Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > DigitalMods (Scripts / API)
Old 07-27-2007, 01:14 AM   #1
Deadeye is an unknown quantity at this point
How to set the zindex of the back and home buttons?
I’m new to SD scripting. I’m just trying to make a simple app.
I have a module that creates an Host window.
hWndHost = (int)module.CreateHostWindow();
That is fine however how do I set the zindex of the back and home buttons to be above this window?
Deadeye is offline   Reply With Quote
Old 07-27-2007, 02:20 PM   #2
Raw Wave
god_of_cpu's Avatar
god_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond reputegod_of_cpu has a reputation beyond repute
You can', you have to cut regions out of the host window that you don't want to cover up StreetDeck.
StreetDeck.com Developer (I am Chuck)
Get StreetDeck at http://www.streetdeck.com
The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
god_of_cpu is offline   Reply With Quote
Old 07-29-2007, 04:13 AM   #3
Is there any sample code for this?
Is there more than a couple pages on a wiki? Is there an API document?
Old 08-01-2007, 08:56 AM   #4
Raw Wave
god_of_cpu's Avatar
The call is the windows API call ::SetWindowsRgn. It may be easier for you to just make an overlay that is restricted to your module though and put duplicate Home and back buttons on it. Overlays will automatically be cut out of the embedded window by StreetDeck.
Old 08-03-2007, 04:30 AM   #5
No overlays will go over the module after
has been called.
ideas?
www.ssw.com.au
Old 08-06-2007, 08:26 PM   #6
Raw Wave
god_of_cpu's Avatar
Did you follow the instructions in the tutorial?
http://www.mp3car.com/wiki/index.php...od_%28Addin%29
If you play a music item, then goto the example digitalmod in the tutorial, does the playing media item show up in the lower left cut out of the embedded window?
Old 08-06-2007, 09:23 PM   #7
Yes I have read that and I did use the example as a base.
My problem is that after I call
module = app.CreateModule("StreetDeckDestinatorAddin");
I have a white window with nothing except the media arrow and track name on the bottom of the screen.
The overlay I created with
StreetDeck.Panel btnShowOverlay = (StreetDeck.Panel)module.CreatePanel(StreetDeck.en umCreatePanelType.eCPTButton, "BUTTONOVERLAY.BACK",
"DestinatorBack", //This is the function name that will be given back to us in any OnExec call and for all intents and purposes is the name of this panel
app.GetSystemMetric(StreetDeck.enumSystemMetrics.e SMGenericModuleClientX),
app.GetSystemMetric(StreetDeck.enumSystemMetrics.e SMGenericModuleClientY),
96, 96);
Does NOT go over the white background.
I would just like my overlay (the back button) to stay on top like the media section at the bottom of the page.
www.ssw.com.au
Old 08-06-2007, 09:25 PM   #8
Raw Wave
god_of_cpu's Avatar
Do other system overlays show up though like the media tray overlay?
Old 08-06-2007, 09:36 PM   #9
Raw Wave
god_of_cpu's Avatar
96, 96);
You are also not creating an overlay there. You are just creating a button. An overlay is on the same level as a module... it contains other panels (controls) in it. To have a button show above your embedded window, you would have to create an overlay, then create a button on it.
This would look something like this:
Code:
StreetDeck.ScriptOverlay overlayRecognition; //Create an overlay that will contain the other controls. Overlays are global and will be shown //above every other module overlayRecognition = app.CreateOverlay("VoiceShowRecognitionOverlay"); StreetDeck.Panel btnShowOverlay = (StreetDeck.Panel)overlayRecognition.CreatePanel(StreetDeck.enumCreatePanelType.eCPTButton, "BUTTONOVERLAY.BACK", "DestinatorBack", //This is the function name that will be given back to us in any OnExec call and for all intents and purposes is the name of this panel app.GetSystemMetric(StreetDeck.enumSystemMetrics.eSMGenericModuleClientX), app.GetSystemMetric(StreetDeck.enumSystemMetrics.eSMGenericModuleClientY), 96, 96);
Old 08-06-2007, 11:59 PM   #10
YAY
thanks thats better.
when do you expect the API doco will be released? evan a beta copy?
www.ssw.com.au
Old 08-07-2007, 12:03 AM   #11
Raw Wave
god_of_cpu's Avatar
The Streetdeck IDL file should contain descriptions of every method available. More through API documentation won't be available until version 2.0.
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
Left arrow key has 'back' function associated with it S4Per StreetDeck Bug Reports 9 03-17-2007 02:06 AM
fabricating dash xenarc 700tsv buttons help michaelrj9 Fabrication 4 03-16-2005 05:34 PM
I'm Back, It feels good to be home Kinnish General MP3Car Discussion 3 06-26-2002 07:00 PM
