The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Coders Corner
Thread Tools Display Modes
Old 03-15-2007, 09:14 PM   #1
DJiK's CarPC Specs
DJiK's Avatar
Vehicle: 1995 Audi 90 Sport Quattro
My Photos: (0)
Question VB6: Get ContorlID of a Button in an External Application
I'm in the process of rewriting my plugin from AutoIt to VB6 so it's better compatible with the RoadRunner Front End.
Here's my issue:
In AutoIt there's a function called:
ControlGetHandle - "Retrieves the internal handle of a control."
This means that I can get the handle of any window and of any control in that window (such as a button).
That way I could send a Click Message to that button using the SendMessage command.
Example:
Code:
$WAhandle = ControlGetHandle("classname=Winamp v1.x", "", 0) ;Gets the Winamp Handle $JFhandle = ControlGetHandle("Jump to file", "", 0) ;Gets the JTFP Handle $JTFBhandle = ControlGetHandle($JFhandle, "", 4918) ;Gets the Jump to File Button Handle
With the code above, JTFBhandle is the direct handle to the Jump button on the "Jump-to-File" Window.
Visual Explanation:
(It is essential that I am being correctly understood.)
In Visual Basic 6.0, I can get to the "Jump-to-File's" Window handle, but I can't access the handles of the buttons that are on the window itself.
See the buttons Enqueue File, Move after current, Jump to file, etc.?
Their Control ID's are 4919, 4920, and 4918 respectively.
I need to get to the handles of these buttons based on their Control ID numbers above.
How do I do it in Visual Basic 6.0?
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Sponsored Links
Old 03-16-2007, 10:55 AM   #2
Pishaa's Avatar
My Photos: (0)
Look at GetDlgItem API help.
Pishaa is offline   Reply With Quote
Old 03-16-2007, 12:39 PM   #3
Raw Wave
lostreception's CarPC Specs
lostreception's Avatar
Vehicle: Chevy Van G20 and '06 Scion Xb
My Photos: (1)
yea thats what i used for IGQ there was alot of extra stuff going on as well tho
Code:
if (getdlgitem(blah) = true AND getparent("winamp") = true) then match=1
syntax is probably off but getdlgitem is not as powerful as autoits getcontrolid
so you need to make a similar function to check for the same things otherwise it find all sorts of weird windows and controls
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Relocating computer power button King_Xerxes General Hardware Discussion 8 02-21-2007 09:15 PM
External Application tn6478 StreetDeck 7 01-11-2007 10:05 AM
How to make MP3 button launch external app? Griffin_Dodd MediaCar 5 04-01-2004 10:04 AM
Mediacar V1.8.5 coyote MediaCar 47 02-16-2004 01:16 PM
Mediacar V1.8.3 coyote MediaCar 12 01-07-2004 01:26 PM
Sponsored Links
Ad Management by RedTyger
