Go Back   MP3Car.com > Mp3Car Technical > Crowdsourced Data Collection, Open Source Mapping And Routing
Old 07-01-2009, 03:53 PM   #1
darth sidious lite
Fiberoptic's Avatar
Fiberoptic will become famous soon enoughFiberoptic will become famous soon enough
The open source navigation problem
The goal of this forum and community effort is to create a free map and routing application that is easy to install and use on many platforms The map and routing engine will be continuously updated by those connected to the Internet.
Why do navigation users need to pay 9$ a month for navigation or 50$ for stale map data that never gets updated? Car companies also charge hundred of dollars for built in navigation upgrades.
None of the current open source or paid offerings have these core features all in one package
  • Free, Accurate, usable
  • Easy to install package for use on low power mobile devices
  • Passively, crowd source collected map data
  • An algorithm to passively process the above and make it routable
  • A routing algorithm to work with the above
  • I am sure as the discussion continues we can clarify this problems list.
I will be moderating this forum with our new moderator, ChunkykS. Over the next week or so we hope to hear more ideas about how the rest of the community can help.
A good place to start reading is a blog post we did in late june of 2009 . There is also a video there explaining the difference between passive and active map generation.
Check out our video blog. 74 videos and counting
Fiberoptic is offline   Reply With Quote
Old 07-02-2009, 11:30 AM   #2
thekl0wn's Avatar
thekl0wn is on a distinguished road
Would it be possible to get just a bit more info? If nothing else, just the general direction of where all of this is heading? Is there something new in development or is the direction going towards using existing? (please forgive my blissful ignorance)
Planning [----X-----] 40%
Programming [-X-------] 20%
Parts [-----X----] 50%
Install [X--------] 5%
See Me In A Pink Skirt
thekl0wn is offline   Reply With Quote
Old 07-02-2009, 11:55 AM   #3
darth sidious lite
Fiberoptic's Avatar
Does this make sense? If not, what am I missing? This is a somewhat complicated topic.
I think a one page graphical explanation of how a navigation package works might be helpful:
  • Map data source
  • Compression
  • Traffic speeds
  • Road flow data
  • How the routing engine uses the above
  • more details on the vision behind real time updated maps and passive vs active data collection and processing. Do you think this point is covered in the teleatlas movie?
Old 07-02-2009, 12:09 PM   #4
thekl0wn's Avatar
That thread itself cleared up a lot. The video did a fairly good job with the basic explanation as well.
Was that thread always in this section? I've briefed through that thread before, but didn't remember it in this section. Or is my brain already on vacation?
Old 07-02-2009, 12:10 PM   #5
darth sidious lite
Fiberoptic's Avatar
I moved it over yesterday. It was in the blogtalk section.
Old 09-06-2009, 03:57 AM   #6
sbb_f1234 is an unknown quantity at this point
Well, i also think that a graphical explanation of how a navigation package works might be helpful, because it's more clear and easier for us to understand.
sbb_f1234 is offline   Reply With Quote
Old 11-01-2009, 08:08 PM   #7
cataso is an unknown quantity at this point
I depends on what you're trying to achieve. If its just mapping then lat, long and maybe altitude is all you need. The big thing seems to be how often you sample these points (currently once every 100 metres.)
If you're after traffic reports, as some suggested, then some kind of real time update and speed collection would be required. All doable in my app but adds complexity, cost and not much benefit until people are really using it.
Other important data is the street data, road names, numbers, speed limits etc. I have started research on this and will be coding once I've made the tracker robust and easy to use.
cataso is offline   Reply With Quote
New Open Source Valentine One USB Adapter Design PredatorCoder Hardware Development 22 06-21-2009 01:21 PM
Problem with navigation superman661 StreetDeck 1 12-21-2006 08:12 AM
Open Source OBDII scanner Trampas Engine Management, OBD-II, Engine Diagnostics, etc. 0 12-09-2006 04:35 PM
RoadNav FREE Open Source GPS Mapping! JohnWPB Road Runner 11 09-28-2006 08:11 AM
Update: 2-12-05.. Flash Support!... guino Road Runner 163 02-13-2005 01:21 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
