Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > DigitalMods (Scripts / API)
Old 07-19-2007, 12:43 PM   #1
Changing Overlay Visible State
I am using this code in my module to make my overlay visible or not:
Code:
If SideBarList.IsItemChecked(0) Then Set obj = module.GetScriptedOverlay("IISpeedVolumeOverlay") obj.Visible = true Else Set obj = module.GetScriptedOverlay("IISpeedVolumeOverlay") obj.Visible = false End If
I keep getting an "Object required" error. What am I doing wrong here? Do I need the path to the overlay in there also?
I also tried this code in my overlay:
Code:
If IsEnabled <> 0 Then Overlay.Visible = true Else Overlay.Visible = false End If
This doesn't seem to do anything. Of course, I can use Label.Caption = "" for all of the overlay, but it doesn't seem like the correct way to do it.
Another thing I would like to do is disable and enable the overlay timer from the module so when the overlay is disabled there is no CPU use. Any way to do this?
Thanks for you help on this stuff. My Speed Volume digitalmod is almost ready to go.
IandI is offline   Reply With Quote
StreetDeck Functions god_of_cpu DigitalMods (Scripts / API) 22 01-15-2008 10:44 PM
Question About Dynamic Overlay Text unreal32 DigitalMods (Scripts / API) 1 09-18-2006 04:13 PM
StreetDeck Panel (Windowing) System god_of_cpu DigitalMods (Scripts / API) 0 01-21-2006 10:54 AM
What's the difference between Hibernate and Standby? BriCubz General MP3Car Discussion 8 08-17-2004 09:32 PM
touchscreen overlay repair? Jarrod Input Devices 3 01-29-2003 01:41 PM
