one for my frontend. All i really want is speed and bearing, so I can have a basic compass in my front end all the time.
Now I know what part of the NMEA sentence I need, but I'm having trouble getting the sentences into VB in a consistant form. I can see the data that I need in the status bar in xPort, but I'm getting alot of garbage and | characters in my input stream.
I can zip up my test app that i wrote and attach it if someone wants to take a look at it.
any help is appreciated.
Trevor
1999 Pontiac Sunfire
New CarPC on it's way! Check out my worklog for details ;)
kamikaze2112 is offline   Reply With Quote
Old 08-07-2006, 02:40 AM   #2
Hi Trevor,
are you converting the data properly? ie; if Bytearray is passed, you would either have to deal with it in bytes or convert it into String. If you upload your file, I can have a quick look.
Rana
RanaUK is offline   Reply With Quote
Old 08-07-2006, 07:07 AM   #3
Confusion Master
Enforcer's Avatar
Here is where I got the code to dismantle to get the info I want.
http://www.developerfusion.co.uk/show/5426/
Enforcer is offline   Reply With Quote
Old 08-07-2006, 09:09 AM   #4
Raw Wave
Laidback's Avatar
I presume you've checked your code without using xport?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 08-07-2006, 09:19 AM   #5
FreeDrive Creator
CdRsKuLL's Avatar
pulled from RR source
Code:
Public Sub ReadGPS() Static Ltry As Double 'Last Time we tried to reconnect GPS Static Buff As String 'Buffer of Data Dim NB As Long 'Number of Bytes Dim b() As Byte 'Array of Bytes Dim DT() As String 'GPS Fields Dim sData As String 'Temp GPS Data On Error Resume Next 'Prevention -- Issue posted by Arathranar If Hibernated Then Exit Sub 'If MM running If MMRunning Then Buff = frmMM.MM.Custom("GetNMEA|GGA", "D3Request") + vbCrLf Buff = Buff + frmMM.MM.Custom("GetNMEA|RMC", "D3Request") + vbCrLf GoTo ProcGPSData End If 'If nothing to do If GPSPort = 0 Then Exit Sub 'Try to read bytes NB = CommRead(GPSPort, b, 1024) 'If Got Data If NB > 0 Then Buff = Buff + StrConv(b, vbUnicode) ProcGPSData: NB = InStr(1, Buff, Chr(10), vbBinaryCompare) 'while there are complete lines While NB > 0 'Get Line of Data sData = Left(Buff, NB - 1) 'Adjust Buffer Buff = Mid(Buff, NB + 1) 'Process Line of Data If Left(sData, 1) = "$" Then DT = Split(sData, ",") Select Case DT(0) Case "$GPRMC" 'Get Lat, Long, Speed and Heading GPS.Lat = CDbl(Left(DT(3), InStr(1, DT(3), ".") - 1)) GPS.Lon = CDbl(Left(DT(5), InStr(1, DT(5), ".") - 1)) If CommaSys Then 'Prepare for Conversions If CommaSys Then DT(3) = Replace(DT(3), ".", ",") If CommaSys Then DT(5) = Replace(DT(5), ".", ",") If CommaSys Then DT(7) = Replace(DT(7), ".", ",") If CommaSys Then DT(8) = Replace(DT(8), ".", ",") 'Get Lat/Long GPS.Lat = GPS.Lat \ 100# + (CDbl(Mid(DT(3), InStr(1, DT(3), ",") - 2)) / 60#) GPS.Lon = GPS.Lon \ 100# + (CDbl(Mid(DT(5), InStr(1, DT(5), ",") + -2)) / 60#) Else GPS.Lat = GPS.Lat \ 100# + (CDbl(Mid(DT(3), InStr(1, DT(3), ".") - 2)) / 60#) GPS.Lon = GPS.Lon \ 100# + (CDbl(Mid(DT(5), InStr(1, DT(5), ".") + -2)) / 60#) End If If DT(4) = "S" Then GPS.Lat = -GPS.Lat If DT(6) = "W" Then GPS.Lon = -GPS.Lon GPS.speed = CDbl(DT(7)) GPS.HDG = CInt(DT(8)) Case "$GPGGA" 'Get Altitude and Sat Count If CommaSys Then DT(9) = Replace(DT(9), ".", ",") GPS.Alt = CDbl(DT(9)) GPS.SATS = CInt(DT(7)) GPS.Valid = (Val(DT(6)) > 0) End Select End If 'Check for more lines NB = InStr(1, Buff, Chr(10), vbBinaryCompare) Wend 'Reset Timeout Timer Ltry = Timer Else 'Didn't get any data in 10 seconds (Problem ?) 'Try to reconnect GPS If Timer - Ltry > 10 And MMRunning = False And CurSCR <> "destinator_gps.skin" Then GPS.Valid = False 'Close Port CommClose GPSPort 'Give O.S. processing time Sleep 1 'Try to Re-open it CommOpen GPSPort, "\\.\COM" + CStr(GPSPort), "baud=4800 parity=N data=8 stop=1" CommSetLine GPSPort, 2, True 'Data Terminal Ready ON (in case) Ltry = Timer End If If Ltry > Timer Then Ltry = Timer End If End Sub
might be of some help :-)
CdR
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 08-07-2006, 09:25 AM   #6
Confusion Master
Enforcer's Avatar
Laidback, you're still about then?
Old 08-07-2006, 02:22 PM   #7
hey, thanks for the replies.
This is the first time I've ever tried anything regarding the serial port, so what I came up with is not very fancy. It was stuff i found with google here and there, and kinda molded into something that i thought would work, so please bear with me.
I've attached my little test program which basically takes whatever is in the input buffer and using the split function splits it into words() using a comma as the delimiter. If words(0) = "$GPRMC" then it takes words(7) and converts it from knots to km/h and puts it in a textbox, and words(8) (bearing) in another box. I have the MsComm control set to Com10 as that's the com i set aside for it on xPort, it can be changed in the properties of the control. Clicking the start/stop button simply sets the mscomm1.portopen property to true or false.
I'm pretty sure it's not the right way to go about this, but it's very simple and i came up with it in about an hour. I don't know how else I can test my program, and I know very little about serial programming.
Thanks for the help
Old 08-07-2006, 02:55 PM   #8
The class file in the zip on the above page was really what I was looking for in the first place, but couldn't find anything. I'd still like to see if what I wrote is going to work with little modification, but if not I can just use the class file
Old 08-09-2006, 02:24 PM   #9
Raw Wave
Laidback's Avatar
Of course, an enforced holiday from broadband, a stuffed mother board and a new house needing plenty of work but I still stick my nose in now & again. :-)
Laidback
Laidback Carputer
Old 08-09-2006, 05:17 PM   #10
Confusion Master
Enforcer's Avatar
did you send your broadband a postcard
Old 08-11-2006, 12:34 PM   #11
DeltaFX's Avatar
Why not intercept the $GPVTG sentence, which gives you speed in BOTH Mph and km/h ? (This sentence is optional on certain GPS units)
You could use AsyncPro components to deal with serial com.
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
serial port to game port adapter wiring asif General Hardware Discussion 5 08-17-2006 04:47 PM
GPS usb-> serial port zerocover GPS 10 10-07-2005 12:08 AM
Command-line serial port logger..?? tj!2k4 GPS 11 09-23-2005 10:56 AM
serial port switch input th3madc0w Hardware Development 5 01-04-2005 04:27 AM
IR serial port receivers Fusion-One Input Devices 3 08-07-2003 05:49 PM
