10-15-2006, 11:12 AM
#1
Traffic Report Module
I will like to have/built a module for the Traffic Report, for some of you this should be basics, but I have no programming skills  .
Compare to the Podcast and the Weather module this should be an easy one, It will also use RSS, and the interface should be very simple. This is where I want to pull the RSS from:
http://rss.traffic.com/rss.xml?c=jqH...gDw7cZRg4oM%3D
Is there any documentation on how to use RSS functions in SD?, any Help?
10-15-2006, 11:44 AM
#2
Raw Wave
Vehicle: 2003/Infiniti/G35 Sport Coupe
Theres no RSS functions per say. RSS is just an online accessible XML file.
The only StreetDeck function you need to use is Utility.DownloadFile to download the online XML file then just load the MS XML parser as a COM object and parse the RSS feed as an XML file. As you mentioned, both of these things are demonstrated in both the podcast and weather DigitalMods.
10-17-2006, 09:06 PM
#3
It worked!, after a quick reading about xml and xml Dom, etc, it was not that dificult, right now its working with text only, maybe you can help me with a question.
How do I extract just part of the text in a specific node?, for example the date and time that the report was created is part of the title, and I only want to diplay the time.
10-18-2006, 07:09 AM
#4
Vehicle: 2003 BMW 325ci Sport
Good luck with this.... another GREAT addition to SD!!!
10-18-2006, 11:23 AM
#5
Raw Wave
Use the vbscript string functions, i.e. Mid, Left, Right, and InStr shoudl do it.
10-18-2006, 05:10 PM
#6
Filatelico that is a good idea. once you have completed that MOD would you share.
10-18-2006, 05:58 PM
#7
I already have that mod
10-19-2006, 02:30 PM
#8
Thanks Chuck, that should do it.......2 more questions:
1. How do I calculate the distance between 2 coordinates?
2. Is there a way to send data to the navigation module from a Digital Mod, like a coordinate or address result, and start the navigation to that location, how?.
So far the mod does 2 things:
1.Give you a Jam report for specific routes based on traffic.com
2.Accident report based on GPS location
Are they any disclaimers or lagalities about sharing mods?, I would like to post it once its done.
01-02-2007, 08:37 AM
#9
You alread have a traffic mod? Can you share?
Kris
| Thread Tools |
| Display Modes |
Linear Mode
