The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > DigitalMods (Scripts / API)
Thread Tools Display Modes
Old 02-01-2008, 01:06 AM   #31
skeurton's CarPC Specs
skeurton's Avatar
Vehicle: 2003 Mazda 6
My Photos: (31)
yup, navigation works just fine.
skeurton is offline   Reply With Quote
Sponsored Links
Old 02-01-2008, 07:09 AM   #32
gfmedia's CarPC Specs
gfmedia's Avatar
Vehicle: 2006 Dodge Charger R/T
My Photos: (0)
In 1.1.1 I have to enter Nav, once it gets nav started, I can use anything (Weather, Movie Mod, Gas Prices) after it has found me on the nav screen. PITA. Have you tried that , entering into the mod after nav is used (you do not have to Route anything, just let Nav initialize and find you. I realized this after a couple days that anything GPS based must take its cue after and only after Nav has been initialized)
gfmedia is offline   Reply With Quote
Old 02-01-2008, 10:54 AM   #33
S4Per's CarPC Specs
S4Per's Avatar
Vehicle: 2002 Audi S4 - Not quite stock
My Photos: (0)
if it turns out that this is the issue, you could use the -nodelayload and/or -nodelaycomp switches when starting SD. I've used both of these ever since I knew about them and they (i forget which one does what) load and initialize all modules at start.
S4Per is offline   Reply With Quote
Old 02-01-2008, 11:53 AM   #34
gfmedia's Avatar
My Photos: (0)
well it is interseting to note, that while loading SD it says at the bottom "initializing navigation" but yet I have to still enter into NAV to "initialize" persay. I have not tried your method of the -nodelay (anywhere to find out what these switches actually are?)
Old 02-01-2008, 11:54 AM   #35
S4Per's CarPC Specs
S4Per's Avatar
My Photos: (0)
there's a faq or sticky on here referencing all SD command line parameters.
EDIT: here you go
Old 02-01-2008, 12:52 PM   #36
skeurton's Avatar
My Photos: (31)
i've tried all methods posted so far...
- starting navigation, then trying weather
- using both of the -nodelay commands
still nothing. i'm stumped. my gps is picking up a signal, but weather is still giving me an error saying that it cannot acquire a zip code. what gps receiver are you all using?
Old 02-01-2008, 01:14 PM   #37
gfmedia's Avatar
My Photos: (0)
crappy Delorme Earthmate LT-20
Old 02-03-2008, 10:06 PM   #38
skeurton's Avatar
My Photos: (31)
Quote:
It uses mappoint directly for the database, but it can only find a zipcode if it can get a complete address for your location. It should always return a zip code after you move around for a while, but it might not get one until it finds its first location.
The weather digitalmod uses the zip code.
found this bit of information in the thread about the gas price digimod. i believe this is my problem. i can only download info from the internet while i'm sitting outside my house, which is fine since all i want to do is check the weather before leaving home. anyway, i live on a road that was built last year, hence it's not in mappoint and a complete address doesn't exist.
so does anyone know a way to get this to work simply by entering a zip code? i looked at the code and found this:
Code:
Sub Module_OnEnter(bFromReverse) ClearWeather bSpeak = module.GetBoolOption(OptionSpeak) SideBarList.CheckItem 0, bSpeak, False strZipCode = navigation.GetCurrentZip If Len(strZipCode) <> 5 Then 'We couldn't get a valid zip code, lets use the last one we stored strZipCode = module.GetStringOption(OptionZipCode) End If 'If we still don't have a zip code, then we error out If Len(strZipCode) <> 5 Then module.MsgBox "Could not determine the current zip code. No weather data will be downloaded. Please make sure the GPS has a signal", "No ZipCode!" module.GoBack Exit Sub End If
i imagine this is what needs to be edited in order to use a static zip code. i'm not really well-informed on vb scripting, though. can anyone help me out?
Old 02-04-2008, 06:45 PM   #39
skeurton's Avatar
My Photos: (31)
nevermind, figured out how to use a static zip code
Old 04-08-2008, 07:06 AM   #40
gfmedia's Avatar
My Photos: (0)
ghave you gotten your dynamic weather updates working yet? I switched to a sprint ovation gps/internet combo and if I am stationary, it will pick up my gps signal, but I cannot use any of my internet/gps mods. Instead, I have to move a little bit then all kick in.
Don't know if you noticed this or not, I just thought I would throw it out there for ya.
Sponsored Links
Old 07-23-2008, 01:15 AM   #41
froalskiner's CarPC Specs
Vehicle: 06 G35C
My Photos: (0)
Ok, I made an update to this digimod. Looks like the URL for weather.com changed.
http://www.mp3car.com/vbulletin/atta...eather-2.0.sdz
Planning: 100% [-▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ->
Bench Testing: 100% [-▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ->
Car Installation: 100% [-▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓ ->
Overall Progress: 95% [-▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓- ->
My Worklog
Wants Mr. T NAV Voices!!!!
froalskiner is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Weather Cache danl Road Runner 8 05-28-2006 04:50 AM
Weather program for Map Monkey warnockm Other Cool Stuff 5 12-10-2005 08:14 PM
Weather Refresh? Chuck Road Runner 45 08-30-2005 05:24 PM
how about a weather wiki site burnhamd Off Topic 2 08-30-2005 10:11 AM
weather with no connection DaRacerz CF Bug Reports 0 02-01-2005 09:46 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
