Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > DigitalMods (Scripts / API)
Old 03-10-2008, 09:14 AM   #1
Getting plugin working with VB.NET
I've been trying to get a sample plugin working with VB.NET (VS 2005), using the sample C# code as a basis. I can get SD to register and load the plugin, but can't get it to register event handling (OnExec) and wonder if I'm missing a trick.
I've tried both creating delegates and adding event handlers, neither of which seems to result in my event being fired.
Code:
Imports system.runtime.InteropServices Imports SD = StreetDeck Public Class SDPlugin Implements StreetDeck.IDualStreetDeckAddin Private Const ModuleName As String = "SamplePlugin" Private SDApp As SD.StreetDeckApp Private SDModule As SD.ScriptModule Private SDOverlay As SD.ScriptOverlay Delegate Function SDOnExec(ByVal Description As String, ByVal eEM As StreetDeck.enumExecMessage, ByVal wParam As Integer) As Boolean Private SDOnExecDelegate As SDOnExec Public Sub OnConnection(ByVal Application As Object, ByVal eConnectMode As StreetDeck.enumAddinConnectMode) Implements StreetDeck.IDualStreetDeckAddin.OnConnection SDApp = Application SDModule = SDApp.CreateModule(ModuleName) Dim btnShowOverlay As SD.Panel = SDModule.CreatePanel(StreetDeck.enumCreatePanelType.eCPTButton, "BUTTON.LISTITEM_HIGH", "ShowOverlay", SDApp.GetSystemMetric(StreetDeck.enumSystemMetrics.eSMGenericModuleClientX), SDApp.GetSystemMetric(StreetDeck.enumSystemMetrics.eSMGenericSettingsModuleClientY), 200, 200) btnShowOverlay.Caption = "Show Overlay" SDOverlay = SDApp.CreateOverlay("OverlayTest") SDOnExecDelegate = New SDOnExec(AddressOf On_Exec) SDModule.onexec = SDOnExecDelegate 'AddHandler SDOverlay.OnExec, AddressOf On_Exec End Sub Public Sub OnDisconnect() Implements StreetDeck.IDualStreetDeckAddin.OnDisconnect End Sub Private Function On_Exec(ByVal Description As String, ByVal eEM As StreetDeck.enumExecMessage, ByVal wParam As Integer) As Boolean If Description.ToUpper = "SHOWOVERLAY" Then If eEM = StreetDeck.enumExecMessage.eEMSelect Then SDOverlay.Visible = Not (SDOverlay.Visible) SDOverlay.MsgBoxEx("Overlay visibility changed!", "Button Clicked", StreetDeck.enumMsgIconType.eMsgIconAlert, 1) End If End If Return False End Function End Class
Can anyone shed any light as to why this isn't working?
PhatStu is offline   Reply With Quote
Old 03-10-2008, 09:39 AM   #2
Well, using the delegate approach doesn't seem to work. But if I use the right variable for the addhandler, it works fine.
RRTMS - RoadRunner tire monitoring system extension plugin Robby BMW RR Plugins 85 09-15-2008 05:48 AM
DJiK's Jump-to-File External Control Plugin, v0.99b [BETA] DJiK RR Plugins 119 12-25-2007 02:20 PM
Infill G4 stopped working haiminger Centrafuse 12 11-11-2007 02:54 PM
Hello World plugin paulpv CF Plugins 5 06-08-2006 10:07 PM
How do I setup the CD Rip plugin ? guino RR FAQ 1 09-21-2005 11:38 AM
