Please be gentle...I'm a newbie. When I install this digitalmod and try and type in my zip code I get an error message. Below is the error message and my log file.
Error Message
Error in script (main)
VE Cache - main (170,1) Error
-2146827859: ActiveX component can't
create object:
'ZipCodeDLL.ZipCodeLookup'
Log File
INFO: ************************************************** ******************************
INFO: StreetDeck Application Data Log
INFO: Log started: Friday, September 07, 10:16 PM
INFO: Application Version: 1.0.6.3
INFO: Command Line:
INFO:
OnPreCreate - Initialization time 1.344 / 1.344 seconds.
INFO:
RenderWindow PreCreate - Initialization time 0.016 / 1.360 seconds.
INFO:
RenderWindow Create - Initialization time 0.015 / 1.375 seconds.
INFO:
Init Loading Logo - Initialization time 0.000 / 1.375 seconds.
INFO: CUVAppData::OnCreate - Navigation controller successfully initialized!
INFO:
Window / Direct3D Create - Initialization time 0.000 / 1.375 seconds.
WARNING: CAuthorize::ReadPhysicalDriveInNTWithZeroRights - DeviceIOControl IOCTL_STORAGE_GET_MEDIA_SERIAL_NUMBER error = The request is not valid for this device.
INFO:
LoadRegInfo - Initialization time 0.016 / 1.391 seconds.
WARNING: UV_GetFileList - The system cannot find the file specified.00000002
INFO:
Init Plugins - Initialization time 0.031 / 1.422 seconds.
INFO:
OneTimeDOne - Initialization time 0.109 / 1.531 seconds.
INFO:
OneTimeSceneInit - Initialization time 0.000 / 1.531 seconds.
INFO:
FindBestWindowedMode - Initialization time 0.000 / 1.531 seconds.
INFO: CDrawWnd::Initialize3DEnvironment...
INFO: CDrawWnd::Initialize3DEnvironment - Successfully created D3D device!
INFO: CRenderEngine::InitDeviceObjects...
INFO:
RenderEngine Init - Initialization time 0.907 / 2.438 seconds.
INFO:
PreInitDeviceObjects - Initialization time 0.343 / 2.781 seconds.
INFO: Initializing POI database...
WARNING: .\UPnPDevice.cpp:68 HRCALL Failed!
0x80070002 = pRegistrar->RegisterRunningDevice( BuildDeviceDesc(strFriendlyName).AllocSysString(), this, CComBSTR("InitString"), GetResourcePath().AllocSysString(), 0, &m_bstrDeviceId)
INFO:
OnInitDeviceObjects Start - Initialization time 0.750 / 3.531 seconds.
WARNING: CInfillOverlay::OnStartup - Error opening infill device hardware! (Open Failed!)
INFO:
Folder Init - Initialization time 1.219 / 4.750 seconds.
INFO: CSoundController::InitDeviceObjects...
INFO: Loading Textures...
INFO: CTextureBag::LoadTextures...
INFO:
Load Textures - Initialization time 0.328 / 5.078 seconds.
INFO:
Load Logo Texture - Initialization time 0.016 / 5.094 seconds.
INFO: Initializing Textures...
INFO:
Initialize Textures - Initialization time 0.000 / 5.094 seconds.
INFO: Initializing Speech Controller...
INFO:
Init Speech - Initialization time 0.000 / 5.094 seconds.
INFO: Initializing Media Event Processor...
INFO:
Init Media Event Processor - Initialization time 0.000 / 5.094 seconds.
INFO: Initializing Volume Control Textures...
INFO:
Init POI DB - Initialization time 0.000 / 5.094 seconds.
INFO:
Init Media Managers - Initialization time 0.000 / 5.094 seconds.
INFO:
Enumerate Apps - Initialization time 0.016 / 5.110 seconds.
INFO: CAppData::LoadSkin - Loading skin Default...
INFO: CAppData::LoadSkin - Loading skin C:\Documents and Settings\CIngram\My Documents\StreetDeck\UI\Skins\Default\Skin.skn...
WARNING: CAppData::SetSystemMetric - The specified skins system metric eSMListNAVDirectionYOffset, 700 is outside the bounds (Min:-500, Max:500) allowed by it. The default value of 0 will be used instead.
INFO: CAppData::LoadSkin - Finished loading skin...
INFO:
Load Skin - Initialization time 0.203 / 5.313 seconds.
INFO: CAppData::OnInitDeviceObjects - Skin successfully loaded!
INFO:
CDVDManager - Initialization time 0.000 / 5.313 seconds.
INFO:
CiPodManager - Initialization time 0.000 / 5.313 seconds.
WARNING: .\RenderEngine.cpp:679 HRCALL Failed!
0x88760b59 = (hr = D3DXCreateTextureFromFileEx( m_pD3DDevice, lpszFileName, 0, 0, 1, 0, D3DFMT_A8R8G8B8, D3DPOOL_MANAGED, D3DX_FILTER_NONE, D3DX_FILTER_NONE, 0, &d3dxImageInfo, NULL, &lpTex->m_lptex ))
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.SHINEY_RECT_LARGE.INFORCE)!
WARNING: .\TextureBag.cpp:342 HRCALL Failed!
0x88760b59 = hr = g_lpAD->m_RenderEngine.LoadTextureFromFile(strFileName, lpTexture)
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.SHINEY_SQUARE_SMALL.INFORCE)!
INFO:
CLaunchCastManager - Initialization time 0.125 / 5.438 seconds.
INFO:
CXMRadioManager - Initialization time 0.015 / 5.453 seconds.
INFO:
CRadioManager - Initialization time 0.032 / 5.485 seconds.
INFO:
CTVManager - Initialization time 0.000 / 5.485 seconds.
INFO:
CVideoFileManager - Initialization time 0.000 / 5.485 seconds.
INFO:
CAudioFileManager - Initialization time 0.000 / 5.485 seconds.
INFO:
Media Manager Ontime Scene Init - Initialization time 0.000 / 5.485 seconds.
INFO: CFontBag::InitDeviceObjects...
INFO:
Init FontBag - Initialization time 0.140 / 5.625 seconds.
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.CHECKBOX.INFORCE)!
INFO:
Overlays - Initialization time 0.125 / 5.750 seconds.
INFO:
User Overlays - Initialization time 0.000 / 5.750 seconds.
INFO:
User Modules - Initialization time 0.016 / 5.766 seconds.
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.WIZARD.INFORCE)!
INFO:
Volume Modules - Initialization time 0.047 / 5.813 seconds.
INFO:
Voice Modules - Initialization time 0.000 / 5.813 seconds.
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.LISTITEM_LARGE.DORMANT)!
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.LISTITEM_LARGE.INFORCE)!
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.LISTITEM_LARGE.EXTENDED.DORMANT)!
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.LISTITEM_LARGE.EXTENDED.INFORCE)!
INFO:
Relay Modules - Initialization time 0.453 / 6.266 seconds.
INFO:
MsgBox Modules - Initialization time 0.000 / 6.266 seconds.
INFO:
External Apps Modules - Initialization time 0.000 / 6.266 seconds.
INFO: CScriptedModule::LoadSkin - Loading skin C:\Documents and Settings\CIngram\My Documents\StreetDeck\Scripts\{1FB0936A-FD23-4A41-86E3-61C3F3977B0F}\main.sds...
INFO: CScriptedModule::LoadSkin - Finished loading skin...
WARNING: UV_GetFileList - The system cannot find the path specified.00000003
INFO: CScriptedOverlay::LoadSkin - Loading skin C:\Documents and Settings\CIngram\My Documents\StreetDeck\Scripts\{4E338835-DF18-49A4-B163-510AF3B3B4CB}\!VolumeAutoHide.sds...
INFO: CScriptedOverlay::LoadSkin - Finished loading skin...
INFO: CScriptedOverlay::LoadSkin - Loading skin C:\Documents and Settings\CIngram\My Documents\StreetDeck\Scripts\{C5DA74F2-6CD1-4DED-A50B-2C35C64D5361}\!NavZoomAutoHide.sds...
INFO: CScriptedModule::LoadSkin - Loading skin C:\Documents and Settings\CIngram\My Documents\StreetDeck\Scripts\{FE67B8EB-7293-4A66-A85F-E3338090B87C}\main.sds...
INFO:
Scripting Modules - Initialization time 0.703 / 6.969 seconds.
INFO:
Tray Overlays - Initialization time 0.000 / 6.969 seconds.
INFO:
EQ Modules - Initialization time 0.000 / 6.969 seconds.
INFO:
MultiMon Modules - Initialization time 0.016 / 6.985 seconds.
WARNING: CPanel::LoadSkinDB - Failed to load custom skin property (fillcolor2 = 4294967295)for panel AlbumShadow!
WARNING: CPluginBag::GetPlugin - LoadLibrary - The specified module could not be found.0000007e
WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\CIngram\My Documents\StreetDeck\Plugins\Input\InputG35SWC.dll )!
WARNING: CPluginBag::GetPlugin - Could not load plugin (C:\Documents and Settings\CIngram\My Documents\StreetDeck\Plugins\Input\InputPhidgetsEn coder.dll)!
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (BUTTON.LISTITEM_SQUARE.DORMANT)!
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (FOLDER.DEFAULT.DORMANT)!
WARNING: CPanel::LoadSkinDB - Failed to load custom skin property (fillcolor2 = 0)for panel VEBackground!
WARNING: UV_GetFolderList - The system cannot find the path specified.00000003
INFO:
Package Modules - Initialization time 0.593 / 7.578 seconds.
INFO:
Load Modules - Initialization time 0.000 / 7.578 seconds.
INFO: CAppData::LoadXMLSettings - Loading XML Settings from C:\Documents and Settings\CIngram\My Documents\StreetDeck\config.xml...
INFO: CGirderModule::OnLoadXMLConfig - No plugins were loaded from the girder plugin path!
WARNING: CRelayModule::OnLoadXMLConfig - No plugins were loaded from the Relay plugin path!
INFO:
Load Settings - Initialization time 0.047 / 7.625 seconds.
WARNING: CAppData::SortOverlays - Could not find overlay (CStatusModule) to set Z-Order!
WARNING: CAppData::SortOverlays - Could not find overlay (CPanelChooserOverlay) to set Z-Order!
INFO:
Init Skin - Initialization time 0.000 / 7.625 seconds.
INFO:
Overlay Scene Init - Initialization time 0.000 / 7.625 seconds.
INFO:
Module Scene Init - Initialization time 0.000 / 7.625 seconds.
INFO: CDrawWnd::RestoreDeviceObjects...
INFO:
Create Class Enum - Initialization time 0.078 / 7.703 seconds.
INFO:
EnumAudioMixers - Initialization time 0.016 / 7.719 seconds.
INFO:
BindToStorage - Initialization time 0.000 / 7.719 seconds.
INFO:
GetDisplayName - Initialization time 0.000 / 7.719 seconds.
INFO:
INFO:
INFO:
INFO:
WARNING: CAVInputDeviceManager::EnumerateInputDevices - Could not find audio device id for device (@device:cm:{33D9A762-90C8-11D0-BD43-00A0C911CE86}\Modem #0 Handset Record)!
INFO:
INFO:
WARNING: CAVInputDeviceManager::EnumerateInputDevices - Could not find audio device id for device (@device:cm:{33D9A762-90C8-11D0-BD43-00A0C911CE86}\Modem #0 Line Record)!
INFO:
INFO:
INFO: CDrawWnd::OnSettingsChange...
INFO: CNAVGPSController::Connect - Simulating GPS Data
INFO: Performing CDVDManager startup...
INFO: Performing CiPodManager startup...
INFO: Performing CLaunchCastManager startup...
INFO: Performing CXMRadioManager startup...
INFO: Performing CRadioManager startup...
INFO: Performing CTVManager startup...
INFO: Performing CVideoFileManager startup...
WARNING: CNAVGPSController::COMM_Thread - The GPS simulation data file (C:\Program Files\StreetDeck\GPSSim.txt) was not found. GPS data will NOT be simulated!
INFO: Performing CAudioFileManager startup...
INFO: MessageBox:
Initializing...
Please wait while the media player initializes.
WARNING: CNetSyncSettingsModule::OnStartup - Could not open sync settings file (C:\Documents and Settings\CIngram\My Documents\StreetDeck\NetSync.dat) to get encrypted password!
INFO: CDrawWnd::Create - Initialization completed!
INFO: CDrawWnd::Create - Program initialization completed in 21 seconds.
INFO: Loading Sounds...
INFO: CSoundController::LoadSounds...
INFO: CDrawWnd::Reset3DEnvironment...
INFO: CDrawWnd::InvalidateDeviceObjects...
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (C:\Documents and Settings\CIngram\My Documents\StreetDeck\Scripts\{4E338835-DF18-49A4-B163-510AF3B3B4CB}\icon.png)!
WARNING: .\ImageLargeLstBtnPanel.cpp:867 HRCALL Failed!
0x88760b59 = g_lpAD->m_RenderEngine.LoadTextureFromFile(m_arTextureFil eNames[i], lpbmp, SM(eSMListAlbumArtWidth), SM(eSMListAlbumArtHeight))
WARNING: CRenderEngine::LoadTextureFromFile - Failed to load texture (C:\Documents and Settings\CIngram\My Documents\StreetDeck\Scripts\{C5DA74F2-6CD1-4DED-A50B-2C35C64D5361}\icon.png)!
INFO: MessageBox:
Extracting Package...
Please wait while all files are extracted from the package.
INFO: MessageBox:
Start DigitalMod?
The new DigitalMod was successfully installed. Do you want to run it now?
WARNING: Script Error VE Cache - main (170, 1) Error -2146827859: ActiveX component can't create object: 'ZipCodeDLL.ZipCodeLookup',
INFO: MessageBox:
DigitalMod Error!
INFO: MessageBox:
INFO: MessageBox:
Start DigitalMod?
INFO: MessageBox:
INFO: MessageBox:
Start DigitalMod?
WARNING: ASSERTION FAILURE! - !GetModule(lpModule->GetModuleName()) && "Module being registered already exists!"
.\AppData.cpp (Line: 4297)
INFO: MessageBox:
DigitalMod Error!
INFO: MessageBox:
INFO: MessageBox:
Start DigitalMod?
INFO: MessageBox:
DigitalMod Error!
INFO: MessageBox:
Script Error!
This DigitalMod has been stopped because of an error! Would you like to try running it again?
INFO: MessageBox:
DigitalMod Error!
