05-15-2007, 12:35 PM
#31
Quote: Originally Posted by polo6979
Still get it after the .net 2.0 install... here is a screenshot of the error.
I am having the same problem. As a programmer, when i see an ActiveX error it usually means that a DLL (or OCX) is not registered. Could this be the problem? Which DLL's should I look for?
Thanks,
Scott
05-15-2007, 07:35 PM
#32
Vehicle: 2005/Nissan/Frontier
You need to register SiriusCom.Sirius.dll. You can run the script to register it. It's located in the script directory at ..\My Documents\StreetDeck\Scripts\{56228B41-EF0B-469A-BE38-67AC73CF5C4C}\Addins\RunMeFirst.cmd
07-02-2007, 08:59 PM
#33
ok, im just messing with the SD demo
and when i double click the sirius.sdz file
it fails durning install
it does show up under digitial mods, and says stopped
this "digital mod" needs to be reworked, its using OLD OLD OLD
sirius code
also, StreetDeck should support it natively
mitch
07-09-2007, 10:01 AM
#34
I am finally ready to get Sirius on my Streetdeck versus the head unit and notice that the SR-ALP1 adaptor is not available from rush2112. Anyone have current experience with the new adaptor and older tuners or must I switch to a new tuner too?
07-16-2007, 09:10 PM
#35
the SC-C1 is better the SR-ALP1
same price for my interface, but smaller/better/cheaper sirius tuner
and i did the /sirius switch on streetdeck, its native support worked. a little slow but it worked
mitch
07-16-2007, 09:27 PM
#36
what is the /sirius switch? I have searched and don't find anything.
07-16-2007, 10:57 PM
#37
C:\Program Files\StreetDeck\streetdeck\streetdeck.exe -sirius
To see the whole list of options:
C:\Program Files\StreetDeck\streetdeck\streetdeck.exe -?
07-17-2007, 09:11 AM
#38
Raw Wave
Vehicle: 2003/Infiniti/G35 Sport Coupe
Its a beta feature. I haven't tested it myself yet, but it should work. It should allow you to use StreetDeck for sirius instead of XM, when you run with -sirius, just configure the satellite radio settings for your sirius hardware and instead of XM radio and the XM radio ui should work for sirius.
08-14-2007, 03:14 PM
#39
Vehicle: 2004 Honda Civic Si
I'm using -sirius with some success. Streetdeck will play the Sirius (ALP-1) but always resets my Line-In volume to Max. Annoying.
08-23-2007, 06:32 PM
#40
I'm doing the same with the SC-C1 and unless ive done a clean shutdown/startup (e.g. not a restart and not a hibernate/standby (which generate their own problems)) when it starts the background system noise is amplified like crazy and actual audio coming in is about half the volume it was at before hibernating/standby.
When I say background system noise I mean that sound you can hear when you crank up your volume to maximum without any music playing. It's not a ground loop in the vehicle, the alternator, power windows, headlights and AC do nothing at all to the sound so I know it's internal to the system.
Anyway, you would never listen to the computer at that volume because any actual sound would be deafening (this is quiet noise coming through at music levels) but that's whats strange is that the radio is then so quiet. It ONLY does this if I didn't do a clean startup/shutdown. If I play an mp3 while this sound is coming through, it mutes the line-in when it switches over to the mp3 and the sound goes away immediately. When I mute the line-in manually it also goes away, so I don't know what's going with the line-out when the system powers down, but when it comes back up it sounds like its been dropped down to 1% and then had the gain cranked up.
P4MST-890 775 MicroATX Pentium Dual Core E2140 , 80GB 2.5", OPUS 320W, MS GPS, SB EXTREMEGAMER PCI, 8" LILLIPUT TS, 15" NEC TS, SIRIUS USB PC INTERFACE, STREETDECK, KICKER ZX850.4, KICKER 2500.1, 2xKICKER SS65.2, 2xKICKER 10"COMPVX
09-18-2007, 11:53 PM
#41
OK.. I can't get this to install.
SD recognizes the program, then when i click install, it starts, but I get this error:
I've run the script, I've tried the switch... Nothing.
09-19-2007, 12:33 AM
#42
sirius code
mitch
This is what happens to me (Screen shot above)
Sean
09-21-2007, 12:04 PM
#43
Vehicle: 2004 VW R32 ... 2006 Jeep Commander
dont try to install the .sdz package.. just run streetdeck.exe - sirius.. go into setting setup your com ports etc.. and it should work when you click on satelite radio
09-21-2007, 12:13 PM
#44
Where exactly do I run this command line? I tried changing the shortcut to include " - sirius" and it didn't work....
09-21-2007, 02:09 PM
#45
OK, for those like me that didn't know where to run this command line:
1) Right click on the shortcut and select properties
2) In the "Target" field, add this to the end of the command line:
"C:\Program Files\streetdeck\StreetDeck.exe" -sirius
The " -sirius" goes AFTER the the quotes in the target field.
Thanks to Goce at mp3car for his help on this!
Great support!
| Thread Tools |
| Display Modes |
Linear Mode
