The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > DigitalMods (Scripts / API)
Thread Tools Display Modes
Old 10-25-2006, 03:27 PM   #16
pogitalonx's CarPC Specs
My Photos: (0)
Look up how to create a DLL.
C# is the easiest to use. Unless you are going to be doing something really hardcore that needs to run without .NET installed, don't use C++, especially if you're a beginner.
http://www.google.com/search?hl=en&l...3+creating+dll
Check that out. Then check out how to register it for COM interop after you've made a DLL.
pogitalonx is offline   Reply With Quote
Sponsored Links
Old 10-25-2006, 06:49 PM   #17
bgallagher's Avatar
Vehicle: 02/Ford/GT Mustang
My Photos: (0)
COM Interop
I would strongly recommend this book, ".NET and COM: The Complete Interoperability Guide by Adam Nathan" to guide you in the right direction if you plan on creating your DLL with .NET.
bgallagher is offline   Reply With Quote
Old 11-28-2006, 08:21 PM   #18
nakinney's CarPC Specs
Vehicle: 2005/Nissan/Frontier
My Photos: (0)
C#.NET COM events
bgallagher, did you ever figure out how to send COM events to vbscript from a DLL written in C#? I have written a Sirius comunication library using C# that is done except for the fact that I'm having difficulty sending the events.
Everything works fine in VB6 and .NET....
nakinney is offline   Reply With Quote
Old 11-28-2006, 08:52 PM   #19
bgallagher's Avatar
My Photos: (0)
Quote: Originally Posted by nakinney View Post
bgallagher, did you ever figure out how to send COM events to vbscript from a DLL written in C#? I have a written Sirius comunication library using C# that is done except for the fact that I'm having difficulty sending the events.
Regarding the .NET event problem, there are a couple of ways to register events in VBScript but this engine does not support them. Typically, to do this in a scripting environment you would use Wscript's version of
CreateObject that defines a "prefix" to hook the events or you could declare your variables using 'WithEvents'.
I ended up following Chuck's instructions by manually triggering my methods once they are stored and invoking them as needed in my DLL. Now, in .NET when you want to pass parameters by reference when late binding to COM members via IDispatch, you must pass an array with only a single "ParameterModifier" element that is initialized with the number of parameters in the member being invoked. If you need sample code, I can provide.
-Brian
STIC
Old 11-28-2006, 09:28 PM   #20
My Photos: (0)
Sample code would be appreciated!
Sponsored Links
Old 04-06-2008, 05:48 PM   #21
dasaint80's CarPC Specs
Vehicle: 2008/Scion/Xb
My Photos: (0)
What's a good Book for a basic crash course ???
dasaint80 is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Open Source Skin Editor for RR lbooker Road Runner 66 04-16-2007 01:51 AM
found in fperrorlog 510SX FP Bug Reports 3 09-21-2006 08:01 AM
Access 2003 help needed veedubya Off Topic 2 05-31-2006 06:49 PM
Bug Reports 1.09 frodobaggins FrodoPlayer 279 10-22-2004 10:24 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 12:25 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
