The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > StreetDeck > DigitalMods (Scripts / API)
Thread Tools Display Modes
Old 05-22-2007, 09:39 PM   #46
S4Per's CarPC Specs
S4Per's Avatar
Vehicle: 2002 Audi S4 - Not quite stock
My Photos: (0)
Quote:
This is assuming you know how to run digimods in dev mode
i don't...any pointers?
also - any progress on fixing it overall?
Thanks,
Per
S4Per is offline   Reply With Quote
Sponsored Links
Old 05-23-2007, 08:56 PM   #47
bembowe's CarPC Specs
My Photos: (0)
Thanks,
Per
No Progress on the fix. This issue is happening with most digital mods. the streetdeck team will have to fix it. I believe they are aware of it.
to run the script on dev mode.
open the SD in dev mode. on the modules panel. browse to find the GPS Gas Price project within the script project. just follow the pic attached.
now double click on Preference. this should bring up the code.
next, Press the Play icon, the one circled on the pic.
now go to the SD window and browse through it to get to the digimod. the Gas Price digimod should be running.
You should be able to change any preference from here.
bembowe is offline   Reply With Quote
Old 07-17-2007, 09:02 PM   #48
96khz's CarPC Specs
Vehicle: 2006 VW Passat
My Photos: (0)
I just updated to 1.1.0.1 and saw that there were some scripting fixes. I gave this digitalmod a try again and it's working great! Thanks for the hard work on this very, very useful app.
96khz is offline   Reply With Quote
Old 07-18-2007, 09:54 AM   #49
My Photos: (0)
thats great. I havent been able to test this app in a while. my car pc is down again. its good to see it working again.
Old 07-23-2007, 01:35 AM   #50
96khz's CarPC Specs
My Photos: (0)
I just returned from a 1000 mile trip around the state using the Gasprice Mod. It worked great. Solid. No crashes or problems.
I check gas prices every so often for the places I was driving past. Pumped at some gas stations that were a few of blocks away from the interstates that were about 10 cents cheaper per gallon.
Another time, the mod informed me that gas on the other side of the freeway overpass was a few cents cheaper.
Sponsored Links
Old 07-23-2007, 11:07 AM   #51
My Photos: (0)
Men, thats sweet news to my ears. I have never used the mod outside my area (no internet access). Good to see that it worked as designed.
Old 07-24-2007, 08:25 PM   #52
meth68's CarPC Specs
My Photos: (0)
Hey guys am I missing something? I installed this mod and it comes up searching for seattle gas stations. I went to preferences and added my zip code and selected premium gas and hit save. Now at the bottom it lists my zip code, I click check zip code and the lady comes up stating "checking xxxxx" which is all good, the problem is nothing happens after that the gas stations are not updated and it still lists seattle. I have an active internet connection (EVDO) that works fine with IE and Google maps cache app.
Any ideas?
meth68 is offline   Reply With Quote
Old 08-23-2007, 07:23 PM   #53
My Photos: (0)
I have still yet to get this to work correctly, is it safe to say its dead for 1.1.0.0?
Old 08-23-2007, 09:10 PM   #54
My Photos: (0)
I am running 1.1.0.0. I just uninstalled the digimod and downloaded the mod from the wiki. I installed this version and it worked fine. upon initial start up, it will show the data for seattle but you should be able to go to preferences and change the settings as you said you did.
after that you would have to press the search button for it to load the new data. it doesnt get the new data unless the search button is pressed.
Now is your search button enabled after going to your preferences?
Old 08-23-2007, 09:15 PM   #55
My Photos: (0)
I installed, set the zip code and hit search. It seemed like it was searching but once it finished it still only listed Seattle information.
Old 08-23-2007, 11:57 PM   #56
S4Per's CarPC Specs
S4Per's Avatar
My Photos: (0)
hmmm...works for me.
now - i AM in Seattle , but seriously, it updates to the various zip codes in the area for me just fine.
Old 08-24-2007, 11:39 AM   #57
My Photos: (0)
Meth68,
try this suggestion. uninstall the digimod.completely remove the folder under the script folder in SD folder. unregister the dlls within the COM folder of this digimod script folder. then get a new copy of the sdz and try installing it again. it might be that you have an old version of the dll that this digimod uses.
Old 08-26-2007, 04:51 PM   #58
Vehicle: 2004 corvette Zo6
My Photos: (0)
i can't find where to download this at.. can someone please give me the link. I know it says it's at the wiki page but i can't find it anywhere. Thanks
dvau11484 is offline   Reply With Quote
Old 09-07-2007, 09:26 AM   #59
My Photos: (0)
Quote: Originally Posted by bembowe View Post
Had a bit of a problem ftping it. incorrect size.
Try it now. it should work
wiki
here is the wiki link men
Old 10-17-2007, 10:11 AM   #60
twenty8eight's CarPC Specs
Vehicle: 03 Hummer H2
My Photos: (0)
I just downloaded this mod...Is it still necessary to register the .dlls and stuff like on the first page of this post or can you simply install it now if you have the version from wiki?
twenty8eight is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
