The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > DigitalMods (Scripts / API)
Thread Tools Display Modes
Old 04-24-2007, 07:55 PM   #1
rburhum's CarPC Specs
rburhum's Avatar
Vehicle: 2002 Audi TT Roadster / 2000 Isuzu Rodeo
My Photos: (0)
Getting handle to pre-existing modules
All the samples that I see are to create new modules and register for notification of events of that modue, but I don't see any to listen to pre-existing System Modules. How can I get a handle to preexisting modules?
rburhum is offline   Reply With Quote
Sponsored Links
Old 04-25-2007, 08:11 PM   #2
Raw Wave
god_of_cpu's Avatar
Vehicle: 2003/Infiniti/G35 Sport Coupe
My Photos: (0)
You don't. The way to modify system modules is through making a new skin. If you want to add functionality to a module, the only way to do it is to make an overlay that is restricted to a particular module.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 04-25-2007, 10:16 PM   #3
rburhum's Avatar
My Photos: (0)
I got my problem solved yesterday, but only through a series of hacks which probably are not the proper way of solving them. I (and am sure others here, too) would appreciate if you could comment on the approach I used to solve my problem. We can all learn from some criticism of the 'correct' approach.
- Problem: After coming back from hibernate the radio doesn't work on T3.
- 'Workaround': Create a 'Restart SD' button on Radio System module
- Procedure of my ghetto solution due to my ignorance of the SD API:
1.- Skin the radio system module and add a button captioned "RestartSD Radio".
2.- Hack #1: Since I couldn't find a way to register for an 'OnClick' of the button, I wrote a C# adding that created a custom 'exit module'; Since I can listen for an event that does the transition in, I can fire my "restart" code that way.
3.- Hack #2:
Since there is not way to tell SD to restart, I wrote a C++ app that monitor SD by process id every half a second and restarts it once it has shutdown. This app doesn't always run. The way it works is that once someone enters my 'exit module', the C# code will spawn the C++ app that does the monitoring, and then the C# code will trigger the shutdown of SD. The C++ app goes away once it has already restarted SD.
So now, everytime my radio doesn't work, I just press the restart sd button and everything works fine once again.
Did I take the long route?
Old 04-26-2007, 01:57 PM   #4
sharpmat007's CarPC Specs
sharpmat007's Avatar
Vehicle: 2006 Mitsubishi Eclipse
My Photos: (0)
I have the same issue when returning from hibernate. If you start playing an mp3 then switch back to radio you get it working again without having to restart SD. I think it might even be the line input getting muted and staying muted after resuming from hibernate, but havent had time to confirm.
Can you test that on yours and let me know?
Mitsubishi Eclipse 2006 GT
Infill T3 running StreetDeck
sharpmat007 is offline   Reply With Quote
Old 04-26-2007, 02:53 PM   #5
rburhum's Avatar
My Photos: (0)
I tried that already, and it doesn't work for me 100% of the time. I originally tought that it was something with a line remaining muted.... doesn't seem to be that (I go to the regular Windows Sounds Volume control and have ALL the possible outputs listed.. none of them have the check on mute when the problem happens).
Old 04-26-2007, 03:10 PM   #6
My Photos: (0)
So you do have some success when you switch between sources(IE play an mp3 and then switch back to radio)? I also have it drop out sometimes if I try to adjust fader/balance...you have this issue too?
Old 04-26-2007, 03:16 PM   #7
rburhum's Avatar
My Photos: (0)
I never have the problem when I switch from sources. Only when coming back from hibernate
If you are having problems when switching between sources it is probably because your SD Settings (as far as input lines) are incorrect.
Old 04-26-2007, 03:27 PM   #8
My Photos: (0)
Clarification: I dont have issues when switching sources. I meant that when I resume from hibernate and the radio doesnt play audio, I can switch to another source and then back to radio to get it working again.
Sponsored Links
vB code is On
Trackbacks are Off
Scripted modules 06TC_OWNER DigitalMods (Scripts / API) 8 10-24-2006 11:45 PM
Importing Modules from Different Skins god_of_cpu StreetDeck Skins 1 08-02-2006 07:07 AM
Door handle i3igmind Car Audio 2 05-23-2005 01:19 AM
FS: More 7" video modules digitalww Classified Archive 18 12-29-2004 12:19 AM
can 90w opus handle... Nico3k Power Supplies 4 03-08-2004 06:14 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
